Sign in to follow this
ian buick
Which 72nd Sea King?
ian buick    147
Hi all
Appreciated the help with Falklands helos. I`m now asking the obvious follow-on which is; which Sea King kit/kits best represent both HAS.5 and HC.4 versions in1/72?
I know hee-haw about Sea Kings, I`m ashamed to say. Is there a kit that allows both versions to be produced, or do I have to go to two separate kits?
Cheers, Ian
tempestfan    340
The only HC. 4 I'm Aware of "in box" is the recent new Airfix tool. Not sure whether Revell did a 5 boxing, but they had a 6/AEW kit some years ago, and I think some People prefer the Revell kit over the Airfix even though the Revell is now some 20 years old.
Don McIntyre    313
I've not seen the newer Airfix or Revell kits, so can't comment on them, but I remember the Fujimi Sea King as being very nice. I don't know, either, if you can do an HC.4 from one. IIRC, for British Sea Kings there was a RN release (HAS.5?) and a RAF HAR.3. At one point I had both in the stash, but they've since been auctioned off.
cvrle    31
IIRC, the Sea King story...
Fujimi - very nice, a bit basic but a Sikorsky machine
Revell (newer one)  - very nice, but the sponsons a tad anemic, also need to be careful which boxing to get for a particular mark (Not all the boxings have all the bits)
Airfix - newsest, some feel the detail is not as good as the Revell one...
Cheers!
theplasticsurgeon    3,012
Try scalemates.com to find your Sea king versions.
Then peruse this GB from 2015 http://www.britmodeller.com/forums/index.php?/forum/504-sea-king-single-type-group-build/
to see if anyone has built it.
Following photobucket, I doubt many photos are in there, but you'll get a flavour from the comments.
andyf117    656
The question's been asked before, with various preferences being expressed - mine is for the Revell kit, which I've used for five completed builds so far, with many to go!
Straight from the box, there is really only the Airfix for an HC.4 (the CyberHobby kit is way too expensive, and less accurate) - but I'll be converting from Revell.
This old thread of mine shows the basic mods needed for most RN versions:
http://www.britmodeller.com/forums/index.php?/topic/234975759-rn-har5-172-revell-cat1/
Most equally apply to the Airfix HAR.3 kit, which is being built as a HU.5 in Dads203 thread:
http://www.britmodeller.com/forums/index.php?/topic/235023572-westland-sea-king-hasr-5/
Though marketed as an HAS.6, the Revell actually better represents a 5 (the 6 had a longer generator bulge) - both of the later Mk.41 boxings (Sea Skua or 45th Anniversary) contain the additional sprue with all the necessary RN HAS parts.
At the end of the day, availability may dictate what you end up building - the Airfix kits are on the shelves, the Revell ones have to be found, but do come up fairly often on eBay.
Procopius    16,795
I've heard the Revell sponsons are too small -- is there a correction for this?
Harry Lime    520
Yes, resin ones available from Whirlybird.
Mark.
Dads203    3,826
I'm building the Airfix HAR3 converting it to a RN cab and I think it's cracking kit, I have two of the Revell kits and two of the Cyberhobby Sea King kits and i must say I prefer the Airfix versions but that's my preference.
Each company has its own merits on the kits that they produce so I can only advise on my experience, the Revell boxings would be a close second though :)
Dan
Ex-FAAWAFU    10,290
I'd second the praise for the new tool Airfix kit.  I was given an HAR3 by a well-meaning friend who knows little about RAF / RN differences ("you flew SAR, so this was your aircraft, no?..."), and I used it as one of many inputs to the drawings I did to correct the more egregious errors in Caruana's [see my 1/48 HAS5 build for details].  Of all the kits I used, the Airfix one had the fewest errors.
Shame it's not my scale, really - but it looks a good kit.
Des    145
Back when Revell originally released their Royal Navy variant kit I contacted them to ask if they were considering a re-release with the necessary parts to release it as an HC.4 and was told in reply that initially the plan had been to include these as an option in the original kit but it had quickly become apparent that the tooling required to do so would have made the kit prohibitively expensive.
Ex-FAAWAFU    10,290
That's not surprising; there are a LOT of differences between the HC4 and the various RN ASW versions (and AEW, which were originally based on HAS2s).  The HAR3 is actually the closest cousin go the HC4 - which probably partly explains Airfix's choice of marks.
Dave Fleming    1,349
It's not just the sponsons, compared side by side along with photos of the real thing, there are a lot more 'correct' shapes on the Airfix kit compared to the Revell. And I still have 8 Revell kits in the stash!
andyf117    656
In the 'Mystery of the Missing Parts' discussed here, the HC.4 was suggested as a possible explanation:
http://www.britmodeller.com/forums/index.php?/topic/234952365-revells-172-sea-king-kits-the-mystery-of-the-missing-parts/
Seahawk    1,168
Though I hope you will agree that the sandbox filter on the AX kit is a major disappointment.  Still, never mind: build an early one with the barn-door FOD guard instead.
Des    145
Thanks for pointing that out , very interesting indeed.
I had a look at the parts plan on an old set of instructions this morning and it looks very much that with so many ASW/AEW parts such as the undercarriage for example distributed across existing sprues of common parts not only was the cost of additional HC.4 parts too high in the original kit but the later substitution of a type specific sprue would have been impossible for the same reason.
Some time later when the Diecast Helicopter Collection was released in the UK I did acquire a couple of their introductory HC.4 models at £1.99 each with the intention of sawing relevant parts such as the undercarriage off to attempt a conversion of the Revell kit but never found the time to try it.
andyf117    656
I had exactly the same thing in mind, and got a few of the die-casts later via eBay - but the only really useable parts are the inflation bottles, flotation cans and undercarriage fairings. The stub wings are too small, and the struts too thick - the cockpit glazing and sawn-off lower nose, however, can be used to replace the equivalent areas of the old Airfix kit and/or the Aurora HH-3 Jolly Green Giant.....
Des    145
 Very reassuring to see that I am not the only one who gets these ideas.
