Spookytooth
Spitphoon 1/72 Airfix.
13 hours ago, The Spadgent said:
The spitfire looks great. Pitty about the scribing after filler. That always happens to me too, I’ve found if you scribe really lightly, do you have a Tamiya scriber? If not I can highly recommend them. Any way really light passes using dymo tape is the best way I’ve found. Or as you say not as all for a really smooth finish. Great save by the way. Looking forward to paint kid.
Johnny
Thank you Johnny, yes I do have and use a Tamiya scriber but the filler was slightly brittle and flaky , also I use Dymo tape as well.
23 hours ago, giemme said:
Alright, no scribing then :D Looking forward to proper paint :popcorn:  :wink:
Ciao
Sorry Giemme, but enough was enough with those bays.
On with the paint.
BG 1
BG 2
BG 3
MR Hobby Aqueous H334 Barley Gray first coat.
A nice semi gloss finish I think.
I am busy for the rest of the day so will try over weekend to get some more done.
All comments welcome.
Simon.
Agreed! :clap: Super smooth, I like it a lot! :thumbsup:
Ciao
Slump, looks like you did all the right stuff.
Never mind it all worked out in the end.
nice finish on that paintwork. :penguin:
Jont
Ciao
Thanks Giemme, it will be smoother now, see below.
Jont
As Giemme said , "talc and C/A is a good mix for scribing over.
The paintwork is getting there.
see below.
OK folks Barley Gray PT 2.
BG 4
Already for spraying.
BG 5
BG 6
The drop tanks and pylons rubbed down with 6000 M.M. the Typhoon got the same.
Drilled a 0.5 mm hole in each droptank/pylon and glued a bit of plastic rod in as a holding pin while spraying.
That`s if for now.
Hopefully will spray them all tomorrow (Sat).
Simon.
Indeed, she's looking very cool already :clap: Have a great WE :)
Ciao
Ciao
Thanks Giemme, we hope that you too have a great weekend.
OK, on with the Barley Gray.
BG 7
BG  8
BG 9
Leave those to dry.
Next up some Light Aircraft Gray H332.
LAG 1
LAG 2
I do like this MR Hobby Aqueous paint.
Anyhow, will leave those to dry and now chill out for a while.
Simon.
OK, so I did not chill out.
Instead I tackled the Spitfire.
Main U/C added.
FF 1
Tail wheel added, a p.i.t.a., really needed to sand down the locating peg.
FF 2
Exhausts added too.
FF 3
Leave to set, then a clean up before a satin varnish.
Now time to chill.
Simon.
I really, really love that Barley Grey tint on your Typhoon :clap: It looks smooth without looking like plastic, if you know what I mean.
Great job on the little Spitty too :thumbsup:
Ciao
Ciao
Cheers Giemme, the Barley Gray looks good.
As for the Spitfire well...
FF 4
FF 5
FF 6
FF 7
As you can see some spray bloom but in real view it`s not that bad.
But the canopy ....
FF 9
Disaster, numb nuts here did not mask some holes on the underside and spray residue pooled in the canopy..
And here is the underside .
FF 8
Oh well, just the prop to finish off tonight some when.
Simon.
Both are looking really smart Simon and you'll soon touch up those bits on the bottom (fnaar!) :)
I bet you could carefully prise that canopy off and clean it up, if you can be bothered... doesn't look that bad?
Cheers Ced, the canopy is staying on before I go and launch it across the room LOL.
It was totally my fault, should of block the holes up on the underside.
They are for the stand..
Anyhow, this morning I got on with the missiles.
M 1
White tips and dark grey fins so far.
Just a touch of black for the motor nozzles and the advanced aams a silver tip.
Simon.
Yay! Looking great. The spit canopy looks fine. I wouldn’t worry about it.
Johnners.
Johnners.
Thanks Johnny, I am not happy about it but WTF, it`s out the way now.
I will learn by my mistakes, I make too many.....
OK, on with the Typhoon.
The air inlet.
Fitted where it touched, a lot of filing and checking.
A I 2
A I 1
A dab of black at the back, then a splash of BG .
A I 4
A run of glue to fix.
A I 5
Filler needed here.
And a view from the front.
A I 6
i will leave that to set the attack it with some filler.
I knew that it was going to be a pita but it`s done for now.
Simon, contented after a plate of spag bol.
Cheers Johnny and Giemme.
Final pic of the day.
Filler added.
A I 7
Lit that harden over night and sand tomorrow.
Still have 2 more seams/joins to do but will wait until I have these sorted
Goodnight everybody.
Simon.
This kit is quite fighting you, but I like your approach :clap:
A bit more of patience and those intakes are going to be sorted :thumbsup:
So, is spag bol a slang for spaghetti bolognese? :D
Ciao
Thanks Johnny and Giorgio for the comments.
The filler.
A I 11
The sides though.
A I 9
A I 8
More filler and sanding but getting there...slowly LOL.
So you can see what I am up to today hopefully.
Simon.
Thanks Cookie, Benedikt and Giorgio.
After some more sanding and swearing, a coat of primer liberally brushed on.
A I 12
A I 13
AI 14
Well there are faults to rectify but getting there.
I will give it a sand tonight ( I have a friend visiting this afternoon,(Yes, I have a friend))
Then see what it looks like tomorrow.
Simon.
Getting there, Simon - getting there :clap:
Ciao
Rather than trying to scribe those pesky doors (I know you've given up on the idea) how about just drawing them on with a pencil?
That is not a bad idea sir.
Simon.
Thanks Johnny, Benedikt, Giemme and Big Dave.
Yet more sanding left me with this.
A I 16
A I 17
A I 18
And now for something a bit ugly...
Ughhhh
The Port one OK the Starboard one.... one of Airfix`s best!!!!!
As for the fit?
So so, the Starboard one is poor, the Port one OK.
I may be able to sort the Starboard one out but worried about the "fine engraving on it" .LOL
Simon.
PS Benedikt, I saw that clip before , made I laugh.
Well that exhaust..
A quick file sand and attack with a razor saw, plus a quick file I got to this.
Uggggh 1
Not brilliant but better than it was . ( Sorry for the blurred pic).
Will give that a coat of primer soon and see hoe it looks then
Simon.
