Airgunner Posted June 16, 2017 Share Posted June 16, 2017 (edited) Having got fed up with trying to win a battle with a Revell Eurofighter, I've given up for now and just need a quick(ish) and easy(ish) build, so I am going to have a go at Airfix's new 48th Defiant. I've built, and really enjoyed, its little brother in 72nd so now I'm moving up to the bigger one. I've also picked up an Eduard Zoom etch and some MAster .303 gunbarrels. Box shot... Extras... So I made a start on building all the cockpit internals, and have removed the throttle box ready to be replaced with the etch version.. This is the replacement, I'm not sure its as nice as the kit part if I'm honest but Im committed now.. This is where I'm at now, all the cockpit sub-assemblies are together and have been given a blast of Halfords grey primer ready for some Alclad Aluminium tomorrow.. Plan for tomorrow is to get the aluminium on early so it has time to cure before loading up the interior green and finishing up the internals. Busy hunting some reference photos now for the cockpit area as I would like to add some electrical and control wires, even though not much can be seen when it's all closed up. More soon.. Steve Edited July 9, 2017 by Airgunner 4 Link to comment Share on other sites More sharing options...
The Spadgent Posted June 17, 2017 Share Posted June 17, 2017 Ooh nice start. I have this kit so I'll tag along if you don't mind. Get some tips you know. Johnny 1 Link to comment Share on other sites More sharing options...
amblypygid Posted June 17, 2017 Share Posted June 17, 2017 I'm building one of these for the Made in Britain GB, and I've found it to be a shake and bake kit, but with little tolerance for anything that's slightly out of alignment. It does build up very nicely. Mine is OOB so I'm looking forward to seeing what difference the AM will make. Link to comment Share on other sites More sharing options...
matteo44 Posted June 19, 2017 Share Posted June 19, 2017 This is an interesting kit... Good work Link to comment Share on other sites More sharing options...
Airgunner Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) Now the hot weather has passed I can get back into to my shed and get to painting again, so I have finally got the interior painted, washed and finished. The Eduard Zoom stuff is as usual very nice, but on a kit like this, I'm sure not much of it will be see, in the cockpit anyway, but it may well help the turret along, that was really my main reason for using it. I also discovered that exposed wiring in the cockpit is minimal on a Defiant, and you wont see it anyway so I gave this a miss to. I've now moved onto the wing assembly, I really like the way this goes together and have started work on the wheel wells and a radiator scoop. I'll post up some photos when there is something worth seeing. More soon Steve Edited July 9, 2017 by Airgunner 3 Link to comment Share on other sites More sharing options...
Airgunner Posted June 26, 2017 Author Share Posted June 26, 2017 (edited) Managed some more bench time recently so time for a small update. First job of the day was to get the fuselage sealed up. This took a bit of time and quite a few test fits, mainly down to the Eduard IP, and the way Airfix would have you assemble the cockpit. As with all the new Airfix releases, tolerances are extremely close so careful cleanup of paint on all the mating surfaces is needed. Once the interior is aligned, it all clicks together well. The tape is there purely to hold it whilst the cement sets. Once that was done and had been put aside to set up, I thought I would take the turret. As previously mentioned, there would be the rest of the Zoom kit in the plus the Master .303 barrels. It's not the the kit barrels are bad, they're not with some careful finishing and opening of the muzzles they will look good straight from the box... But the Master barrels bring some much more, especially in 1/48th. The turret is a lovely little kit all of its own, and even without the etch and some careful painting it will look the business as is. I have convinced myself I need to do another one of these and use no aftermarket just to see how it turns out. The turret has loads of detail, but as I had it I will put the etch in, so lots of of the standard raised detail has been removed. So that's it for now, just going to leave that little lot to set up, then a bit of clean up and we can start squirting paint about again. I may well have a go at the undercarriage later if time permits, but for now, That's All Folks!! Steve Edited July 9, 2017 by Airgunner 7 Link to comment Share on other sites More sharing options...
Graham T Posted June 26, 2017 Share Posted June 26, 2017 (edited) Nice work so far. Those Master barrels look pretty good to me, a great upgrade!! Edited June 26, 2017 by Graham T Link to comment Share on other sites More sharing options...
amblypygid Posted June 26, 2017 Share Posted June 26, 2017 Yes, they're a distinct improvement on the kit plastic. 4 hours ago, Airgunner said: As with all the new Airfix releases, tolerances are extremely close so careful cleanup of paint on all the mating surfaces is needed. True; I had to shave a bit off the IP as I think I'd fixed it too low, but otherwise the fit was damn near immaculate. Link to comment Share on other sites More sharing options...
Mick Drover Posted June 27, 2017 Share Posted June 27, 2017 Great progress Steve. As Chris mentioned above, I had to do a bit of fettling to get the etch part of the Eduard IP to fit. I think it was slightly bigger than the kit plastic part. Other than that the build was a breeze as I'm sure you're aware of. Those Master barrels do look nice. Cheers, Mick Link to comment Share on other sites More sharing options...
Billydick Posted June 27, 2017 Share Posted June 27, 2017 Going to follow this looks good .. those Master barrels are the biz ! BillyD Link to comment Share on other sites More sharing options...
Martian Posted June 27, 2017 Share Posted June 27, 2017 Good call, replacing the kit barrels with the Master ones. Martian Link to comment Share on other sites More sharing options...
