Sign in to follow this
Hobbycolours
New products from HOBBYColours
Fellow Modelers!
HOBBYColours new e-shop is up and running by mid of August 2017:
Our new e-commerce platform is very flexible and safe, credit card payment was integrated and other features.
It is now very responsive and purchases will be more easy and safe from mobile and tablets too.
HOBBYColours new products available:
We are more than pleased to announce new products in our e-shop.
During 2017, new Companies like FOXBOT (Decals), DANmodels (PE/Resin parts), Mini World (PE/Resin parts) were added in our products offering.
Our own production and exclusive distribution of tools and modelling materials was also enlarged.
One of the most complete series of masking tapes for modelling is now available:
Modelling Masking Tapes – Standard
Our Standard Masking Tapes are Washi tapes (Japanese flat paper) uniformly coated with acrylic adhesive and 0.08 mm thickness.
These Modelling Tapes have ideal physical properties and seamless masking performance characteristics for boundary lines when painting:
    Tape will not give adhesive residue and not change color up to 120 °C for 30 minutes.
    Tape does not break when peeling off, but can be easily torn by hand.
    Tape back side will not repel the paints.
    Tape is designed to give an excellent and sharp paint break line.
With I.D. (Inner Diameter) size fits the standard tape dispensers (Tamiya dispensers as well) 25.4 mm / 1” inch while O.D. (Outer Diameter) size is 50.8 mm / 2” inch.
Available in 18m Length and Widths:  6mm, 9mm, 10mm, 12mm, 15mm, 18mm, 20mm, 24mm, 30mm, 36mm, 40mm, 50mm and 60mm.
HC50006F_1024x1024.jpg?v=1505735721HC50009F_1024x1024.jpg?v=1505735753  HC500010F_1024x1024.jpg?v=1505735190
HC500012F_1024x1024.jpg?v=1505735228HC500015F_1024x1024.jpg?v=1505735268  HC50018F_large.jpg?v=1505735313
HC500020F_large.jpg?v=1505735370HC500024F_large.jpg?v=1505735418  HC500030F_1024x1024.jpg?v=1505735533
HC500036F_large.jpg?v=1505735570HC500040F_1024x1024.jpg?v=1505735611  HC500050F_large.jpg?v=1505735643
HC500060F_large.jpg?v=1505735682
Modelling Masking Tapes - Curved Lines
The Masking Tapes for Curves are PVC uniformly coated with rubber adhesive and 0.051 to 0.12 mm thickness.
These Modelling Tape have ideal physical properties and seamless masking performance characteristics for curved lines when painting:
    Tape will not give adhesive residue and not change color.
    Tape does not break when peeling off, but can be easily cut by modelling knife.
Available in 10m or 20m Length and Widths: 2mm, 3mm, 5mm.
HC50002F_1024x1024.jpg?v=1505735035HC50003F_large.jpg?v=1505732635  HC50005F_1024x1024.jpg?v=1505153855
HC50021F_large.jpg?v=1505735441HC50022F_1024x1024.jpg?v=1505735489  Curved_yellowA_1024x1024.jpg?v=1505735463
Modelling Masking Tapes - Draw Lines
The Masking Tape No.HC50001 is a 1mm width by 13 m length tape. A PVC uniformly coated with rubber adhesive and 0.13 mm thickness.
This Modelling Tape has ideal physical properties and seamless masking performance characteristics for draw lines when painting:
Available in 1mm Length and 13m Width.
HC50001F_1024x1024.jpg?v=1501956190
For all new tapes above we have different choice of dispensers available.
Dispensers that will fit these tapes securely, easy and practical to use.
This will help you to keep tapes clean and for longer time.
