Vadim
Polikarpov I-16 Type 28, 1/48, ICM
Hello everyone.
While my Mosquito getting final coats of satin varnish, I couldn't resist and started this one...
Polikarpov I-16 Type 28 in 1:48 from Ukrainian manufacturer ICM:
rLtnlNdHrlfR9ukamNhXSlLBPMf-N9SYTmEevzH2
For those who unfamiliar with the kit here are few shots of sprues and details which are really nice and crisp:
Mc23l1nMkghw8E3M8O69tGpyIZl_pq7kBFrZt9iE
IidWzADYHbR2UlB_wsxW6svmajNOwvlcDX0PLT2T
ybzMOqb0JF4oNIVK92eyedmI_gAQWC4oN5s5aqiR
9u74CSCyQhFIO94GNwEHxCuaZalUYY_QwYQE7z-F
I started with the wings and ailerons:
Pn5KwAwJq0PU7RWOCOpo1U_Win_YXNlnxrWEC_Ba
Followed by the cockpit which is really basic:
x8CZP6Sw9hpDxvNR2uJUlyxVnyKW1p5YlJlG3_on
B2hGkupbAb6IPthXAnA0QweL9AdmmAxZHxBpAsF2
The fit is brilliant and I really enjoyed that first hour with this model:
RR9RvyQJI1BY9bBJ11Sr3AQtbjWsIS_5Pa7AkXQr
Here is another small update:
I started with the engine and also made a dark wash on the cockpit. Currently thinking to add seat belts... probably will make them from the remains of the PE fret
3N-h8bSlLuCRmf8M6D1EDpbmtSbv4NoLuj_7ztfv
t5A4sxWQ9UlfbslmGrFvnfGIAe3NRSezvhz2Crgk
Here is the next small update on my I-16:
I do this straight out of the box. I've completed the cockpit, but I couldn't ignore a lack of seat belts. So I've decided to add some scratch built. I used a foil from the wine bottle neck and made two loops around with beading wire... Hope it looks ok :phew:
So tonight I can close the fuselage, attach wings and it will be ready for painting. :yahoo:
rDB57PhQMvcf8tcsSteTaKk2zEYHrujvRhdvmJaA
BNXz3geA-8IcDXxgjwoIpGUraYhQ0ipc-pKQDqxA
wGQcaR2cIJJVaMvBDYBppLZeBjKFOjrYnACxfSXW
Edited by Vadim
My last session with this small fighter was really enjoyable. As you may see these pictures, I closed the fuselage, attached stabilisers and wing. The rudder and stabiliser remain movable.
Now I continue with the engine - attaching all the exhaust pipes, which must be positioned correctly into the fuselage holes. Once it is complete I can start painting.
UDitsVW3JbX_sd_D4WnDOelQBeqkjmNQ8FRceHm_
The fit was nearly perfect! Hope it just requires some sanding and no filler will be used:
gnrAUM31L_0uueigy68nInvuFL820_CUpS7vj7Ow
Finally, I can see the shape of this small bird!
o-sRDa6nD43NdFRr6bBLSdikWB2X-_2QL-sPD_--
Excited to see how this turns out. Just complete ICM's I- 153 kit. Was a joy to build - but looks like there's more fun to be had with this as far as positionable control surfaces go. Looking great so far!
Hey, Bruce, thanks for your kind words! I've visited your I-153 RFI - it looks really nice and cool. I liked that worn look.
Another small update here...
All sanded and I used just a little of Vallejo putty.
Wheel wells are masked with maskol and everything is ready for painting:
JTBKRa2BBfW_pdJWA8CUvmoAxW7tQpLxVhRQuFeG
oHHT6dI6mAUtK8BFkGv6D4JyjDmkvVT1DpCu8b9A
Here is another small update.
I've completed the painting, gave a coat of gloss varnish (Vallejo) and applied decals. Actually I really impressed of decals quality. They are really thin and stick really nice. All the underneath panel lines are visible:
vXNnB5iV3dCSY9xyNP80g_8AhXeRT_E0X9-a2bUE
fAL3D1zASmPkWNKhEDVFWF21CnRBgaZl9ou1fAE8
iwXWydwktpyR8GrZHAbENGw4lEMJ04CdH0CNveNr
b5UDFvFQEbXO2jWFdx--lp8YRM6OPUiMtftrfR7w
Very nice! I recently built the ICM I-153 and it was a very pleasant build.
Does the kit supply anything for the undercarriage retraction cable, or do you have to make/add it yourself?
Hello Vadim !
What a very nicely done Rata !
I did'nt have the ICM ones but as I can see they are pretty good !
Thank for sharing, your painting is really good too !
Must cool down a bit again before starting another soviet fighter !
Congratulations :yes:
Sincerely.
Corsaircorp
On 10/25/2017 at 10:33 PM, k5054nz said:
Very nice!
Thanks Zac. And no, nothing in the kit for the undercarriage retraction, unfortunately. And I don't plan to any extra details apart those seat belts. Want to keep this one as simple as possible :)
Thanks mate! This is really lovely kit. All fit perfectly and decals are superb.
Here what have I done over the weekend. Not much progress on the model but did some carving :pumpkin:
eqj3rU1XJqkYrxFsqdVaaF55xunyCTMv2qkKM9pQ
I managed to do some more progress here:
The engine was installed together with front section and propeller. Then I started to glue all the exhaust pipes - to ensure they are in proper positions I put engine cowling and fixed all the pipes in their respective holes:
bdu4_JGzDZgIyJG7SbNwQTceuAClXIWtH0duymEx
The model will be finished without engine cowling panels:
Rv1RAp3HPv4jmK2gz8ZXlifKCGlFhULX1NGLI6Jm
Then I installed all the flimsy bits for landing gear. The model is not heavy so I hope these won't collapse one day:
64PsadF89teeuYVTScU4NRQQDXViJ9i2MFIHYtsq
Then the canopy was masked and painted in few steps. I didn't use any pre-cutted masks, so I masked each frame rib separately and painted:
4FeOa_BXGQ5hKBCm-4gEpndU269MnWb-XJGaBOyj
I attached the opened door (which requires some weathering)
And this is how it looks this morning:
j_P2TSz1VgHFqaVUN2vtnbKwn4b88xbLmU_bNAHH
26 minutes ago, Corsairfoxfouruncle said:
I really must get one of these. They truly are good looking little fighters.
This is probably the most enjoyable kit ever... Quality, fit, decals are great. I got Do-215B4 from ICM which promises to be another pleasant build.
Lovely build Vadim! Based on the pics and description, this looks a good "mojo restoration" kit - I'll have to remember that. Good job!
A very nice build :)
I didn't realise the ICM kits were as good as this, your build has been a good advertisement!
