Julien Posted June 9, 2017 Share Posted June 9, 2017 Ki-61-id Hien Update sets & masks - For Tamiya Kit 1:48 Eduard Exhaust Stacks (648316) This is a resin drop in set for the kit parts. Eduard's well cast resin will be worth it in this area. Update Set (49822) This is one brass fret.& one colour nickel one. Most of the colour pats are for the cockpit with the instrument panel and side panels being replaced. Many other cockpit parts are also replaced. There is a new flap for the radiator, and new interior baffles for it as well. There are new main gear doors and other parts for the wheel wells. Brake lines are supplied for the main gear legs and lastly new framing for the canopy is supplied. Flaps (48920) This large brass frets which provides flaps for the kit. The ribs are just bent into position on these, small rod is needed which is not supplied. Some work on kit parts is needed. Seatbelts (49823) This small fret provides seatbelts for the Ki-61 Wheels (648317) This set provides both main wheels with circumferential tread, and the tail wheel. A set of wheel masks are also included. Masks (EX548) These are on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, landing lights & wheels. Conclusion These sets will enhance an already impressive model. Recommended. Review samples courtesy of Link to comment Share on other sites More sharing options...
