Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      PhotoBucket are no longer permitting 3rd party hosting   01/07/17
      As most of you are now painfully aware, Photobucket (PB) are stopping/have stopped allowing their members to link their accumulated years of photos into forums and the like, which they call 3rd party linking.  You can give them a non-refundable $399 a year to allow links, but I doubt that many will be rushing to take them up on that offer.  If you've previously paid them for the Pro account, it looks like you've got until your renewal to find another place to host your files, but you too will be subject to this ban unless you fork over a lot of cash.   PB seem to be making a concerted move to another type of customer, having been the butt of much displeasure over the years of a constantly worsening user interface, sloth and advertising pop-ups, with the result that they clearly don't give a hoot about the free members anymore.  If you don't have web space included in your internet package, you need to start looking for another photo host, but choose carefully, as some may follow suit and ditch their "free" members at some point.  The lesson there is keep local backups on your hard drive of everything you upload, so you can walk away if the same thing happens.   There's a thread on the subject here, so please use that to curse them, look for solutions or generall grouse about their mental capacity.   Not a nice situation for the forum users that hosted all their photos there, and there will now be a host of useless threads that relied heavily on photos from PB, but as there's not much we can do other than petition for a more equitable solution, I suggest we make the best of what we have and move on.  One thing is for certain.  It won't win them any friends, but they may not care at this point.    Mike.
Sign in to follow this
Followers 0
Julien
Revell
Fw 190D-9 - 1:48 Revell
Fw 190D-9
1:48 Revell
The Fw.190 was designed by Kurt Tank, and initially gave the RAF a bit of a fright when it first appeared. The D, or Dora, was often known as the "Long nose" due to the elongated nose cowling to accommodate the liquid cooled Jumo 213A engine. It came into production in late 1944, and over 1800 examples were manufactured before the end of the war.
The Kit
Even though this is a Revell box the plastic inside is from Eduard. There are 5 sprues of grey plastic, one clear sprure and a small decal sheet. Construction starts with the cockpit. Instrument panels sides are added to the cockpit tub along with the control colum, side parts and then the main instrument panel. The seat is added along with the rudder pedals.
Forward of the cockpit is the nose machine gun bay, which can be detailed with a large number of parts if it is to be left open, or with the omission of the MGs and their ammo boxes, the bay can be closed up with the use of a pair of MG stubs that glue into the bay cover. As the engine ancillary units (including the super-charger and engine mounts) are in the same bay as the MGs, it may be as well to leave open the MG bay, to show off the nicely rendered parts.
The main part of the engine is not depicted in this kit, but the exhaust stacks are mounted from the inside of the fuselage in their own boxes, and are held in place by the front bulkhead of the MG bay. The detailer will need to open up the exhaust stubs to add a little realism here. Once these are installed, the modeller can close up the fuselage.
The wing underside is a single piece unit, with a long spar running along the back of the landing gear bay, to which additional ribs are added to detail the gear bays themselves. The wing mounted cannons go through the bays here, and must be added at this point due to their tapering shape. It may be wise to chop off the last section and replace it later in the build with a piece of fine tubing if you are a tad clumsy like this reviewer. The upper halves of the wings can have the cannon bays left open to expose the breeches of the 151/20 cannons, or if left closed, a blanking section can be substituted. The flaps are moulded integrally, but the flying surfaces can be posed at an angle to give a little extra visual interest, and are added after the wing halves are joined. The whole wing is then offered up to the underside of the fuselage, so plenty of test fitting would be sensible here.
The rear empennage is standard, irrespective of which tail you have opted for, and the rudder is pose able, while the horizontal tails fit to the fuselage with a large attachment tab, so should stay horizontal with very little trouble. The landing gear on the 190 is long and canted in slightly, which is shown by the helpful diagram, and the modeller has a choice of two wheel types here with either smooth or treaded tyres. The wheels themselves should be installed at an 8o angle to the oleo strut, which would be fun to measure, if it weren't for the 1:1 scale drawing that is provided - good idea, Eduard! The retraction jacks fix within the bay to large contact points, so a strong landing gear should be the result.
The modeller can choose to pose the cowling flaps open or closed, which are provided as separate rings that slot in behind the main cowling onto a large cylindrical spacer. The super-charger intake is installed at this point, as are the gun troughs on the forward fuselage. The nose gun bay cover is installed, along with the wing mounted gun bay covers, which if modelled closed, receive a nice set of PE piano type hinges once installed.
Although the clear sprue includes four canopies, only two are actually used, with the choice being open or closed. The head-rest & armour is installed in the canopy, as well as a tiny PE grab handle, and a standard windscreen mounts over the coaming to complete construction, other than choosing to mount a bomb or fuel tank on the centre line pylon.
Decals
The smallish sheet is printed in Italy for Revell and should pose no problems. As it is Revell no swastikas are provided. There are two decal options provided;
Werk Nr 500666, II./JG 301, Erfurt-Nord, May 1945
Werk Nr 210194, I./JG 2, Aachen, 1 January 1945
Conclusion
Quality plastic from Eduard, and quality decals from Revell so you cant go wrong.
Revell model kits are available from all good toy and model retailers.
For further information visit logo-revell-2009.gif t_logo-a.png or facebook.gif
3 people like this
Followers 0
