Tony Oliver
Mission Models Paint NMF - Faded aluminium
Tony Oliver    3,578
So this is from the new range of metallics released by Mission Models along with their aircraft shades. Courtesy of @TIGER HOBBIESLIMITED
I will be starting some tomcats to use the US FS greys soon, but I have a move coming up which is likely to delay those, so thought I'd give this a quick blast for the 'Russia with love' group build. (This build was planned to wear Revell aqua - eg cockpit was already done)
So about the paint-
This build was primed in the gloss black stynylrez, another new product to me, to make this an all acrylic NMF. (Link for gloss stynylrez at bottom of the post)
The mission metals are quite thin and not very 'dense' out of the bottle when compared to their other paints that come thick. This is down to the nature of the pigments that they use from one shade to the next as per their 'tip and tricks' on their website.
It also says to build up and spray the metals in light coats.
I can confirm this, the paint is thin enough to spray straight from the bottle.
Lots of light coats are the best way.
They dry much quicker too then and less time for a chance of dust or fluff settling on the paint.
I went into double figures for this level of coverage. A bit tedious but the results are worth it.
Perhaps a grey primer would have been better and not required as many layers?
Anyways, despite having double figures coats of paint all the detail is still perfectly crisp as the paint really shrinks back and levels out once the carrier has evaporated and/or flashed of. I also speeded each layer up with a hairdryer on a low setting.
Now for some pics. Tried to get a few different angles to catch the light and change the shade.
I think it looks pretty good. Nice and smooth at normal viewing distances.
Some of the close ups are a touch grainy but no acrylic NMF will withstand that much scrutiny.
On the undersides I went bold with the coverage when spraying to try and see how forgiving the paint is.
You can almost get one coat coverage of the black, but it required me to flood the surface that much that all the panel lines and rivets disappeared. Once it dried they all returned but the finish wasn't that great (as expected) so light coats and patience is definitely the way to go.
I am going to do another NMF with these soon, but may start with a lighter primer and do some colour variation using this aluminium again and then a few mixed darker shades with the 'cold rolled steel' (gunmetal) added to do a patchwork type finish.
Thanks for looking!
Gloss black stynylrez:
Mike    10,672
That looks promising... water based, eh?  Wonder how they stand up to tape?  I'm still looking for my holy grail, which is an alternative to Alclad, as I don't like the way they "go off" after a couple of year, going gritty and making spraying a total faff as you have to strain the paint first.  Seems more prevalent in the darker colours, and the darker they are, the worse the effect is.  I'd like to try these, and also the non-Alclad AMMO paints too, but you can imagine how much money's worth of Alclad I've got going off on my metallics shelves :crying:
Tony Oliver    3,578
Hi Mike, I can confirm they take tape fine, as not long after the wheels wells were masked off with tamiya tape (detacked on the back of the hand to be safe) and sprayed in a mixed light grey (from mission black and white)
The regular mission paints take tape perfectly too, see this here that I did earlier in the year that required loads and lots and then some more masking. Used their primary colours with my own mixed greys as this was when the paint first came out with an armour only range.
As to your curiosity over mig ammo metal acrylics, I dabbled with them
over Christmas...
Lastly, in your quest for an alclad replacement, another decent waterbased metal paint I would reccomend is Vallejo metal color. Not to be confused with their inferior model air metallics in regular 17ml bottles. These are the Dumpy 35ml bottle with black fliptop cap. Good range of shades, very fine finish, mix well with each other and regular model colour. Takes masking well also. Didn't rate their specific gloss black primer or metal varnish. I have a build in the cabinet (not the one below mind) that is still tacky today from that varnish.
Cheers, Tony
Mike    10,672
Now I didn't get on at all with these metallics.  They applied nicely, but lifted when I removed the masking :crying: The primer & varnish were bad too... In fact, it was the varnish that lifted, come to think of it :hmmm: Smells odd when you spray it. :hypnotised:  Maybe I need to try it with my favourite gloss varnish... just need to get 'em back from Julien is all :owww:
Tony Oliver    3,578
What's your Favourite? Here its alclad aquagloss or ak gauzy all the way. I tend to seal most metals before masking for all the smaller sprayed details anyways, protects the fragile finish from my sausages.
Perhaps you need to try vallejo metal color over stynylrez?
One point for me - ak gauzy only pre, not post, decals.
Mike    10,672
Favourites are Gauzy if it's not going to get sanded afterward as it's just so shiny and easy to apply, Alclad Aqua Gloss for barrier coats with some possible light sanding needed, but for areas that will need "proper" sanding such as around the carrier film of decals, it still has to be Klear.  I have a couple of bottles left, so I pick & choose what tasks I use it for to eke it out :)
NEVER try to sand Gauzy - that's its achilles heal. :owww:
Space Ranger    794
Why, oh why do people persist in using gloss black primer for natural metal finishes?? This is necessary ONLY for chrome and super shiny metallics. For a normal natural metal appearance as seen on most aircraft, it is NOT NECESSARY! A smooth gray primer will work, and so will the bare, unpainted plastic in many cases.
Duncan B    6,048
I now stock the Mission Models paints and have been really pleased with the results that I have had from the 'samples' that fell out of the rack and onto my desk. I haven't tried the metallic ones yet though as I can't see past the AK Xtreme Metallics for NMF paint jobs.
I have to say that the MM faded aluminium looks good on Tony's Mig so I might have to look at trying that out too.
Duncan B
Tony Oliver    3,578
Order made! Along with some other goodies ;)
Duncan B    6,048
Thanks Tony, they are in the Post so should be with you by Wednesday. Do show us how you get on with the RAF colours as I have only tried the Luftwaffe colours so far.
Duncan B
Gazontipede    38
At the risk of sounding heretical or just plain dense do you have any idea as to the suitability of these paints using ye olde hairy sticks?
Tony Oliver    3,578
Well I only brush small details not whole kits. I can say the normal colours do brush fine, the metals are a bit thinner so would need many coats. Haven't tried brushing these yet.
Wouldn't fancy brushing an NMF myself but nothing to stop you trying I suppose?
PS this plane is now complete, RFI here:
Gazontipede    38
Cheers for that! Having only recent experience with acrylics I've found the internet adage 'dilute to the consistency of skim milk and apply multiple coats' has worked quite well for me. So I may grab a bottle of one of these and give it a trial whirl.
I recently brush painted a 1/72 Airfix Spit 22 in the OOB NMF scheme as part of my relearning process and it doesn't look too terrible. (To the naked eye, I've yet to shove it under a macro-lens!)
The Mission Models paints have got rave reviews wherever I've looked and should, fingers crossed, be an improvement over the bog standard Tamiya colours I'm currently using.
What could possibly go wrong?? :wink:
Edited by Gazontipede
I can haz no grammar
