Lawzer Posted September 9, 2017 Share Posted September 9, 2017 (edited) Hi folks, while the Corsair awaits it's wheel HUBS (thanks in advance @Ade H) : I thought I'd get another victim on the go (thanks to @mike romeo for the bargain!)... For this I'm going to *try* and use my new toy: Bot of a tidy up required maybe first.... Dog shaking it's head in despair Anyway I've decided to do this as it's a fairly colourful scheme (thanks to @rs2man for the cheap decal set!).... Reason I'm doing a WIP is this is *well* outside my comfort zone and I'm looking for tips/suggestions. I'm going to try and re-scribe the whole thing, do a nmf (well, not foil but as close as tamiya acrylics will allow) and perhaps try some pre-shading (done before without a great deal of success) and if you folks think perhaps a bit of black basing. Anyway, wish me luck Edited October 3, 2017 by Lawzer 5 Link to comment Share on other sites More sharing options...
mike romeo Posted September 9, 2017 Share Posted September 9, 2017 I recognise that box! Looking forward to this! Regards Martin 1 Link to comment Share on other sites More sharing options...
modelman182 Posted September 9, 2017 Share Posted September 9, 2017 I think you should listen to the dog, mate! I've got the old Revell 32nd scale MkIII in my stash and it looks just as much of a 'bear' as that old 48th scale one. If you're going for an NMF then I'd recommend trying Alclad's lacquers - if you can, that is. They also do a black base colour for their metallics which would help with the 'pre-shading' idea. If you're tied to using Tamiya's acrylics then I'd try using some satin (X-18) or gloss (X-1) black for the pre-shading and then a base of X-11 (Chrome Silver) which can be mixed with some X-19 (Smoke) for emphasising selected panels. HTH Kev 1 Link to comment Share on other sites More sharing options...
BIG X Posted September 9, 2017 Share Posted September 9, 2017 That dog looks incredibly realistic - what scale is it... 1 Link to comment Share on other sites More sharing options...
Lawzer Posted September 9, 2017 Author Share Posted September 9, 2017 3 minutes ago, BIG X said: That dog looks incredibly realistic - what scale is it... 1/144 ...had my magnifying glasses on for the weathering 1 1 Link to comment Share on other sites More sharing options...
mike romeo Posted September 9, 2017 Share Posted September 9, 2017 I'm no expert on scribing, but in my opinion, less is more. Removable panels (engine and gun panels, f'r instance) and major construction joints do it for me. Scribing wings is easier (not easy) due to the flattish section. Fuse panels less so. If panel lines go across the fuse halves, you really have to do this once the halves are joined to ensure they match. Scribing on compound cuves: beyond me, I'm afraid! On the P-51, the first ~40% of the wing chord should be pretty smooth, I believe. Good luck! Regards Martin 1 Link to comment Share on other sites More sharing options...
Lawzer Posted September 9, 2017 Author Share Posted September 9, 2017 28 minutes ago, modelman182 said: I think you should listen to the dog, mate! I've got the old Revell 32nd scale MkIII in my stash and it looks just as much of a 'bear' as that old 48th scale one. If you're going for an NMF then I'd recommend trying Alclad's lacquers - if you can, that is. They also do a black base colour for their metallics which would help with the 'pre-shading' idea. If you're tied to using Tamiya's acrylics then I'd try using some satin (X-18) or gloss (X-1) black for the pre-shading and then a base of X-11 (Chrome Silver) which can be mixed with some X-19 (Smoke) for emphasising selected panels. HTH Kev Cheers- when (if) it gets that far I'll bear that in mind Link to comment Share on other sites More sharing options...
Lawzer Posted September 9, 2017 Author Share Posted September 9, 2017 4 minutes ago, mike romeo said: I'm no expert on scribing, but in my opinion, less is more. Removable panels (engine and gun panels, f'r instance) and major construction joints do it for me. Scribing wings is easier (not easy) due to the flattish section. Fuse panels less so. If panel lines go across the fuse halves, you really have to do this once the halves are joined to ensure they match. Scribing on compound cuves: beyond me, I'm afraid! On the P-51, the first ~40% of the wing chord should be pretty smooth, I believe. Good luck! Regards Martin Cheers for the info! i made a start on the scribing (already 3 "deviations" that'll need to be filled). no pain no gain Link to comment Share on other sites More sharing options...
Lawzer Posted September 10, 2017 Author Share Posted September 10, 2017 (edited) OK a small update... Scribing has been done. I fear some of them are like canals but hey ho.... Putty was to cover up some "slips" apart from the rear of the starboard fuselage - sink mark As @mike romeo said it'll be easier to try and scribe the lines that cross the fuselage join after it's been put together. Edited September 10, 2017 by Lawzer 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 10, 2017 Share Posted September 10, 2017 Dont forget most mustang wings were puttied to help smooth airflow. Very few panel lines other than the gun/ammo panels and a couple of inspection panels. 1 Link to comment Share on other sites More sharing options...
