airscale
1/18 Fairey Firefly VX376
Having finished my 1/18 Spitfire XIV, I am hooked on the scale as it allows me to go nuts on detailing and get a scale effect through skinning with metal, so after a bit of deliberation I have settled on my next victim...
...you don't see many of these, in fact none in large scale (yet) and I like UK prop aircraft so I settled on the Fairey Firefly - they don't come in natural metal finishes which I like as it shows off the metalwork, so the nearest I could find is this bird a TT5 VX376 seen on 29th Feb 1956 - Pilot: S/Lt Mike Thorne, Observer: Lt Jones, Duty: Townsville to Cairns & target towing for the 1st Frigate Squadron...
..it is near enough NMF for me, this one, sister ship VX388 is in Steve Long's care in Oz and shows the sort of anodised looking finish - it is probably paint, but either way I still think I can work with it, and if worst come to worst I will just paint it smile.png . I may well do VX388 as you can't have better references than a real, and more importantly unrestored example..
..the first step in any project like this is good plans. I intend to scratchbuild it using traditional methods so a good outline & section plan is a must. I found some fantastic 3 views with sections by Jumpei Temma whom I trust as I used his work on my 1/24 F7F Tigercat...
..I had these scaled to 1/18 - here seen with my laptop - as you can see she is a big girl - 64cm span and about a third bigger than my Spit... I have two more sheets not shown that detail the undersurfaces & the fuselage & sections...
..the next step is getting repetitive strain injury by right click & saving every image on the internet I can find - some are real quality shots like this of VX388 - I can reproduce everything you see here, but cut some corners as will be seen..
..once references have been started I can start to work up a Photo-Etch sheet for the model - I did thsi for my Spit and F7F and it means many, many parts that would be difficult or time consuming to make can be 'drawn' in at about 5 - 10 minutes an item - some are obviously more complicated, but simple things like hatches, brackets, instruments, radiators all sorts of stuff can be made.
It just takes a bit of basic PC skills with a drawing program like CorelDraw (subscription @£22 a month, drop in & drop out whenever you need it) - I learned all I know with this and Rhino 3D modelling from Youtube videos - it really is straightforward.. making a PE fret has a couple of rules I may well do a quick tutorial on, but basically you just draw things in layers - things you want full thickness & things you want part etched - anywhere you can see through is just dissolved away. You also need to tag things to a frame so they don't just float away on theor own..
..so here is a bulkhead where I have started to trace it's outline and add detail to.. anything in blue is half etched - that is to say it disolves away half the thickness of the sheet, anything in yellow is full thickness - the metal is left untouched.. you can see I set the shapes to be transparent so I can see what is going on in the original pic - it is just like tracing...
..while this kick-off post doesn't have any actual building yet, I have spent about a week so far drawing up structures & components that will be used later on..
..for example the instrument panel - there are two as one is a backplate the detailed one fits onto, as they are copies of each other they always fit perfectly smile.png
..lots of assorted parts including throttle & prop controls, compass mount and loads of internal / external hatches & brackets..
..the Observers station - bulkheads & surrounding structure..
..the pilot's bulkhead is actually three layers of structure to get the best level of base detail before all the framework is added...
..another cheat for complicated or uniform parts when scratchbuilding or converting is 3D modelling - this is a wheel from my Spitfire done on Rhino -again a 3 month trial is available with the software which is enough to learn the basics, and get a few parts done - I will likely repurpose this for the Firefly as it has four cut-outs in the middle not 3 and has block tread not diamonds, but wheels & the prop spinner are pretty straightforward parts to design using a 'revolve' surface tool..
so that's it for day one - I think it's about a 2 year build and it is an aircraft I think will really have presence when completed. I am always looking for close up internal reference pics, or drawings so please, if you find anything drop it in here or PM me smile.png
I look forward to your company on the way, and while it is not as beautiful as a low back Griffon Spitfire, I hope it is engaging enough to keep us entertained smile.png
TTFN
Peter
Edited by airscale
Peter’s building a Firefly. I like Peter’s modelling and I like Fireflys.
What a treat this is going to be - thanks Peter :)
Peter,
Thanks for taking on another epic challenge.
Will be following of course and learning all the way.
All the Best!
Don
Peter,
Loved your Spitfire, so I will dip in and out on this one as and when, if that's ok.
Regards
Martin
That's a very nice choice of aircraft Peter.
I'm sitting in a very comfy armchair with two years supply of popcorn on order.
I can't wait to see what I'm going to learn on this journey and any tutorials along the way would be gratefully received and very much appreciated.
Best of luck.
This is going to be a really interesting build - the Spitfire got us entranced so a Firefly will be great - Steve Long would be a good source of references for RAN Firefly's - not forgetting that Paul Fisher is working on a 1/32 Firefly kit to go with the Sea Fury - things are looking up - if only Wolfpack would get their act together and finally produce the 1/48 resin Firefly wingfolds!
CJP
Another adventure begins!
Huzzah!
I'm right there with you Peter!  Thank you for continuing to share your artistry with us!!  I especially appreciate your sharing on photo-etching.
Many thanks!
PR
Great choice Peter looking forward to your progress and your excellent building skills.
Guy
I arrived at the Spitfire build very late, I glad I'm here for the start of this one
really looking forward to this
rgds
John(shortCummins)
Looking forward to seeing this unfold. I predict an absolute masterpiece.
Really looking forward to this, having  found it fairly early for once I might even get a seat near the front!
John
Edited by Biggles87
Peter,
Like so many others, I was enthralled by your Spitfire build and cannot wait to see how this one progresses.
I sense you're well on your way with a TT5 - but there was an all over silver Mk IV (apart from anti-glare panel) - TW692 which features in a couple of photos - one I think in the Warpaint book...? Again, I think the silver was probably painted rather than natural metal - and I would think the yellow/black undersides and target towing gear of the TT5 would be really eye catching.... But I wouldn't want you to get to the end and then think "I should have done THAT one!"
Looking forward to the next instalment.
Nick.
Note to self,
1/Search Amazon for bulk discount on popcorn.
2/Try to avoid bedsores while watching this by moving occasionally.
3/ Keep the mods busy so they don't notice 2 years worth of pages.
I too came across your Spitfire build very late and spent many enjoyable hours reading the thread from start to finish - Glad i'm here in time to follow this one, the word Epic springs to mind!
21 hours ago, CJP said:
..Paul Fisher is working on a 1/32 Firefly kit...
Oh my!  Is he?  His Fury is stunning.
Peter, you have picked one of my very fave aircraft; I look forward to learning a ton of stuff which I can then shamelessly plagiarise in 1/48!
Hoorah!
Hoorah!
I found Fisher Firefly news on this forum link - http://forum.largescaleplanes.com/index.php?showtopic=60778
CJP
Approved!!!
Stunning start with those drawings for the interior!!!
Let us dream!!!:yes:
Oh goodness! Here we go again.:D
"Somewhere, a little Tigercat waits..." (I really was expecting progress to resume on that little gem.)
Oh my! You really put the truth to the saying" The sky is the limit" don't you!
