DaveJL Posted July 24, 2017 Share Posted July 24, 2017 Hello all, Here is my first entry for this GB - Revell's 1/48 F-15E marked as 89-0487 from the 335th Fighter Squadron, during Operation Inherent Resolve in 2016. This jet has the distinction of getting the F-15E's only air to air kill, dropping a GBU-10 on an Iraqi Mi-24 in February 1991. It is also the only F-15E to date to have logged 10,000 hours of flying time. Kit (hiding in an Academy box): I'll be using a lot of parts from a left over Academy kit - Sniper pod, antennae etc. Extras: Authentic Decals, Pavla seats and Eduard Small Diameter Bombs. I'll be loading the jet with the SBD down the centre line, 3x GBU-38's, 4x GBU-12's, 3x AIM-120's, 1x AIM-9 and 2x fuel tanks. All armament, bar the SBDs, will be from the Academy kit. This load is based on several images i've seen online: 3x AIM-120 GBU-12 - 7th picture down SBD on the centre line The last picture above will be what i'll base my weathering on. Looking forward to this one. Dave 3 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted July 24, 2017 Share Posted July 24, 2017 Welcome aboard, good subject choice Link to comment Share on other sites More sharing options...
DaveJL Posted July 24, 2017 Author Share Posted July 24, 2017 Cheers! Link to comment Share on other sites More sharing options...
snapper_city Posted July 26, 2017 Share Posted July 26, 2017 Link to comment Share on other sites More sharing options...
Shaun Posted August 5, 2017 Share Posted August 5, 2017 Nice project Dave.. Link to comment Share on other sites More sharing options...
DaveJL Posted August 5, 2017 Author Share Posted August 5, 2017 Cheers Shaun. Made a brief start by building up all the ordnance, tanks and Sniper pod. Everything bar the tanks and GBU-39s are from the Academy kit: The lovely Eduard GBU-39s: More soon. Dave 4 Link to comment Share on other sites More sharing options...
Tim Moff Posted August 20, 2017 Share Posted August 20, 2017 On 8/5/2017 at 8:16 PM, DaveJL said: Cheers Shaun. Made a brief start by building up all the ordnance, tanks and Sniper pod. Everything bar the tanks and GBU-39s are from the Academy kit: The lovely Eduard GBU-39s: More soon. Dave Looking good Dave - doing the same with my 2 x 'K' and 'M' Sprues from the Academy kit.....still after a GBU10 for my F111F!!! Link to comment Share on other sites More sharing options...
DaveJL Posted August 23, 2017 Author Share Posted August 23, 2017 On 20/08/2017 at 9:01 PM, Tim Moff said: Looking good Dave - doing the same with my 2 x 'K' and 'M' Sprues from the Academy kit.....still after a GBU10 for my F111F!!! Cheers Tim. Should have some more progress soon. I may have a GBU-10 somewhere. Will have a check when i'm next at the bench. Link to comment Share on other sites More sharing options...
Tim Moff Posted August 24, 2017 Share Posted August 24, 2017 cheers, Just realised that my in-flight option is flawed....intakes for non running engines only? any top tips? Link to comment Share on other sites More sharing options...
DaveJL Posted August 28, 2017 Author Share Posted August 28, 2017 On 24/08/2017 at 10:19 PM, Tim Moff said: cheers, Just realised that my in-flight option is flawed....intakes for non running engines only? any top tips? Wasn't aware of that mate, the intake ramps look like they would be manipulated to allow the intakes themselves to be adjusted. Back to this build, and i've done a bit more, a bit off the track from the instructions, but the main fuselage is assembled: The dark grey plastic is the Sniper pylon from the Academy kit. I also dropped the ailerons a bit, as this seems to be the norm for jets on the ground. A sharp blade along the edges of the part sorted it. Only a dab of filler has been required thus far, though i'll need a drop more on the joins of the outer part of the wings. The general fit is excellent, if only all Revell kits were like this! Pylons built up, with launch rails from the Academy kit: Won't be back to the bench for close to 2 weeks, due to work, a wedding and a trip to Ukraine. Dave 2 Link to comment Share on other sites More sharing options...
madcat911 Posted August 29, 2017 Share Posted August 29, 2017 Nice work so far. However I suspect you have installed the missile launch rails on the wing pylons too far aft. Mark Link to comment Share on other sites More sharing options...
DaveJL Posted August 29, 2017 Author Share Posted August 29, 2017 9 hours ago, madcat911 said: Nice work so far. However I suspect you have installed the missile launch rails on the wing pylons too far aft. Mark Good spot, thanks Mark. Looks like I filled the wrong locating hole. Luckily they've been easily moved. 1 Link to comment Share on other sites More sharing options...
Hewy Posted August 29, 2017 Share Posted August 29, 2017 got the majority together well dave ,a slight correction on the pylons shouldn't pose you too much trouble, glynn Link to comment Share on other sites More sharing options...
