Sign in to follow this
Rabbit Leader
Generic Dot / Solid circle decals - does anybody make any?
Rabbit Leader    1,272
All,
Does anyone know where I can get a sheet of generic black dot or solid circle decals in different sizes, similar to Xtradecals' stripe sheets?
As I manly model in 1/72, there are times when a simple circle decal is good enough to represent a hole or vent, rather than having to drill, punch or score and risk these being uneven.
Any thoughts and possible links would be most welcome.
Cheers.. Dave
Ade H    88
It may be cheaper (in the long term) and easier to just spray through a small template. To do what you're after, I have used one of a set of Lionroar templates. I know that this doesn't directly answer your question, Dave, but I haven't seen such decals and at least this method works.
Rabbit Leader    1,272
Thank for the reply Ade. That may be another way around it, however I don't really fancy my chances in trying to make these nice and sharp. It does open up other possibilities though so is a good work around all the same.
Cheers., Dave.
Ade H    88
You just need to tape the template in place to get a sharp edge, because they're very flexible. They're the types designed for re-riveting and scribing.
LotusArenco    483
You used to be able to buy sheets of Letraset type rub-down circles and dots, but I’ve not seen or used them for years, sorry.
Alternatively, how about one of those blank DIY decal sheets for use in your printer?
Mart
Nigel Heath    13,739
You could invest in a set(s) of punches - not a cheap option but they come in handy for lots of other modelling jobs. Circular discs could then be punched out of black decal film or decals from the spares box.
Rabbit Leader    1,272
Thanks Lotus and Nigel, I quite like the idea of the print your own option. I'm surprised I'd not thought about it myself (that's why we ask on here I suppose?). The punch set also has many more applications, so perhaps I should also invest my hard earned sheckles in one of these as well.
Once again - thanks for your assistance chaps.
Cheers.. Dave.
pigsty    1,301
Isn't that what 1/32 is for?
