Revell 1/32 Bf109G-6 JG300 "Red 8" Finished!! :)
galgos
If it's not too late I'd like to join in please.  I've never built a Bf109 and have little or no knowledge about them however I'm a great fan of Bf110s and of the Nachtjagd in particular.  So it makes sense to cut my teeth on a Bf109 from JG300, though I'll have to research details and colour schemes - from a quick browse I see some interesting ones.  The build will be OOB.
Max
Thanks V-P and Wayne.  It's been a while since I've been active on Britmodeller, so building a new type of aircraft for me in an STGB is an exciting prospect.  I hope to make a start during the upcoming week but in the meantime a snap of the box art:
I've no idea about the accuracy or pedigree of this kit and right now ignorance is bliss because I don't want to get hung up on corrections etc., just enjoy the research, build and painting process!!
Max
I knew I would, I'm already beginning to waiver on the OOB part of the build.....why do I always complicate matters for myself!! :huh:  I'm now contemplating using a spare engine and bearers from a Bf110E kit to fit into the Bf109!  I need to investigate the logistics of this first though......
Max
I'm feeling slightly frustrated because, although I've thought better of the open nose panels/engine route, I'm waiting for the AlleyCat resin upgrade stuff to arrive so I don't really want to get stuck into the actual build yet.  However, I do have Radu's wonderful Luftwaffe seatbelt set so I spent a couple of hours this morning studying the instructions (you can't take anything for granted with these!) and putting one of the lap straps together, pictures below:
Having completed one I'm pretty confident the rest will be done in a fraction of the time, but I'll still be taking great care to follow the instructions!
Max
Not got a lot of hair to pull out George! No, they're fine as long as you take the time to study and understand the instructions, and then follow them meticulously. Once the set is together and lightly stained I think they'll look pretty good.
Max
Seatbelts complete apart from a little "weathering":
I need to adjust the shoulder straps slightly so that they are the same length though I could probably lose the difference quite easily by careful arrangement on the seat!
Max
Trying to make a little progress with the cockpit but the instructions are fighting me!  If you like the "Where's Wally?" books you'll enjoy making this kit.  Not only are the individual parts in the assembly drawings not related in any way to the sprue that they are on, not only is there no coherent arrangement of parts on the sprue (i.e. all the cockpit parts on one sprue), but some part numbers in the drawings don't agree with the part numbers on the sprue!!!  I've just spent 5 minutes looking for part 10, allegedly the seat, but on oh, it's part 9!
GGrrrrrrrrr!!
Max
The bits of the cockpit are ready to assemble, probably the hardest part of the build completed.
The pilot and his crew man are getting ready to go.....
Max
Just a matter of patience Davey......I'm no musician though!
Final pic before the port side goes on:
Dry fitting, looks like a good fit.
I'm securing the port and starboard nose panels in two, maybe three stages, initially glued at the nose but I'm about to do the middle and perhaps aft section.  I'm taking it easy because a tight fit is required and I don't want to have to sand too much; I'm aware that some the joins at the aft end are not on panel lines so filling is needed anyway - I want to make this as trouble-free as possible!
Max
Fuselage zipped up.  I have to say that I'm really impressed with this kit, its fit and the way that it's engineered - quite delightful to build (so far)!
Wheel wells boxed in and rads. fitted prior to shooting a little dark grey/black before the lower wing halves go on.
Max
A superb value kit as well . Nice not to haave to make the difficult expose engine or not decission and keep the lines of the 109 all buttond up . The upper mid wing joints need some care to avoid a smidge of filler .
A less-than-perfect join, the upper nose cowl with the fuselage nose sides, the cowl being slightly too narrow for the whole of its length but most noticeably near the cockpit.  I've removed some of the unnecessary kit superstructure just forward of the IP, the 2 part plan being 1. to put a horizontal spacer inside the rear section of the cowl to spread it very slightly and 2. to gently squeeze the side panels to the width of the forward two-thirds of the cowl, hopefully achieving a flush-fitting side panel/cowl assembly for the whole of its length.
But she's coming on:
Max
Hi Max
..long time no speak. Here's a few JG 300 'wilde Sau' G-5/6 scheme options
G-5s 'white 1' and 'white 4' with Naxos
G-6 'white 7' of 1. Staffel with exhaust stack shroud  ( and possibly whistle)
Closer view of a JG 300 G-6 exhaust stack flame shroud with Eberspächer acoustic pipe or 'whistle' over the leading ejector. These ‘whistles’ provided an audible alarm signal to alert an airfield and its flak batteries that a wilde Sau night fighter was operating in the vicinity
G-6/R6
Thank you Steve and Neil.  I'm really enjoying building this kit, it's simple but interesting, perhaps the fact that I haven't built a 109 before is a factor?
Agreed it's been a long time Neil since we've chatted, thank you for posting those pictures of JG300 planes. I've got the EagleCals JG300 Part 1 decals though, since I'm doing the short tail version, I'm a little disappointed by the options.....neither particularly attract me.. The first is Red 6 of Fw Arnold Doring (I./JG300), very heavily mottled and oversprayed with black under parts, and the second is Red 8 of Oblt Kurt Gabler (III./JG300) which goes to the other extreme of essentially a natural metal finish, the paint being sanded off in a quest for speed.
All options are still open!
Regards
Max
PS Neil, just caught up with your Blogspot thoughts on Gabler's Red 8, might well go for that one.
Following on from yesterday's conversation with Neil, "Red 8" it's going to be:
There is a degree of uncertainty about how much of the original camouflage was sanded off so I reckon that gives me a fair amount of artistic licence.  I mostly use Mr Paint which, though described as acrylic quite clearly isn't as far as the carrier medium is concerned because that's lacquer-based.  But they are beautifully fine and smooth to use straight from the bottle and I hope will be perfect for achieving the "remnants of colour" finish on this aircraft.  The main base will be anodised aluminium with some panels/areas in duraluminium of similar:
