Mystery conversion kit
freedomfighter
Certainly can. Its almost certainly 1/72, as I can't remember building in anything else. The fin height is 32mm and the length of the bottom of the fin is 42mm, and the bottom of the fin is concave, the curve tightening slightly towards the rear of the rudder. The main undercarriage legs have a lug on either side, so 2 main wheels per side. The main wheel doors are grooved on the inside, presumably to take the round main undercarriage legs. And the nosewheel leg, the upper part of it is 3mm square section - and that's not sprue, as there is a pin at the top of the leg to fit into a front fuselage. Hope that helps.
71chally, thank you for switching the light on! Have to have a look round for the rest of the kit now. Thanks to all of you for helping identify these parts. So if any of the readers of this thread have the wing halves and fuselage halves, I can help you out!
Thanks again
freedomfighter
