Old Man    1,446
I don't mind confessing this step nearly bounced me off the project, and even now I am still considering improvements that might make the contriving of spoke wheels a more regular process with a smaller ratio of failures to acceptable outcomes. But I have got enough of the bugs out to present a method which can produce acceptable results.
The method is derived from routines presented by the late Harry Woodman, master scratch-builder, whose book is available on-line, and highly recommended....
http://rclibrary.co.uk/files_titles/1216/ScaleModelAircraft_Woodman.pdf
But his method was meant for 1/48 scale work, and probably (though this is not clearly stated) employed waxed sewing thread for spokes. Adjustments have to be made for work at a smaller scale, and employing monofilament ('invisible thread') for the spokes.
The basics remain the same: two circles pressed together to make a wheel, sandwiching between them a spacer representing the axle, and a pattern of spokes attached separately to each circle and, in their centers, to each end of the spacer/axle. This crowns the spokes out as the unit is assembled.
Alignments of various sorts are essential, and have to be got at least more or less right.
Alignment of the spokes with one another I refer to as internal alignment: Half the spokes are attached to one end of the spacer/axle, and to the mating surface of one of the wheel halves, and the other half of the spokes to the other end of the spacer/axle and other wheel half's mating surface. When the mating surfaces of the wheel halves are brought together, the spoke patterns must be offset from one another, as this provides an optical illusion of more spokes than there actually are which is essential.
Alignment of the wheel halve's mating surfaces with one another I refer to as external alignment. Ideally the things should go together precisely --- a small off-set can be made good, but too great a mis-alignment here will show, particularly at the inside where the spokes sprout, a place where the eye will be drawn.
Alignment of the spacer/axle also has to be right, or at least to look right. If it is very crooked, and this can happen even if the external alignment is acceptable, the wheel will not look right.
Three factors complicate the matter further. First, there is not a lot of 'give' in the monofilament. It must be very strongly attached, both at the rims and the center, and will only stretch a little. Second, the wheel halves are pretty insubstantial. In 1/72 scale they ought not be more than a half millimeter thick, and there should not be more than two millimeters difference between outer and inner diameters, in fact it really ought to be a bit less. This makes bringing them together against the strain of the monofilament crowning out at the ends of the spacer/axle difficult. Third, when cleaning up, after the wheel halves have been attached, care must be taken to keep sanding sticks and knife edges away from the spokes, and the assembly should be held only by the rims, never by the center. Nothing really can be done on the inside seam at all.
It is made no easier by the fact that the wheels for 'El Sonora' are much smaller than standard. Wheels of Great War types generally run about 10mm outside diameter in 1/72 scale (or 15mm in 1/48), but the wheels on 'El Sonora' were only 20" in diameter, scaling out to an outside diameter of 7mm.
After a good deal of trial and error, which exposed various problems in succession, I finally reached a point where I have been able to produce this weekend a five reasonably usable wheels for 'El Sonora' (which needs three).
Here is what is needed for a wheel:
The two wheel halves are obvious, the bits beside them are two thin discs made of small slices of 1mm rod flattened down hard in a smooth-jaw pliers, two thin slices of 1mm rod left as is, and a half millimeter disc of of 1.3mm rod ---these make up the spacer/axle and anchors for the centers of the spokes. The octagonal piece is the weaving jig for the spokes, it is 1mm thick. The square pieces, one of white and one of clear plastic, also 1mm thick, with holes in the center, are assembly tools. The tape is used to tack down the ends of the monofilament line at start and finish. The larger sheet of plastic is one means of providing a background against which the spokes can be seen clearly during several steps (they don't call this stuff 'invisible thread' for nothing...)...
The wheel halves are cut off the end of a length of tube with a 7mm outer diameter.
The suggestion of 'roundness' can be given to the end of the tube before cutting off the ring, and once cut off, the excess can be sanded down to a proper thinness. The ring on the left is finished, the one on the right is straight off the tube.
Here a wheel half is on the weaving jig, with the spokes in place. The pencil marks are measured to provide a placement guide for centering, double-face tape sticks the piece in place, the projecting piece of 1mm rod at the center spreads the spokes out. Both ends of th length of monofilament are taped down on the back of the jig. A dab of CA gel is placed between the paired spokes on the rim, and spread to cover them. Care must be taken to keep glue off the inside rim, and it s best to do this twice. Let the glue set ('liquid patience' can be used to ave time, but doing so will make it necessary to replace the double-face tape for each use of the jig). Test by a little nudge with a toothpick to see each spoke is firmly attached.
Then clip the lines outside the rim, and lift the half-wheel with spokes off the jig....
