Hockeyboy76 Posted July 26, 2017 Share Posted July 26, 2017 Having been a brush painter all of my modelling life, I thought I would try this airbrushing lark. I have a 1/35 Tiger tank to paint so have bought an airbrush that runs off propellant canisters. I have set it up right according to what little instructions there were, thinned the paint ( Mig Ammo acrylics with Mig thinners at a 50/50 ratio, but when I push the airbrush I get a quick burst of air which then fades off to a constant stream but no paint. It only seems to go up the tube on the initial burst. The valve is fully open on the canister. I'm at a loss. Anybody have any ideas? Link to comment Share on other sites More sharing options...
Black Knight Posted July 26, 2017 Share Posted July 26, 2017 Loss of air pressure due to the can getting cold very quickly. Stand it in a jug of very warm - but NOT hot - water; that should help 1 Link to comment Share on other sites More sharing options...
mollythedog Posted July 26, 2017 Share Posted July 26, 2017 What BK says/ However,try spraying a small amount of water first=if it sprays ok you are good to go.If not you have a blockage somewhere. Sounds like a single action brush.siphon feed. You might want to consider adding Winsor and Newton flow improver. a drop or 2 will work wonders, but only when the head is clean and completely clear. No airbrush will work if clogged with paint and acrylics are notorious for doing this. HTH. mtd 1 Link to comment Share on other sites More sharing options...
