Old Viper Tester
Harrier GR.5 at Red Flag 91-3
Red Flag at Nellis AFB Apr-May 1991...
Unfortunately, I could only get to the flight line on the weekend, so everything was buttoned up.
ZD352, No 1 Squadron, 01
ZD352 1sq 01 KLSV 19910504 05crZD352 1sq 01 KLSV 19910504 04
ZD375, No 3 Squadron, AO
ZD375 3sq AO KLSV 19910504 07crZD375 3sq AO KLSV 19910504 11
ZD400, No 1 Squadron, 02
ZD400 1sq 02 KLSV 19910504 27crZD400 1sq 02 KLSV 19910504 32
ZD404, No 1 Squadron, 07
ZD404 1sq 07 KLSV 19910504 01cr
ZD405, No 1 Squadron, 12
ZD405 1sq 12 KLSV 19919594 16cr
ZD406, No 3 Squadron, AB
ZD406 3sq AB KLSV 19919594 36cr
ZD408, No 1 Squadron , 11
ZD408 1sq 11 KLSV 19910504 12cr
ZD411, No 3 Squadron, AG
ZD411 3sq AG KLSV 19910504 10cr
ZD412, No 3 Squadron, AH
ZD412 3sq AH KLSV 19910504 20cr
Thanks for looking
Sven
Thanks for posting, finally have some load out reference pics for GR5's that aren't trials or publicity shots.
Mark.
Just found this thread too Sven.  It's rare to see new photos of UK GR.5s, so its excellent to see these; thank you! :)
I thought you may be interested in the brief aircraft histories as there some famous UK Harriers in the group, plus a couple of losses, after they were upgraded to GR.7 or GR.9 standard (Serial / build number fin code):
ZD352 /19 > 19 mission markings from Op Telic. Longest serving GR.9A on Op Herrick, 514 days; with IV(R) Squadron (the OCU) when Joint Force Harrier disbanded in Dec 2010, carrying pilot's name LT HOGG.
ZD375 / 23 > The 20(R) Squadron display aircraft in 2001 with the pale blue fin.
ZD400 / 30 > As a GR.5 crashed near RAF Wittering on 19-May-97; pilot ejected safely.
ZD401 / 31 > With IV(R) Squadron when Joint Force Harrier disbanded in Dec 2010, carrying pilot's name LT CDR FRANCIS.
ZD404 / 33 > As a GR.7A fly on Op Herrick with name 'Lucy' and black female silhouette plus 19x E-Paveway and, 3x 540lb bomb mission markings. Not upgraded to GR.9 standard.
ZD405 / 34 > As a GR.7 flew on Op Warden coded white WC and early onOp Herrick still with the insignia of the Fast Jet Weapons Operational Evaluation Unit on its fin. One of the last GR.9 conversions had yet to fly when JFH disbanded.
ZD406 / 35 > As a GR.7 flew on Op Warden coded white WB.  As a GR.9 carried the Fly Navy 100th Anniversary of UK naval aviation fin markings.
ZD408 / 37 > As a GR.7 flew on Op Warden coded white WK with a huge shark's mouth. Op Telic - 37 and another large shark's mouth, with mission markings. GR.7A coded 37A on Op Herrick it had 4x EPW mission markings applied. Crashed 16-Jun-08 into a field near RAF Cottesmore, pilot ejected safely.
ZD411 / 40 > As a GR.7 used for AGM-65 Maverick trials at NAWS China Lake in May-99 and flew on Op Herrick as a GR.7A coded 40A. Last flying GR.7A with IV(AC) Sqn on 31-Mar-10. Not upgraded to GR.9 standard.
ZD412 / 41 > As GR.5 AH with 3(F) Squadron (s0 in the markings seen) left runway while landing at RAFG Gutersloh, pilot ejected, aircraft ended up in Ems Canal.
Nick
Thanks for the info Nick. I've included into my slide descriptions.
Sven
Edited by Old Viper Tester
Removed extraneous info
Happy to help Sven.
The 'Desert Pink' Phimat is a 'relic' from the RAF's Jaguars which used them in the 1st Gulf War.
Nick