Trim the excess monofilament off at the rim, closely (the stuff is very resistant to sanding, so get it right at the edge with the scissors or knife). Place it mating surface up on the opaque assembly tool, prepared with double-face tape, and glue one of the thin flattened discs in the center. Hold over a white surface while you do this, so you can see the center....
Place the wheel half mating surface down on a flat white surface, and glue one of the un-flattened discs of 1mm rod in the center....
Return one of the two wheel halves to the assembly tool, mating surface up, and fasten the half millimeter length of 1.3mm rod to the center disc...
Leaving that piece in place, attach the other wheel half to the bit of 1.3mm rod, taking care to off-set its spokes from those of the other wheel half. This is where the magic begins to happen....
The wheel halves are still separated by a bit under a millimeter's distance, however....
Apply glue all around the mating surface of the bottom wheel half, taking care to keep it off the inside rim. Place the clear assembly tool over the upper wheel half....
Squeeze the assembly tool together, doing your best to see the wheel halves come together with their otter diameters closely aligned. You won't always succeed, but about two out of three times the result will be acceptable. Holding the sandwich firmly together for a minute of so will be enough for the CA gel to set. If it looks useable, douse wit accelerator and tend to the seam, thinning down the outsides of the 'tire' a bit as well.
I am still mulling over ways to improve the final external alignment. I am thinking that a 'collar' of the tubing, with several lengths of stout rod, perhaps 1.5mm thickness, affixed to the outside of the 'collar', would provide a good resting point for the bottom wheel half, and a good guide for fastening the upper wheel half to the spacer/axle piece, and for pressing it down to mate with the bottom wheel half. Another length of the tubing could be used as a tool to press down the upper wheel half in this step. I expect I will give that a try before I actually put wheels on 'El Sonora', but as I have usable wheels in hand, and know I can do this at the rate of about forty minuted a wheel complete, I consider the problem solved, and now, with wheels and motor in order, I can move to making the airframe....
The aeroplane is 'El Sonora', a Glenn Martin 'Flyer' operated in Mexico starting in 1913.
Work on its engine may be found here:
Edited by Old Man
andymoore    432
awesome work & an excellent description.
I think this thread will end up being the definitive how-to guide to making spoked wheels. Maybe it should be one of the 'pinned' threads at the top of the forum.
cngaero    1,113
That's a beautiful piece of work and I agree that it should be pinned, as it's an extremely useful reference.
Thank you for sharing it with us.
Pinback    197
Thanks for showing :)
You have to be applauded, especially as Harry Woodman's book concentrates mainly on !/48 scale!
limeypilot    3,793
Lovely job OM.
 I have made some 9mm wheels available in my Shapeways shop here.
Perhaps I should add various sizes of tyres for use in such projects as this....
Ian
Scimitar    2,214
An excellent reference.
Thanks for posting it.
Brought back memories of building bicycle wheels as a boy.
JWM    5,640
Very nice idea and way you did it, OM!
 Recently i've bought PE set for spoke wheels, which was not cheep at all, so if I would you methed earlier I will save some money... ;) I think I have to consider how I will do it now (I am thinking on wheels for Potez 25). My old method was different (I use rubber o-ring, alu foild, thin sprue and a lt of patience most of all . My way I explained on Bristol Bulldog example, but yours is better.
J-W
Old Man    1,446
Thank you very much, Gentlemen, for the vote of confidence. I think it needs a little more refining before I would want it quite so prominent as that. It might be better, too, to have a display of making more standard size wheels (9mm or 10mm or so outer diameter).
Old Man    1,446
Thank you, Sir. There were some difficulties involved in scaling down, that is true. This could be scaled up readily, however, using a slightly heavier monofilament.
Old Man    1,446
8 hours ago, limeypilot said:
Lovely job OM.
Ian
Thank you, Sir.
That is an interesting thought. Have sent you a PM....
Old Man    1,446
Never reached the build your own bike stage. The wheels are useful as an inspiration and instruction with things like this....
Old Man    1,446
J-W
Thank you, Sir. I hope it helps. I had no luck with a photo-etch spoke set. I took a run at this some years ago, and got one good wheel out of it, but I was using other adhesives and there were problems with setting against the pressure. I did one not too long ago similar to yours, using 34ga beading wire for spokes, and putting them in one by one to wheel halves with an axle stuck up in the center. It came out all right, but was like the proverbial dog on two legs --- more of a 'it's not so much that it's done well but that it is done at all' sort of thing....
I've got at least four discarded jigs/assemblers and quite a little pile of failed wheels behind what's on display here.
