MigModeller
Tornado GR1A best 1/72 kit?
MigModeller    3
Hi All
Just discovered my Modeldecal sheet with 13 Squadron RAF Tornado markings (not roundels and fin stripes).  Only which is the most accurate kit?
I read that Revell has an inacurrate nose.  There are severl Airfix GR1s on that terrible online market.
Talking of noses and Airfix, a badly made MRCA is part of my loft insulation!
I hope my Modeldecal sheets of postwar RAF codes are still usable.
I look forward to your suggestions
M.M.
Hook    355
The RoG is still the best overall.
For a GR.1A, a combination of the ECR and GR.1 boxing would be the most suitable (and you can build a standard Tornado from the bits left.
HTH,
Andre
Richard E    615
I would suggest the Revell kit, it's possible to reshape the nose or there are some aftermarket alternatives available from your favourite on-line retailer; you will also need the IRLS (Infra Red Linescan) which fits under the nose: Freightdog include one in their Tornado GR Mk.4 update set; perhaps the other area of the Revell kit which needs some work is the nose gear which sits slightly too high.
MigModeller    3
HTH,
Andre
Hi Andre
Please might you elaborate on this?
I'm assuming the decals come from the GR.! and the nose from the ECR?
RoG stands for?
Nigel Bunker    251
RoG = Revell of Germany (as opposed to Revell USA).
Hook    355
Of course - you can use some of the ECR bits (cannon port plugs, underfuselage bulge) of the ECR kit with the RAF-specific bits from the GR.1 kit (RAF-style pylon fairings, fin ILS aerials, 2250 liter tanks,  Sky Shadow, RAF stencilling from the decals, etc.).
Andre
MigModeller    3
Thanks Andre
When you say "bits" the  ECR does not solve the nose shap problem then.  Or?  Which of the two provides the main source (fuselarge, wings) of the GR1A?
Nigel Bunker    251
To solve the nose problem, you'll need a resin replacement. Hannants have two on offer - here and here. This is not an exhaustive list - others may be available.
