Airfix Westland Sea King HU5
Cheers chaps :D
its going to take a while to plumb in the hub the hub and all the bits and pieces, it was one area that I wasn't going to go to far with but I do think that it adds to the hub assembly.  It's going to drive me crackers I fear as getting the small brass wire to stick with CA glue is a real pain and a bit hit and miss. As not to overload myself I've done more to the main fuselage exterior and I've also painted the pilots and co pilots seats, photos later.
I think I'll leave the pitch links for the moment they were a bit of a mare to get in place as I used some plastic stock which isn't polystyrene, I had a few problems getting it to stick, it's now really stuck fast with thick CA glue and other adhesives
Thank you all for the comments and likes :thumbsup2:
Dan
So a quick check of the crew and seating in the front office , seats painted up
and I see I have a bit more work in getting the guys sitting right, I'll add the belts from the seats
with lead foil once its all painted and glued up, I need to get the controls fitted correctly into the pilots hands.
Now would the whole cockpit be painted black for this cab?  I know they went through the NVG upgrade
so I reckon the floor and rear bulkhead would also be black?
More later
Dan
  • Like 10
Adding more detail, the sea tray outside parts done with Green Stuff,
Added the seat cushions for the radar ops position as no crew figure will be used on this seat.
enjoy
Dan
Pretty much everything ahead of the Broom Cupboard was black on an NVG cab - which, conveniently, is where your moulded detail extends to.  The rear of the Broom Cupboard might well have been grey.
Left hand seat & floor:
Looking up & back, including Broom Cupboard:
Hope that helps.
Crisp
Cheers Crisp, that's a real great help, I now know what to paint and not paint black, cracking photo's btw :D
Adding the small missing details to the sponsons, not sure what they are but I've used .3 lead wire, slightly overscale
but with some paint should look okay. Some foil used as the brackets, these seem to be fitted to all the RN cabs.
Dan
Started on the Radar kit, added the mushroom anti vibration mounts
and the start of the trestle table that it sits on. Just the table now to build and finish off the operators seat
and it should be ready for paint.
Enjoy
Dan
That's a very good piece of moulding on ?Revell's part; it represents the Observer's station of a Sea King sufficiently clearly that even a front-seater can identify it.  Even the Master Compass is clearly visible.
How are you planning to colour the radar screen?
Edited by Ex-FAAWAFU
And  my next question is " what colour would the screen be ?"
:D
Hi,
I'm glad things have improved a little and you're doing a fantstic job on this model!
Those guys are really lively and all the additions you're doing are improving a lot the models quality!
I'll keep an eye on thes topic!!!:yes:
A bit more test fitting and details added. Crisp, that photo is brilliant fella, really shows off the area well.
Just got to decide on how far to take it :huh:
Cheers for looking
Dan
A bit more work on the Radar Ops seat, added the seat rails , seat belt fittings and primed, paint next and then add some PE belts,
Started on the smoke float racking, not strictly accurate as the rack should be slightly angled up
but it will do for me.
Cheers for looking
Dan
Thank  you chaps :yes:
Decided to redo the pilots and co pilots seat, the figures didn't really look right
so I added thicker cushions and then pushed the figures into place. I'll wait for the putty to dry
and repaint. I also started painting up the life raft that will go inside the main crew door.
Work is still on going on the Radar consul at the moment and I should get the trestle table done today.
Enjoy
Dan
Just been mucking about with the winch,  needs some rivets adding to the housing yet
but I've added the spring thing to the hook assembly and reshaped the hook to look better,
added the locking bar to it as well so the crewman doesn't fall off the ook !
On the fuselage side next to the mounting I've added the connectors for the plumbing and
the hole for the missing support bar to the winch.
Not much progress as I've had other things going on but a step closer
to bringing up the kit to my standards.
Dan
