New Ultimate Sanders
Ultimate Products
You might be getting a bit of déjà vu here, but I can assure you that you are reading a whole new review, as Ultimate have revised their sanders a tad, now adding the word waterproof into the description, and colour coding them, which would be useful if I had any form of memory.  There are two shapes – the thinny sanders have a long narrow section that is very useful for detail sanding, with a shorter handle that is approximately three times the width, and allows sanding of larger areas without having to change sticks.  The others have a roughly rhomboid form factor, and I say roughly because one side has sharp angles, while the other is gently curved.  One of the sharp ends are rounded and the other is square, so you have plenty of different shapes to play with.
They are easy to use, and flexible enough to allow you some degree of latitude when handling them.  The thinnies have a tapered tip, which means you can get into even smaller places, and with their now documented waterproof nature, you can wet-sand with impunity.  I have used the older ones wet, and they stand up pretty well, although occasionally some of the abrasive would peel away under prolonged use.  This shouldn't be a problem now, even though it was only a little one.  The thinnies come in packs of 6 and the thickies(?) are sold in packs of 3, with the thinnies having the same grit on both sides and the standard ones having two grits per stick.
The samples arrived weeks ago, but because of the lack of modelling time I've had, they had to wait until I'd had time to use them before I could get the review done.  They've been my primary finishing sticks now since they arrived, and have been useful as well as capable.  When they clog during dry sanding (I was sanding resin at the time) they can be washed clean, which extends their lifespan, so they should last well.  Now I just need a set of waterproof coarser sticks to complete the set.
Thinny Sticks 800 & 400 (6 packs)
800 grit x 6
400 grit x 4
Sanding Sticks 400/800 x 3
Review sample courtesy of
