Hi Chaps,
Well I have never managed 2 in a GB before but here I am going for number 3.
I'm not sure if I'll finish as I'm on holiday for the start of July and I'm away for work 1 week as well so only really 2 weeks to get this done. Its been to the top of the pile a few times and gone under again but with 3 weeks left its about the only 1 I'm likely to get done before the deadline.
This has been in my stash for many years as I thought it was the twin engined one when I bought it and was probably a bit disapointed when it arrived. The other ARBA kit I has was the Gloster Whittle which I built back in 2006 and was a great kit for its time. Special Hobby brought the Whittle out soon after so this will prompt some mainstream guys to produce it.
The box, also seen with a picture on the lid. I built the Airfix Bedford MWD last week while deciding whether to start this or a Meteor.
Fills the box or would do if it was a smaller box!
IMG_6853
6 pieces of resin, 11 bits of pewter and 2 canopies. How hard can it be................!
Will make a start this week end.
Colin W
Edited by Colin W
Picture restoration
This is great Colin :thumbsup2:
A really unusual aircraft and what a fascinating concept.
I'm trying to imagine an alternative history in which such aircraft populated the decks of late WWII aircraft carriers.
There aren't many parts in the kit, but as we all know, that doesn't necessarily mean it will be easy!
Good luck for an enjoyable build; looking forward to seeing this incredible shape take form :)!
All the best
TonyT
Cheers Tony
The canard bomber from the cover of Tony Butlers 'Secret Projects' book was doing the rounds on the internet last week. What might have been? Maybe if Bleriot had followed the Wright brothers, Cody and the Bristol Box kite by putting the elevators in front then this would be the norm!
Well it didn't take too long to get things underway. The instructions were 'sparse' but the gist was OK. I spent the morning tidying up the resin and twice nearly cut this scoop off. The patchy resin convincing me it was uncured and  the scoop had inadvertently stuck in the wrong place. Then, just as I was about to cut I realised the hole under the scoop was aligned with it and its actually correct. Near Miss!
IMG_6854
Well that out of the way I joined up the front fuselage with the engine using epoxy. Once dry I added the main wings and then set the cannard wings to be parallel.
IMG_6858
The tails were supposed to be a butt joint but I drilled 1mm brass rod into the wing and tail to help with alignment and provide some strength to the join.
IMG_6859
I also cleaned up the pewter parts which were not too bad actually. Lovely seat and instrument pannel and a cracking throttle quadrant. It made me wonder about all the kits which provide impossible to see rudder pedals but give no throttle. These guys got it the right way round. Well a coat of filler here and there to tidy the joins and fill the odd air bubble ready for an overnight drying. I love getting the major assembly done before painting the cockpit.
Colin
Edited by Colin W
Picture restoration
I painted the interior with Int green mix and the instrument panel black. Seat belts were from tape as usual. The cockpit went together very well and I was soon absorbed into the the vacform canopy.
ARBA provide a spare which is always useful but not necessary in this case. The material is probably some of the thickest canopy material I have come across and it took quite a bit of cutting out. Fit was quite good and the material was very clear after a dunk in Future.  I did use a bit of filler around the front of the canopy and at the rear where it was slightly proud of the front wing. I was so absorbed I forgot to take a picture until after the canopy was on and masked. Shame as it was quite nice. Anyway here it is with the green sprayed on.
IMG_6860
Once the green was dry I gave it a couple of coats of grey Mr Surfacer with a light sand in between to cover over the base colours and give a flat start point. The undersides were then sprayed with white ready for the yellow.
Meanwhile I have painted the wheels and prop. Should not take too long but I just realised I have to make my own decals. Another job!
IMG_6863
Colin
Edited by Colin W
Picture restoration
Well ripping through this. At least 14 years in the stash and open box to final paint in a week. I should have made it before.
Apparently a Libuella is Latin for dragonfly. The dragonfly always has the tandem wing with the rear wing wider than the fore wing. Libelluloidea is a family of dragonflies.
I painted the undersides yellow over the white, masked them and painted the brown and then copied the camo pattern from the instructions masked the brown and painted the green.
IMG_6868
IMG_6870
The pictures are about twice real size so I can see a bit of touching up is needed. Decals to print now. I'll leave it for a few days to degas and get the wheels on.
Colin
Edited by Colin W
Picture restoration
A fascinating subject and the dragonfly name seems very apt.
Cliff
Yes I thought Libellula was an odd name but once translated its an ideal name for this plane.
I have just printed the decals and the serial number is U0235. This is very unusual for a military serial and is not a Makers number or civilian one either. Does anyone know where this might have come from?
Colin
It looks great Colin. A really nice kit by the look of it.
I like how you say it's been 15 years in the stash and just over a week to paint :D!
If only they were all like that.
Good stuff :thumbsup2:
TonyT
Terrific work, looking great. Such an unusual concept, like something by Bert Rutan.
Dermot
Very nice. Such an odd looking machine! Needs a Handley-Page Manx to go with it.
A Handley Page Manx! How about an M52?
Actually this is another ARBA kit I built about 10 years ago.
Miles M52  1
Another stunning Miles creation destroyed by government bungling!
Sorry no pics of this with the Libellula as I left it in the UK.
Colin
Edited by Colin W
Pics added
Well I said it would be a quick build and here we are after 8 days. Quick even for me!
Moving on from the last pictures I painted the main camouflage and popped the main landing gear on.
IMG_6935
Decals were nice and easy, Main roundels were from a 1/72 microscale sheet of excessive years but still perfect. The P was from the same Fantasy Print shop sheet as the P on the 510 above. Serials were home printed. All floated on with a layer of Future.
A coat of Microscale satin to blend it all together and leave a sheen. I find the matt too flat in 1/48 so prefer the satin. Cockpit unmasked and the prop fitted.
IMG_6940
IMG_6941
IMG_6942
IMG_6943
Thanks for the likes and the comments above.
Colin
Edited by Colin W
Picture restoration
Quoting from Wikipedia
"test serials are used to externally identify aircraft flown within the United Kingdom without a full Certificate of Airworthiness. They can be used for testing experimental and prototype aircraft or modifications, pre-delivery flights for foreign customers and are sometimes referred to as "B" class markings".
Excellent model by the way and finished in record time too!
Superb :clap:!
A great model. I keep looking at it and thinking:
"Did this really  exist in real life?".
Yes, it did.
A really nice model made in record time and a great addition to the Gallery.
Thank you for a great contribution to the Group Build :thanks: .
Best regards
TonyT