Lawzer Posted September 10, 2017 Author Share Posted September 10, 2017 42 minutes ago, Corsairfoxfouruncle said: Dont forget most mustang wings were puttied to help smooth airflow. Very few panel lines other than the gun/ammo panels and a couple of inspection panels. Hhmmmm.....i may have overstepped the mark a bit i might fill in some of the other lines..... 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 10, 2017 Share Posted September 10, 2017 Hello lawzer i think this will help i took a screenshot from another post a while ago here on BM. I think they had taken it from another Forum. So all credit to whoever's the original post was. I used this when i did my 1/72 P-51 a couple of months ago. It shows the different colors of aluminum and duraluminum as well as what was filled in. Hope it helps. To the Moderators If i violated any rules here at BM. I promise it is unintentional and was never done on purpose. 1 1 Link to comment Share on other sites More sharing options...
Lawzer Posted September 10, 2017 Author Share Posted September 10, 2017 38 minutes ago, Corsairfoxfouruncle said: Hello lawzer i think this will help i took a screenshot from another post a while ago here on BM. I think they had taken it from another Forum. So all credit to whoever's the original post was. I used this when i did my 1/72 P-51 a couple of months ago. It shows the different colors of aluminum and duraluminum as well as what was filled in. Hope it helps. To the Moderators If i violated any rules here at BM. I promise it is unintentional and was never done on purpose. Cheers mate! 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 10, 2017 Share Posted September 10, 2017 I believe the real aluminum to be the darker indicated areas. That would support the paint over putty idea. 1 Link to comment Share on other sites More sharing options...
BIG X Posted September 10, 2017 Share Posted September 10, 2017 Hi Ian - if you look at the picture of the scheme you are using it is covered in panel lines - look under the wing... ...'silver birds' look brilliant with sharp black panel lines. Don't forget - it's not ALL about reality... ...it's about having fun too and if YOU want loads of panel lines and a stunning looking model then go for it!!! It's your model and - who knows - maybe they ran out of putty on that particular day 2 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 10, 2017 Share Posted September 10, 2017 I agree with you BIG X. Build them however you want. I wasn't sure if Lawzer was going for super accurate because of the replaced panel lines in the above posts. Or is this just a fun build. But i thought id point out the wing panel lines in case he wasn't aware. 2 Link to comment Share on other sites More sharing options...
BIG X Posted September 10, 2017 Share Posted September 10, 2017 On 09/09/2017 at 20:41, Lawzer said: 1/144 ...had my magnifying glasses on for the weathering The weathering around the muzzle is superb - remember - less is more 2 Link to comment Share on other sites More sharing options...
Lawzer Posted September 10, 2017 Author Share Posted September 10, 2017 Me...accurate..... 2 Link to comment Share on other sites More sharing options...
Lawzer Posted September 10, 2017 Author Share Posted September 10, 2017 1 minute ago, BIG X said: The weathering around the muzzle is superb - remember - less is more Wait till you see the german shepard model i did in full diorama running... 2 Link to comment Share on other sites More sharing options...
BIG X Posted September 10, 2017 Share Posted September 10, 2017 52 minutes ago, Lawzer said: Wait till you see the german shepard model i did in full diorama running... I simply have no words - I'll keep my eyes open for RFI in the diorama area of the forum 1 Link to comment Share on other sites More sharing options...
Lawzer Posted September 25, 2017 Author Share Posted September 25, 2017 so a small update. foil seatbelts half on. front grill drilled out (although it doesn't look like it is in the pics). ready to be buttoned up. However it's a clear view through the what I believe is the supercharger/oil cooler. I'll need to try and do something with that.... not going to fit the tail wheel or radiator (or supercharger - not sure which) flap till later. Checked I can do it when fuselage is buttoned up..... 2 Link to comment Share on other sites More sharing options...
mike romeo Posted September 25, 2017 Share Posted September 25, 2017 Good progress! Link to comment Share on other sites More sharing options...
rob Lyttle Posted September 25, 2017 Share Posted September 25, 2017 Silver birds, I like em! Monogram too! Can I just show you what I picked up for a couple of quid - Lovely... Are you sure you want to use paint, and not Ali foil? Ah look, here's a seat....😃 2 Link to comment Share on other sites More sharing options...
Lawzer Posted September 26, 2017 Author Share Posted September 26, 2017 14 hours ago, mike romeo said: Good progress! It's pretty rough going - the plastic is somthick and hard.....broke 3 drill bits already 11 hours ago, rob Lyttle said: Silver birds, I like em! Monogram too! Can I just show you what I picked up for a couple of quid - Lovely... Are you sure you want to use paint, and not Ali foil? Ah look, here's a seat....😃 Nice! I'm on the lookout for kits like these now. Got a few tamiyas in the stash but going forward - retro all the way foil hhmmmmm - beyond mynskill set but i might give it a go. Could be the fuselage and most of the wing in foil (it'll end up looking like a bad Christmas turkey ) and the flaps etc painted....... 3 Link to comment Share on other sites More sharing options...
rob Lyttle Posted September 26, 2017 Share Posted September 26, 2017 Ever seen this stuff Lawzer? Sticky back Ali foil tape that builders use. Its a dawdle. 1 Link to comment Share on other sites More sharing options...
