robw_uk
1/35 Eduard m4
Placeholder for my next build.... Eduard M4. Building OOB for a GB elsewhere. Should start later this week work permitting
Started, pics later... So far so good
Progress. So far so good. Side applique armour needs to be adjusted so have taken it off.... Enjoying the build but the suspension has me a tad worried....
36074618946_ca0b09efc7_z.jpgIMG_20170721_174330 by Robert Worth, on Flickr
36116224345_552fffbe61_z.jpgIMG_20170722_170255 by Robert Worth, on Flickr
35308083793_9a10d0b589_z.jpgIMG_20170722_174341 by Robert Worth, on Flickr
35308082823_8bd66d5ea7_z.jpgIMG_20170722_170305 by Robert Worth, on Flickr
36116200405_261c08437f_z.jpgIMG_20170722_174354 by Robert Worth, on Flickr
2 minutes ago, BruceG said:
Suspension isn't too bad to do, but do it one unit at a time. Big piles of bits just makes it confusing!
Yeah, did on the easy-8 and the M10.....
Asuka suspension is little complicate, but this is the best Shermans on the market.
Hi Rob. Definitely interested to see this one in progress. I've got one in the stash so I'm going to bookmark your thread. Looking good so far. :thumbsup:
Kind regards,
Stix
Hi Rob,
Looking good. Not you, the Sherman!  Well, as good as an ugly Sherman can be said to be looking good anyway. I prefer the look of the Shermans with the flat upper hulls and all the angles.
I also will bookmark.
Rearguards,
Badder
Nice progress Rob, are you depicting it as a British or a US tank? I normally find the running gear a bit of a chore, but for some reason I like how the Tasca bogies build up.
Cheers Ozzy. Going with "Goldie" markings. US 66th armoured from June 44
need to get back to this now christmas is done...
mojo returned. some fiddly PE sorted that out ;-). coming on, just some small additions then i will start 2018 with painting
39409934151_69093a282b_z.jpgIMG_20171231_160414 by Robert Worth, on Flickr
39379901642_538891def8_z.jpgIMG_20171231_160405 by Robert Worth, on Flickr
38701641524_a3cfec24d1_z.jpgIMG_20171231_160425 by Robert Worth, on Flickr
Good to see some progress on this one Rob. I've now got mine underway in the Sherman STGB.
Kind regards,
Stix
think this is build done. going to leave th MG without an ammo box. wheels left off for ease of painting and I am adding the hedge cutter that was in the kit but no instructions (got them off the internet)
38575138125_6cd61e9088_z.jpgIMG_20180102_165357 by Robert Worth, on Flickr
27676499069_2b838a795d_z.jpgIMG_20180102_165340 by Robert Worth, on Flickr
24587631257_aabb2f4739_z.jpgIMG_20180102_165413 by Robert Worth, on Flickr
so next stop, painting... going to try the B&W method I think
Nice assembly rob that 50 cal looks great, theres a really well molded one in the calliope kit I'm doing in the gb, i know they didn't use them but im gonna build it anyway  as a little mini kit, look forward to the painting
Glynn
Glynn
thanks Glynn....
B&W pre-shading and then AK Interactive Light OD Base... for once i didnt go too overboard but i need to do something about my airbrushes.... not flowing properly even after full clean (mind the H&S does have a crack in the nozzle so needs replacing)
27776067739_ded2f52240_z.jpgIMG_20180107_090511 by Robert Worth, on Flickr
25681812018_bc55e5ff14_z.jpgIMG_20180107_090502 by Robert Worth, on Flickr
24684731367_2cee177794_z.jpgIMG_20180107_090458 by Robert Worth, on Flickr
24684731907_7f3e668c0c_z.jpgIMG_20180107_090440 by Robert Worth, on Flickr
38843184384_9ef35993b0_z.jpgIMG_20180107_090430 by Robert Worth, on Flickr
Fine looking painting
Edited by Hewy
Spelling
Looks good, hope after oils do not go too dark.
Just in case do not forget that this bar next to the pick head it is handle for it - not a metal bar.
decals on... not sure if i am going to weather this one. will have to see once the detail painting is done
25796858798_32697dd3ef_z.jpgIMG_20180113_164958 by Robert Worth, on Flickr
24799938677_b5818b6063_z.jpgIMG_20180113_165021 by Robert Worth, on Flickr
38771613195_7f77d147b9_z.jpgIMG_20180113_165008 by Robert Worth, on Flickr
39638261972_0dd2fb1c8a_z.jpgIMG_20180113_165036 by Robert Worth, on Flickr
14 hours ago, Ozzy said:
Nice job Robert.
thanks Ozzy....
Edited by robw_uk
Matt varnish applied. am still thinking no weathering on this - just the modulated paint. but who knows
27908911529_96b09f2efc_z.jpgIMG_20180114_161316 by Robert Worth, on Flickr
25815349548_fc2dc37373_z.jpgIMG_20180114_161302 by Robert Worth, on Flickr
24818612297_a0e74515a5_z.jpgIMG_20180114_161252 by Robert Worth, on Flickr
38789790305_38a9d69af2_z.jpgIMG_20180114_161322 by Robert Worth, on Flickr
That Matt varnish worked really well Robert, which brand of varnish did you use?
cheers ozzy.... after trial and error on a few brands i now use Windsor & Newton Galleria acrylic matt varnish. Sprays unthinned, no whitening, can be brushed straight from the bottle.... cant recommend it highly enough
