corsaircorp Posted August 27, 2017 Share Posted August 27, 2017 Hello Dears, I have a problem with my old faithfull Badger 150. The air coming from the compressor seem restrained somewhere. I dismantle the venturies, cleaned it all Bearing ok thoroughly cleansed. But still no power when turned on. May be the valve for air ??? If anyone has an idea ?? Thank for watching. Sincerely. Corsaircorp Link to comment Share on other sites More sharing options...
corsaircorp Posted August 27, 2017 Author Share Posted August 27, 2017 Here we go, I cleaned again, had the needle removed, blow with garage compressor but still the same ! Will look if there is a repair kit, or thing like that. Thanks Sincerely. CC Link to comment Share on other sites More sharing options...
Greg B Posted August 27, 2017 Share Posted August 27, 2017 This area of the forum (site help and support) quite clearly states in big red letters at the top of the page that it is not for modelling related issues. Please take the 30 seconds worth of consideration to determine where a post would be best suited to go in order to stop wasting moderator time.  I will now move the post.......  1 Link to comment Share on other sites More sharing options...
corsaircorp Posted August 28, 2017 Author Share Posted August 28, 2017 7 hours ago, Greg B said: This area of the forum (site help and support) quite clearly states in big red letters at the top of the page that it is not for modelling related issues. Please take the 30 seconds worth of consideration to determine where a post would be best suited to go in order to stop wasting moderator time.  I will now move the post.......  Hello Greg, Sorry for any inconvenience I may have caused. Feel free to move the post in adequate place. Have a good modelling day. Sincerely. Corsaircorp Link to comment Share on other sites More sharing options...
Drift Posted August 28, 2017 Share Posted August 28, 2017 8 hours ago, Greg B said: This area of the forum (site help and support) quite clearly states in big red letters at the top of the page that it is not for modelling related issues. Please take the 30 seconds worth of consideration to determine where a post would be best suited to go in order to stop wasting moderator time.  I will now move the post.......  Having a bad day Greg? Link to comment Share on other sites More sharing options...
Greg B Posted August 28, 2017 Share Posted August 28, 2017 2 hours ago, Drift said: Having a bad day Greg? Â Nope, having moved the nth post of the morning for the nth time that week sort of grates after approaching the first decade..... Link to comment Share on other sites More sharing options...
janneman36 Posted August 28, 2017 Share Posted August 28, 2017 (edited) 18 hours ago, corsaircorp said: Hello Dears, I have a problem with my old faithfull Badger 150. The air coming from the compressor seem restrained somewhere. I dismantle the venturies, cleaned it all Bearing ok thoroughly cleansed. But still no power when turned on. May be the valve for air ??? If anyone has an idea ?? Thank for watching. Sincerely. Corsaircorp It can be the valve or the trigger, you can remove the valve yourself.. I should try a new trigger as sometimes the inside of the trigger wears out together with the pin from the valve.. I had that once and is easy to fix!   Edited August 28, 2017 by janneman36 1 Link to comment Share on other sites More sharing options...
little-cars Posted August 28, 2017 Share Posted August 28, 2017 It can also be something more simple, like the air hole at the front of the brush getting clogged up with paint.  Take the air valve off the  brush, activate it to check that air is getting through and the air vale is working.  Then check that the air hole where the air valve screws in is not clogged. Then check that the air hole at the front of the brush is not clogged with paint.  Paul 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted August 28, 2017 Author Share Posted August 28, 2017 Thanks Janne Thanks Paul, Will try it tomorrow, finger crossed, some Ac are waiting in a queue at the painting booth ! I thank you again. sincerely. CC Link to comment Share on other sites More sharing options...
corsaircorp Posted August 30, 2017 Author Share Posted August 30, 2017 Hello Dears, I cleaned up every thing once again, will see tomorrow if it work ! So, I keep you in touch, seem that the needle has gone too far ahead. Thanks again. sincerely. CC Link to comment Share on other sites More sharing options...
