Belgian Mirage 5 BR
Graeme H
Well seeing as stevehnz has left the door open on this,
I thought why not, so
I have a Mk2 PJ kit in stock ( what a surprise), and although I was a little undecided, I settled on the BR recon version
37283011556_56a8a5ca69_b.jpgDSCN0800 by qfa_tsv, on Flickr
The great advantage of this kit is that it has a lot of resin goodness to do those late Belgian aircraft, with all their different bits
I started this on Friday
It requires you to cut off the plastic parabrake housing, as it the unique Belgian one included as a resin fin
37283005716_eb1b277013_b.jpgDSCN0811 by qfa_tsv, on Flickr
There are 2 clear resin noses included for either the early or later recon nose, I of course need the later one
37282994556_fa1c74fb78_b.jpgDSCN0813 by qfa_tsv, on Flickr
here the basics are just sitting together
37282988576_c363e1e1ed_b.jpgDSCN0814 by qfa_tsv, on Flickr
Must confess these HPM/PJ kits are very easy to build, the big downside is the gap between the wings and fuselage, which is the reason for the spacer, helps, but does not eliminate it at all as can be seen in the shot above, and is worse on the port side every time for me.
The resin include with this covers everything, including a Mk10 seat, and the big 1700L French style tanks, as well as a pair of Israeli 500L Supersonic tanks, being a recon bird I will be going with the 1700L tanks
A late entry!
Always  a special challenge with the big advantage of having less time to loose the spirit! ;)
Seems to be a very well balanced kit!
Good progress so far imho,
Looking forward to more!
All together and time to start the rather complicated all over camo paint job,
The PJ instructions say the Dark Green is FS34064, which is called a very Dark Drab, which sounds about right, because it is much darker than the FS34079 called out by most others.
Hardly surprising that Pierre has the good info, but then again Verlinden doesn't, Looking at photos of them in the early days with the lower fuselage in a light grey it looks much more like the Vietnam scheme whereas when they went to the all over scheme the colours changed.
Now I couldn't find anything that even came close, so went a searching at my favourite paint reference site IPMS Stockholm they suggest that a 50 50 mix of Humbrol Hu66 and Hu163, and when mixed does certainly give the right shade.
so some paint on
37230216890_f30258c5e2_b.jpgDSCN0824 by qfa_tsv, on Flickr
I had painted the inside of the intakes white before joining them up, and the outside of the intakes and the fuselage under the intakes in the green to save on a lot of masking in that area
Now there is the rest upper and lower and my thinking is to do one wing and fuselage before the other, as I can't really see me being able to do the whole lot in one go
Well doing some research on the Belgian Recon birds, I found the PJ painting instructions were more for a 5BA than a 5BR, then from the deepest recess of my now untrustworthy brain, I seemed to remember someone did a special for a 5BR scheme, so a search turned up that Modeldecal did way back last century, and lo and behold I have it, so changed to the camo scheme on that, but it's a bit small, and I can't find anything on my computer to increase the size like you can with some photocopiers, I'm sure that there was something, but damned if I can find it now.
So first things first with an allover scheme is where to start, as you can see I did the nose and some tan, but some of the tan is not correct by the Modeldecal sheet, and photos of the real thing, so some adjustment is going to be necessary.
These allover schemes are a right pain I can tell you trying to remember where you need to mask next, there was no way I could mask and do all of one colour, I have got the airbrush out 5 times so far, and still have part on the upper and lower to sort out.
The Bathurst Car Race is on tomorrow here in Australia, , so I should be good to get most of the painting done, while I watch that on my little TV in my modelling room
First the top
 36835557134_9579492e0b_b.jpgDSCN0829 by qfa_tsv, on Flickr
36835552844_e2f76ddc14_b.jpgDSCN0831 by qfa_tsv, on Flickr
The fin is going to be white, which is why no paint just yet, I did find some photos of BR04 and BR22 without the white fin, so if the Modeldecals don't work out I can just do it as a standard bird
The underside, still a lot to sort here
37497413096_aa9fb9e7a7_b.jpgDSCN0832 by qfa_tsv, on Flickr
The masking kept getting more and more intense, as I applied each colour and then it was time to paint the fin
I used Tamiya flat white, followed by a thin coat of Tamiya white gloss
DSCN0836
Then the top of the fin needs to painted light grey, so more masking, and do both at the same time
nothing to see here
DSCN0837
and also there is a black on top of that, no photos of that bit
Then the great unmasking, firstly the bottom, and you can see where I missed some of the tan on the port wing, oh the humanity and bit of masking tape I missed
DSCN0839
and the upper
DSCN0841
so onto doing some touch ups, then it can have a coat of gloss ready for the sickers
OK, moving slowly with this, but little by little
It got first use of the upside down jig, so lower bits going on
37200929264_c3bc3ee949_k.jpgDSCN0850 by qfa_tsv, on Flickr
and mostly done, a few U/C struts to add, then it can sit on it's U/C and get the topside done
37200926734_1fb9a8b692_k.jpgDSCN0852 by qfa_tsv, on Flickr
The big 1700L tanks had a different set of pins to the plastic kit, probably left over from the PJ resin Mirage, so had to drill holes for them, and the fit wasn't that good, next time I will do this before any painting, started using the old Modeldecal sheet, came away with some white coloured muck which I washed off with a brush, went down very well though, the tanks were the big test, before I have to do the fin, the rest will be the modern kit ones.
really hoping to get this one finished in time :hourglass:
OK, another over the finish line (just), this is the PJ Version of the HPM kit
first some lower shots, have to be in the jig to get these without damaging the model
a few comments on this, firstly the Modeldecals sheet was sized for the Heller kit, and it would appear their fin is a bit bigger, haven't had time to do a comparison yet, another is the PJ 1700 L resin tanks are a little undernourished, compared to most, especially the HPM resin one, think I would use those in future.
26225065269_214007bf27_k.jpgDSCN0866 by qfa_tsv, on Flickr
26225062949_0bd27ce600_k.jpgDSCN0867 by qfa_tsv, on Flickr
26225060489_0943525430_k.jpgDSCN0868 by qfa_tsv, on Flickr
38001168071_a4ad4a05cf_k.jpgDSCN0870 by qfa_tsv, on Flickr
Edited by Graeme H
additional
I don't know how I ever managed to miss this thread...   ...obviously needed my new specs.
I always remember seeing Belgian Mirages as we transited to RAFG from the UK and back, happy memories!
You've done a fine job there Graeme, thanks for your effort!
