Sign in to follow this
Shar2
Triple Ejection Racks. 1:32
1:32 Eduard/Brassin
(632-103) – Triple Ejector Racks or TER for short, are used in conjunction with a pylon and enable aircraft to carry multiple GP bombs such as Mk81/ Mk82, cluster bombs, LGB and others. It is also capable of carrying and firing rocket launchers such as LAU-68, LAU-131 and flare launchers such as SUU-25. Maximum load capacity for a TER it is 3000 lbs.
TER uses three ejector release units (ERUs) which hold and enable release of stores. The ERUs are located in two groups of three : one aft and one forward, symmetrically arranged about the centerline and at 45 degrees at either side
Each ERU holds the store by means of two suspension hooks placed at 14 in (std NATO) and also by a pair of sway brace pads which provide steady captive flight. Each ERU uses one or more impulse cartridges which enable safe separation of stores.
The five TER’s come in the standard Brassin cardboard box, well protected by foam pads inside.  They are really well detailed, as we have come to expect from Eduard and certainly have more finesse than injection moulded items. Before assembly each TER will need to have certain holes drilled out with a 0.4mm drill. Each TER is assembled with the addition of the two suspension hooks, check references for where they are fitted on the rail, three ejector racks and six crutch pads. The modeller has to supply the 0.4mm wire to attach between the ejector racks and the TER main body. There is a small etched disc glued to the rear of the TER to complete the assembly.
Conclusion
Eduard/Brassin keep churning out these products every month, but with no loss of detail.  These items will look great fitted to which ever large scale fighter/bomber you are building.
Review sample courtesy of