Kahunaminor Posted June 28, 2017 Share Posted June 28, 2017 Nicely done Steve, The Master barrels certainly do add to the turret. Your progressing quite well and I cannot think of any real vices I discovered from my build last year ( see here). Which scheme do you intend to finish it in? Regards, Link to comment Share on other sites More sharing options...
Airgunner Posted June 30, 2017 Author Share Posted June 30, 2017 (edited) Moving on.... Basic airframe together, primed with Halfords grey plastic primer and polished with 8000 grit Micromesh... ....ready for a coat of Alclad Aluminium in the areas there will be wear and chipping... And pre-shaded underneath. I try to preshade with a darker shade of the colour to be painted. TO me, RAF Sky has a greenish tint so I preshaded with RAF Dark Green.. While the compressor was running, I gave the turret an initial coat of Tamiya Semi-gloss Black... And one other thing that was bugging me. the wheels are not the best. One side of each wheel on the opposite side of the mounting hole was a deep sink mark, so I punched out a couple of discs to covered them, and also they add a little more depth to the wheels. A centre bolt was also added from a piece of round sprue.. Thats all for now, looking to get the underside painted tomorrow, and hopefully will get some of the other ancillery bits done like the prop and undercart etc. Steve Edited July 9, 2017 by Airgunner 3 Link to comment Share on other sites More sharing options...
Airgunner Posted July 1, 2017 Author Share Posted July 1, 2017 (edited) Frustrating day today, wanted to get the underside done, but had a real fight with the paint. Used, as I always do for RAF Sky, the Xtracrylix Sky which has always worked a treat but just couldn't get it to go down well. Tried loads of things but I just think the conditions I was trying to spray in was the perfect storm for it to go wrong. After about three hours I got it looking like this.... It's not horrendously bad but I'm not sure I am happy with it. I have put the airbrush away for today and will have a look with fresh eyes tomorrow. It may get away with a gentle flattening with Micromesh cloths and be presentable, we will have to wait and see. So much for getting some progress, today was the most time I've had at the bench, but the smallest amount got done. Oh well, there's always tomorrow. Edited July 9, 2017 by Airgunner 2 Link to comment Share on other sites More sharing options...
phildagreek Posted July 2, 2017 Share Posted July 2, 2017 Looks smart, I like what you've done with the cockpit. Link to comment Share on other sites More sharing options...
Airgunner Posted July 4, 2017 Author Share Posted July 4, 2017 (edited) Got a good bit more done over the last few days, so here's an update.. Got the Dark Earth on, used Xtracrylix for this as to my eye the Tamiya version is a little too red. A marathon masking session then followed and the Dark Green was sprayed. This is Tamiya, heavily thinned.. Once it was dry, it was time to unwrap it.. Whilst the paint was soft I started on the chipping.. I also got on with the drybrush on the turret, and added the etch.. Got the prop done too... The step has some obvious detail on it, but the kit part is just a flat bit of plastic. There are lots of clear photos out there so I formed the basic shape from plasticard and added that. The end is in sight now, just getting some paint on the little bits and bobs, clear parts have all been dipped in future and are now drying ready for paint. Hopefully I'll get this finished over the next couple of days. More soon Steve Edited July 9, 2017 by Airgunner 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted July 4, 2017 Share Posted July 4, 2017 (edited) Looking great! Loving that tub and I wouldn't beat yourself up over the underside. It looks fine to me. The camo's looking rather splendid too. wonderful work. Bravo sir. John Edited July 4, 2017 by The Spadgent Link to comment Share on other sites More sharing options...
Airgunner Posted July 9, 2017 Author Share Posted July 9, 2017 (edited) Bloody annoyingly, thanks to PB all my photos now seem to have gone the way of the Dodo. So, I am now using Flickr, and this is going to be a bit of and experimental post. Got all the decals and stencils on now.... Edited July 9, 2017 by Airgunner 4 Link to comment Share on other sites More sharing options...
Airgunner Posted July 12, 2017 Author Share Posted July 12, 2017 (edited) Quote A bit of a test post this one, just trying out an upload via Flickrs app. I've hollowed the exhausts out with a micro drill and a sharp 10A blade... Edited July 12, 2017 by Airgunner 1 Link to comment Share on other sites More sharing options...
Airgunner Posted July 12, 2017 Author Share Posted July 12, 2017 Well, that seemed to work so I'll try and get some more photos up later... Link to comment Share on other sites More sharing options...
spitfire Posted July 12, 2017 Share Posted July 12, 2017 That looks great, I have a soft spot for the Defiant. Cheers Dennis Link to comment Share on other sites More sharing options...
Airgunner Posted July 18, 2017 Author Share Posted July 18, 2017 Bit more progress over the last few days... Dot filter on, and the colours used.. This took a good few days to dry, probably down to the warm weather.. Whilst that was drying I added a the reflectors for the landing lights, I used some small pieces cut out of a Swann and Morton blade packet as it is aluminium coloured.. The canopies and turret clear parts have been painted too, first the interior colour, then Alclad Aluminium and then the exterior colours.. Once these have been left a day I will start on chipping them. More soon... Steve 3 Link to comment Share on other sites More sharing options...
amblypygid Posted July 18, 2017 Share Posted July 18, 2017 Nice! I'm just at the point of weathering mine, but I've attached the canopy and turret. I found it impossible to fit both turret doors in the open position, and ended up with the rearmost door closed. Hopefully yours fits better! Link to comment Share on other sites More sharing options...
The Spadgent Posted July 18, 2017 Share Posted July 18, 2017 Looks awesome. looking forward to how the dot filters turn out. John Link to comment Share on other sites More sharing options...
