Julien Posted May 31, 2017 Share Posted May 31, 2017 Supermarine Seafire Mk.III "last Fights Over the Pacific" Special Hobby 1:48 It is believed that the Admiralty first showed an interest in a carrier based Spitfire as early as 1938, when Fairey Aviation proposed such a modification could take place. This idea was rejected and subsequently left the Fleet Air Arm to order other less capable aircraft. The matter was again raised in 1939 and a Spitfire was fitted with an A Frame arrestor hook. After further investigation folding wings were added to the specification. At the time one of the major factors holding back a Sea Spitfire (or Seafire as it was to become) was that production capacity was needed for land Spitfires. Due to this Wildcats were ordered from Grumman for the FAA to be called the Martlet. By the end of 1941 the Admiralty again looked at Spitfire project. 48 Spitfire Mk Vbs were converted by Air Training Services at Hamble to become hooked Spitfires. These would allow the Royal Navy to get experience operating the type, which due to its narrow undercarriage and high nose was not the ideal carrier aircraft. The second major type for the RN was the Seafire Mk II, this used a cropped supercharger to provide greater power at lower levels. The IIc was the first major mark to be deployed in any number. The Seafire Mk III was the real first true carrier Seafire. It was developed from the IIc. It had manually folding wings allowing more aircraft to be carried. The wing would fold using a system of two straight chordwise folds. A break was introduced immediately outboard of the wheel well where the wing would fold upwards and slightly forward, a second fold would be at the wingtip. The Mk III would use the Merlin 55 engine with a 4 bladed prop. The Mk III would be used by the Fleet Air Arm, The Irish Air Corps, and the French Aéronavale. The French would receive 65 Mk IIIs which were deployed to Vietnam on board the carrier Arromanches in 1948. The Irish Air Corps were supplied with 12 Mk III in 1947 which were stripped of their Naval equipment (except the wing fold) by Supermarine.The Kit The kit arrives in a fairly sturdy box. Inside are three large and three small sprues of grey plastic, a clear sprue, a sheet of vinyl, a sheet of photo etch; and an instrument panel film. Construction as with most aircraft starts with the cockpit area. The bulkhead forward of the pilot is made up along with the instrument panel. This is added to the engine firewall, the floor area including rudder pedals and control column is added. The seat can then be attached to its backing of armour plate, this along with the headrest is then added to the rear fuselage frame. PE seat belts and harness straps are then added. The next step is to add both of the previous subassemblies onto the main fuselage. Lage side panels with relief details are also added at this stage. The fuselage can then be closed up. The vinyl parts can then be applied to the closed up fuselage. The next stage in construction is the wings. The upper wing halves are attached to the one part lower wing. The internal sections of the wheel wells need to be placed inside the wing sections before they are closed up. The right cannon bulges need to be glued to the upper wing. There is no internal structure under the bulges. Be sure to use the right cannon bulges as there are four different sets on the sprues. The propellor is the next sub assembly to be built up, along with the arrestor hook parts If your build needs them). The next major task is to attach fuselage to the wings. Following this the tail planes, rudder, ailerons; and wing tips are added. Attention then turns to the underside of the aircraft. The radiators, engine under cowling, air intake and tail wheel are added. If your aircraft has an arrestor hook this sub assembly is also added, if not then a plate is added to this area. The undercarriage is also assembled and added at this stage. Finally to wrap up your build the engine exhausts, appropriate cannon barrels, aerial mast, entry door, propellor assembly; and canopies are added to the kit.Photo Etch & Vinyl A small photo etched fret is provided for the seat belts & harness, Instrument panel, rudder pedals, escape crowbar, and fuselage stiffening plates. A self adhesive vinyl sheet provides for raised areas on the fuselage where even PE would be too thick. An acetate film is provided for use between the PE instrument panel parts. Canopy The clear parts are very clear and remarkably thin. Care will need to be taken removing them from the sprue. I am not sure if the main canopy will fit over the rear part as the instructions do not show this. Decals Decals are provided for 3 aircraft. PR256, 894 Sqn HMS Indefatigable. April 1945. PR240, 880 Sqn HMS Improbable, June 1945. NN212, 887 Sqn HMS Indefatigable, August 1945. All decals are printed by Aviprint, are in register and colour density looks good.Conclusion A good re-release from Special Hobby showing aircraft from the last combat patrols of the FAA in the Far East. In fact NN212 took part int eh very last combat of the Fleet Air Air of WWII. Highly recommended. Review sample courtesy of 5 Link to comment Share on other sites More sharing options...
