Aerofix Posted June 22, 2017 Share Posted June 22, 2017 Any idea where I can source water slide decal sheet 1/72 or 1/48 of the above please? Preferably grey and in this country but all options considered! Link to comment Share on other sites More sharing options...
Benson Posted June 22, 2017 Share Posted June 22, 2017 Any particular aircraft? Link to comment Share on other sites More sharing options...
Aerofix Posted June 22, 2017 Author Share Posted June 22, 2017 Thanks for getting back. no particular aircraft, just a generic sheet which can be cut up. I'm probably thick but I don't quite get your reply! Cheers David Link to comment Share on other sites More sharing options...
Black Knight Posted June 22, 2017 Share Posted June 22, 2017 3 hours ago, Benson said: Any particular aircraft? Because the digital camo is not generic; its designed to a specific aircraft type, eg the digital on an F18 has not the same patterns as would be seen on an F15 Link to comment Share on other sites More sharing options...
Muzz Posted June 22, 2017 Share Posted June 22, 2017 You won't get a set of generic digital camo decals, as stated above they will be aircraft specific. You will more than likely get sheets of single coloured decals or stripes of various thickness which could be cut up but the colours will be a problem. Paint and masking tape is probably the better option. Link to comment Share on other sites More sharing options...
chris57 Posted June 23, 2017 Share Posted June 23, 2017 Aerofix Try googling AnarchyModels, in my travels I picked up a generic set of mini digi camo stencils which may help you out. The sheet number I have is 0019 and I was hopeful one day of using it on a Mil 17 the Peruvian AF took delivery of(since been crashed). The sheet is primarily intended for use with air brushing. hth cheers Chris Link to comment Share on other sites More sharing options...
Aerofix Posted June 23, 2017 Author Share Posted June 23, 2017 Much obliged everyone - as usual! Link to comment Share on other sites More sharing options...
