PhantomBigStu Posted August 10, 2017 Share Posted August 10, 2017 (edited) Started the academy p-47d as the box scheme, assumed it was painted olive drab based on some builds I've depend but the instructions say it's medium green fs34092 ? Also what stores can I mount for authenticity? The box scheme is for the 78fg at dux in the autum of 44 Edited August 10, 2017 by PhantomBigStu Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted August 10, 2017 Share Posted August 10, 2017 (edited) Well P-47D's being the big brutes they are could carry quite a load. You dont mention theater, Squadron, or year. However some Nmf 9th AF P-47's in euope were repainted olive drab after they were moved to france and belgium in july '44. Sometimes medium green or RAF Dark green were substituted if stock ran low. They could carry pretty much everything from 100lb bombs to 500lb'rs on the centerline, & 1000 lb'rs on the wing rack. Though a standard load would usually be 3x500lb bombs on the centerline and on the wings. They also carried the early 3 tube bazooka rockets just outboard of the droptank/wing rack. Though i do not believe D's or at least the razorbacks or early bublletops could carry 5" HVAR Rockets later D's M's, and N's could. Most would carry at least one droptank on a mission mounted on the centerline. And unless this is very late '44 or early '45 dont mount the flat 200 gallon tank those werent around till the end of '44. A large group of P-47 squadrons kept the P-38 165 gallon drop-tanks when the switched over for the longer range. So those were seem on quite a few P-47D's. Now if this were other thestets such as mediterranean, pacific, or cbi you could see a variation on the above. Just remember in the Pacific/CBI Theaters Long distance's were more normal so drop tanks played a more prominent role. Hope this helps. Edited August 10, 2017 by Corsairfoxfouruncle Corrected/proof read 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 10, 2017 Author Share Posted August 10, 2017 Should have been more specific, on my phone but editird the post. Anyway the period is autumn of 44 and the unit is the 78fg at duxford Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted August 10, 2017 Share Posted August 10, 2017 (edited) 78th Fg was Long distance escort with 8th ftr command. Seconded to 2 Tactical air force for ground support as needed. Standard long distance escort load was three droptanks. Usually two 108 gallon paper or 165 P-38 drop tanks on wing stations and a third 108 paper or 110 gallon aluminum tank on centerline. The 200 gallon centerline tank would/could be used post oct'44. If in ground support mode go with the 9th air force loads in my first entry. You should be pretty sorted with those options. Dennis Edited August 10, 2017 by Corsairfoxfouruncle 1 Link to comment Share on other sites More sharing options...
JosephLalor Posted August 10, 2017 Share Posted August 10, 2017 There was a discussion about Eileen's colours on Britmodeller in 2013 It may have had RAF Dark Green uppersurfaces and either Sky or Medium Sea Grey undersurfaces 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 10, 2017 Author Share Posted August 10, 2017 Thanks guys I shall have a read later Link to comment Share on other sites More sharing options...
Tbolt Posted August 10, 2017 Share Posted August 10, 2017 (edited) 5 hours ago, Corsairfoxfouruncle said: Well P-47D's being the big brutes they are could carry quite a load. You dont mention theater, Squadron, or year. However some Nmf 9th AF P-47's in euope were repainted olive drab after they were moved to france and belgium in july '44. Sometimes medium green or RAF Dark green were substituted if stock ran low. They could carry pretty much everything from 100lb bombs to 2000lb's on the centerline. Though a standard load would usually be 3x500lb bombs or 1000 on the centerline and 500's on the wings. They also carried the early 3 tube bazooka rockets just outboard of the droptank/wing rack. Though i do not believe D's or at least the razorbacks or early bublletops could carry 5" HVAR Rockets later D's M's, and N's could. Most would carry at least one droptank on a mission mounted on the centerline. And unless this is very late '44 or early '45 dont mount the flat 200 gallon tank those werent around till the end of '44. A large group of P-47 squadrons kept the P-38 165 gallon drop-tanks when the switched over for the longer range. So those were seem on quite a few P-47D's. Now if this were other thestets such as mediterranean, pacific, or cbi you could see a variation on the above. Just remember in the Pacific/CBI Theaters Long distance's were more normal so drop tanks played a more prominent role. Hope this helps. 2000 lb? I don't think the P-47 could carry the 2000lb bomb, I'm not sure any fighter could, its a seriously big and heavy bomb. The largest bomb load I've ever seen on a Thunderbolt is 1000lbers on the wing pylons and a 500lb on the centerline, this was the max bomb load even on the P-47N. Edited August 10, 2017 by Tbolt Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted August 10, 2017 Share Posted August 10, 2017 Sorry typo on that 😱 ! I have big fat sausage fingers. I just didnt catch it when proof reading my entry. Thanks for pointing it out. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 10, 2017 Author Share Posted August 10, 2017 Thanks again guys, seems i will go with raf dark green and sky as the paint and fit the two bombs included on the wings. Link to comment Share on other sites More sharing options...
dfqweofekwpeweiop4 Posted August 11, 2017 Share Posted August 11, 2017 (edited) Don't use any rockets on it unless you find a pic of it or it's squadron mates (of the same time period) with them fitted. Without researching and seeing pics of the real thing, you'll be safe with 75 or 108 gal drop tanks on the wing pylons (or 500lb bombs) and either of the 2 previously mentioned drop tanks on the belly or the larger flat belly tank, or even nothing at all! If you fancy putting any other weapon fits on it, I would recommend doing some research if you're concerned about accuracy. That's what I do unless I see pics to show otherwise. For painting I would go for either Olive Drab/Neutral grey or RAF Dark Green over Medium Sea Grey. If they used RAF paints, they are the colours that would have been most likely lying around in that time scale, again unless you can find more than speculation as to them using anything else. Note the Academy kit's decals are pants, try and use aftermarket decals if you can. Also the Academy kit's landing legs are far too long, even for an unladen aircraft, any reduction you do in the landing gear length will improve the look of it. I'm sure I read that 2mm reduction is what you need. thanks Mike PS on some other points, the M models never carried rockets of any kind. They were only issued to the 56th FG who hated rockets, drop tanks or clean aircraft are best for M models, unless you see pics showing otherwise. I'm pretty sure the P-47's hardpoints were cleard for 1000lb's of ordnance, and that's the biggest bombs they carried. Edited August 11, 2017 by Mikemx 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted August 11, 2017 Author Share Posted August 11, 2017 Cheers @Mikemx though as seen in then photos on the thread linked earlier i do feel the underside should be sky as it looks just too light for medium sea grey. And will be mounting the two bombs in the box, with might even mount the centre tank though will have to cut the stand hole in it. Link to comment Share on other sites More sharing options...
