Shar2 Posted July 23, 2017 Share Posted July 23, 2017 French Pre-Dreadnought Danton Gun Set 1:350 Master Models A new month and a new set of barrels as Master models continue to build up their range of 1:350 scale armament sets. This set is for the recently released Hobbyboss French pre-dreadnought battleship Danton. As usual they are well up to the standard we’ve come to expect from Master Models. [350-097] The guns in the kit are pretty good for injection moulded parts, but you can’t beat some finely machine turned brass barrels to add that extra finesse to the model. In this set you get four 305mm aluminium barrels, twelve 240mm aluminium barrels, sixteen 75mm brass barrels and twelve 47mm brass barrels. The set also includes six resin trunnion mounts for the 240mm barrels and two for the 305mm barrels. These replace the trunnions in the kit. You will need to cut the kit barrels from the 75mm and 47mm mountings and drill appropriate sized holes both 0.5” and 0.3”. Conclusion Master models just amaze me how they continue to churn these sets out and keep the quality so high, just what you need to give your model a lift. Review sample courtesy of Piotr at 2 Link to comment Share on other sites More sharing options...
