Sign in to follow this
Messerschmitt Bf 109G-4 - 1:48 Eduard ProfiPACK
The Messerschmidt Bf 109 is one of the iconic aircraft of WWII. The G models arrived in 1942 and the G-4 was nearly identical to the G-2 but was fitted with a much improved VHF radio set. The R versions were also designed for reconnaissance some versions of the G-4 were fitted with underwing canon pods. Due to the increasing weight of the G models larger main wheels were fitted which resulted in the teardrop fairings on the upper wing surfaces. A larger tail wheel was also fitted and the retraction mechanism removed as it was too large to retract. 1242 G-4s were produced in total.
The Kit
This is a profipack boxing, with 4 sprues of plastic, a clear sprue, 3 sheets of photo-etch, Masks (not shown); and 2 decal sheets. Construction starts shockingly enough with the cockpit. Various control wheels and the main control column is added along with the armoured seat back. Following this the seat pan and rudder pedals are added. A full set of photo-etched belts is provided for the pilots seat. Following this side panels and parts are added into the fuselage sides, including some photo-etched panels. The instrument panel is made up using the supplied photo-etched parts. Once all of these sub-assemblies are made up they can be placed inside the fuselage and this closed up. As well as the cockpit the tail wheel and exhausts need to be added before the closure takes place.
Once the main fuselage is together the intake needs to be added on the side. For the tropical version this will need the additional filter adding as well. Construction then moves to the rear of the main fuselage with the tail planes and rudder being added. All of the control surfaces are separate so can be posed as needed by the modeller.
Next up are the wings. The lower is one part with left and right uppers. The wheel well detail needs to be added into the lower wing and then the uppers can be added on. Once complete the wing assembly is mated with the main fuselage. Next up the leading edge slats and ailerons can be added.  On the underside of the wing the left and right radiators are assembled and added to the wing. The flaps can then be added making sure to get the radiator flaps at the correct angle.
Moving towards finishing the model the main landing gear units are completed and added to the model. The wheels are a single part with a left and right hub. The gear leg is attached as is the door. The canopy parts can then be added not forgetting the pilots head rest & armour in the main centre part. Last but not least for the main kit the propeller and spinner are added. A centre line fuel tank is then added for tropicalised decal option, and underwing gun pods for the two other Luftwaffe options, and the Regina Aeronautica one.
Decals are in house from Eduard and should pose no issues. There is a main sheet and a supplemental sheet for the stencils, markings are provided for 5 examples;
  • Bf 109G-4/R6, W. Nr. 14997, flown by Lt. E. Hartmann, 7./JG 52, Taman, Soviet Union, May 1943
  • Bf 109G-4/R6, W. Nr. 14946, flown by Maj. W. Ewald, Stab III./JG 3, Kertch, Soviet Union, April 1943
  • Bf 109G-4/trop, W. Nr. 15013, flown by Lt. U. Seiffert, 8./JG 53, Tindja, Tunisia, April 1943
  • Bf 109G-4/R6, W. Nr. 19566, flown by ten. G. Gianelli, 365a Squadriglia, 150o Gruppo Autonomo, Sciacca, Sicily, July 1943
  • Bf 109G-4, flown by Lt. Av. P. Protopopescu, Escadrila 57, Grupul 7 Vânătoare, Kirovograd (Kropyvnytskyi/ Ukraine now), Soviet Union, June 1943
This is a welcome new G-4 release from Eduard. Highly recommended.
Review sample courtesy of
Yes it is good to have the Italian and Romanian markings in there.