DaveJL Posted August 29, 2017 Author Share Posted August 29, 2017 1 hour ago, Hewy said: got the majority together well dave ,a slight correction on the pylons shouldn't pose you too much trouble, glynn Thanks Glynn - pylons fixed and all! Link to comment Share on other sites More sharing options...
DaveJL Posted September 10, 2017 Author Share Posted September 10, 2017 Slow progress on this one. Having a bit of a modelling blip these last few weeks. Anyway, main fuselage cleaned up and GPS dome added: As brilliant as the Revell kit is, I always seem to need some filler at the join of the 2 wing portions. Not too much of an issue. Cockpit was build up, painted, detailed and given a light wash: Same for the front landing gear bay: Front fuselage closed up: Be a few days before I get back to the bench. Hope I can get both entries done at this rate. More soon. Dave 3 Link to comment Share on other sites More sharing options...
Tim Moff Posted September 19, 2017 Share Posted September 19, 2017 On 10/09/2017 at 5:08 PM, DaveJL said: Slow progress on this one. Having a bit of a modelling blip these last few weeks. Anyway, main fuselage cleaned up and GPS dome added: As brilliant as the Revell kit is, I always seem to need some filler at the join of the 2 wing portions. Not too much of an issue. Cockpit was build up, painted, detailed and given a light wash: Same for the front landing gear bay: Front fuselage closed up: Be a few days before I get back to the bench. Hope I can get both entries done at this rate. More soon. Dave Good work. Is the dome to the starboard in front of the engine hump/1/2 down opposite the speed brake? Is this for E models only and painted off white? Do the C models have it behind the grill behind the cockpit - white circular area or is it the same place as the E? Link to comment Share on other sites More sharing options...
DaveJL Posted September 19, 2017 Author Share Posted September 19, 2017 1 hour ago, Tim Moff said: Good work. Is the dome to the starboard in front of the engine hump/1/2 down opposite the speed brake? Is this for E models only and painted off white? Do the C models have it behind the grill behind the cockpit - white circular area or is it the same place as the E? As far as i'm aware mate the GPS dome is in the same location on the C and E. The circle behind the vents just aft of the canopy is also appearing on the E model. https://i.ytimg.com/vi/IBD9j_fHAvY/maxresdefault.jpg http://images04.military.com/media/news/equipment/f-15e-strike-eagle-1800-ts600.jpg No idea what it is though! Dave 1 Link to comment Share on other sites More sharing options...
DaveJL Posted September 20, 2017 Author Share Posted September 20, 2017 More done and i'm finally getting back in the grove! Most of the assembly is now complete. Any minor areas of filler were cleaned up, the forward antennae (updated examples from the Academy kit), CFTs and pylons added and the Eduard GBU-39 launcher/pylon added. Just a small bit of filler to clean up around the CFT/intake join and then it's ready for priming. More soon. Dave 3 Link to comment Share on other sites More sharing options...
crushkill Posted September 20, 2017 Share Posted September 20, 2017 Looking forward to seeing this one finished, that weathering your aiming for is beautifully ugly, like any working aircraft should be. I can't wait to see how you pull it off! Link to comment Share on other sites More sharing options...
DaveJL Posted September 20, 2017 Author Share Posted September 20, 2017 1 hour ago, crushkill said: Looking forward to seeing this one finished, that weathering your aiming for is beautifully ugly, like any working aircraft should be. I can't wait to see how you pull it off! Cheers! I'm not sure at the minute how i'm going to accomplish the weathering! Link to comment Share on other sites More sharing options...
crushkill Posted September 20, 2017 Share Posted September 20, 2017 11 minutes ago, DaveJL said: Cheers! I'm not sure at the minute how i'm going to accomplish the weathering! Looks like condensation, but it also reminds me a lot of oil with dust in it. If you look at images of humvees or tracked vehicles in Iraq you can see it all over them (especially around turrets or engines). I would use try mixing some pigment with like a small (think one drop) of baby oil. Test it out on another kit first though. The hard part would be getting a clear cost over it that shows the "wet" nature of it Link to comment Share on other sites More sharing options...
DaveJL Posted September 20, 2017 Author Share Posted September 20, 2017 Thanks for the tips, i'll try and work something! Link to comment Share on other sites More sharing options...
Tim Moff Posted September 24, 2017 Share Posted September 24, 2017 Good shout on the under nose Ae's....will need to sort mine from the C/E Academy kits I have. Looks a good clean build! Link to comment Share on other sites More sharing options...
DaveJL Posted September 25, 2017 Author Share Posted September 25, 2017 Cheers Tim. Link to comment Share on other sites More sharing options...
DaveJL Posted September 26, 2017 Author Share Posted September 26, 2017 Painting is well underway. I got sidetracked from the main airframe and painted the majority of sub assemblies. Ordnance first: All with decals and panel wash added (bar the fuel tanks). Seats: Exhaust petals started. Sprayed white then weathered with Tamiya pigments: Airframe next. Dave 5 Link to comment Share on other sites More sharing options...
