elmarriachi Posted June 14, 2017 Share Posted June 14, 2017 Hello, I want to show you one more small kit of a construction vehicle. This time an old motor grader from Caterpillar, model number 12. It was built during world war two and still used long time after the war all around the world. The kit comes from Plus Model from Czech Rep. and is a multimedia kit consisting of resin, wire, etched parts and decals. Also included a CD-Rom with pictures of the kit and the original, a good mounting instruction and clear head lamps. Unfortunately the kit includes only decals and painting guide for two versions of the US Army - no civil one in the typical Caterpillar yellow which I will make ... First I have started with the frame, rear tandem-axle and the steering axle with the steering linkage, then the wheels. The engine is consisting of several small and smaller parts plus some photo etched parts. I think I will add some wire to it next to give it some more details ... Cheers Micha 5 Link to comment Share on other sites More sharing options...
RichO Posted June 16, 2017 Share Posted June 16, 2017 You seem to be able to find some of the coolest, earth moving equipment kits. Keep 'em coming. Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 18, 2017 Share Posted June 18, 2017 That just looks like a mad Dragster! I've seen some of the newer versions of this, and the way the front axle articulates all over the place makes it look really worn out. Link to comment Share on other sites More sharing options...
elmarriachi Posted June 19, 2017 Author Share Posted June 19, 2017 Thanks a lot ... I like earthmoving vehicles Just started the soviet dozer DT74 these days Link to comment Share on other sites More sharing options...
elmarriachi Posted June 21, 2017 Author Share Posted June 21, 2017 Hello, and some more pictures .... The driver's place .... some levers follow later..... the rest is done .... ... and primered in rusty red ... ... also the rest of the car is primed in red ... some wiring at the engine added (although only a little bit will be visible later) ... Behind the front axle mounted: The ripper ... behind the ripper follows the blade .... Next follows some hairspray.... then typical Caterpillar yellow at the engine and rear/bottom of the driver's place .... Cheers Micha 3 Link to comment Share on other sites More sharing options...
elmarriachi Posted June 26, 2017 Author Share Posted June 26, 2017 Hello, the rear area of the grader was primered in rusty red, then water and salt added. The main color was sprayed on top in the rear area and on the engine, consisting of Tamiya X4 and Lifecolor orange. After that the blade and some further parts were added, also some parts at the drivers place - levers, steering wheel, ... After that the new added parts were primered, water/salt added and everything painted in the final yellow colors. Then the salt removed. Next step - painting all the details, then weathering. Cheers Micha 3 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted June 26, 2017 Share Posted June 26, 2017 Wow! It's coming along very nicely. Link to comment Share on other sites More sharing options...
RichO Posted June 26, 2017 Share Posted June 26, 2017 That is very nice! Link to comment Share on other sites More sharing options...
stevehnz Posted June 26, 2017 Share Posted June 26, 2017 That is looking smart. I recall similar graders to that in this neck of the woods when I was younger. (Much) Steve. 1 Link to comment Share on other sites More sharing options...
elmarriachi Posted July 6, 2017 Author Share Posted July 6, 2017 Hello, the motor grader is mostly finished now. Some last details need to be done, also the base which I have begun needs some further work... But before I could go on I will leave to summer vacatiln now Cheers, Micha 5 Link to comment Share on other sites More sharing options...
stevehnz Posted July 6, 2017 Share Posted July 6, 2017 Wow, what a beaut, just like I recall the ones from my childhood, though I do seem to recall a rudimentary cab on some. Your weathering is spot on for a machine such as this to my eye. Steve. Link to comment Share on other sites More sharing options...
RichO Posted July 6, 2017 Share Posted July 6, 2017 I'm with Steve on this one. Great job on the weathering! Link to comment Share on other sites More sharing options...
elmarriachi Posted July 28, 2017 Author Share Posted July 28, 2017 Hello, I think that's it ... some weathering of the white/red rods missing yet, then I think it is done ... Cheers Micha 4 Link to comment Share on other sites More sharing options...
stevehnz Posted July 28, 2017 Share Posted July 28, 2017 For an ugly old thing like that, its looking really rather good. Steve. Link to comment Share on other sites More sharing options...
RichO Posted July 29, 2017 Share Posted July 29, 2017 Beautiful work! Link to comment Share on other sites More sharing options...
