Calum
1/48 Hasegawa A-4K Skyhawk
Now the F-14 is done , I'm onto the next project, a Hasegawa A-4K. I'll be doing a SEA A-4K from around the mid 1980's to replace the kit below which I trashed stripping it prior to wanting to repaint it
This will be an in flight build so not much aftermarket, just the excellent Gekko Graphics decal and a seated pilot from Aerobonus. Anyone who has built this kit knows the fit isn't particularly great. This coupled with the, IMHO, far to fine panel lines means you can have a bit of fight on your hands.
First step is to deal with the poor fitting intakes, basically the intake is not as wide as the kit so you end up with a step on the inside where the engine face piece mates with the middle part of the intake.
The easy solution here is to cut the engine face in half. Then glue each half to the respective fuselage half. now you'll have no step and unless you've got a boroscope you can't see the centre of the engine piece once everything is together.
I fitted the tubular piece, which simulates the CSD/CFG roughly in the centre of one of the cut pieces.
As you can see, no sign of the split and we haven't put on the rest of the intake, which makes the gap even smaller
Edited by Calum
Will be watching.............coincidentally I am finishing up one myself...............in the wonderful SEA scheme as yours
rgds
Had a little flash back at the mention of the CSD.
Memories of standing on a wobbly chock on an artic Nowra morning checking the fluid level.
Sometimes the aircraft would wake you up by dropping the outer intake door upon your bonce.
Good times
I plan to build of of this as well, someday. Pulling up a chair to follow along if you don't mind.
Awesome, looking forward to this! :popcorn:
1 hour ago, pacificmustang said:
great fix for the intake Calum
Cheers mate, Can't claim it as mine though. I think I saw it mentioned on ARDC a few years ago.. Surprisingly I managed to remember .
The Aerobonus pilot/seat was disappointing, his visor was up, not down as it should be when flying and the arms were to short I shan't be using my other one, the Kit seat and a figure from the spares box will be just as good for my next build like this..
I ended using a head and arms from the spares box.. I didn't bother getting to carried away with the painting as he's going to be under the canopy which isn't large to begin with.
Edited by Calum
Been working on the mounting point for the aircraft as it's going to be done "in flight. I'm using acrylic rod which I had a mate mill a 1/4 inch square on . I'll be mounting it into the rear of one of the main leg fairings.
I used square box on the inside of the wing
And scrap to make a box on the main gear fairing
Everything together and it's time for filling. getting the main gear doors to fit was a challenge and fairings for the main legs didn't really match the doors so magi sculpt was used to fill and contour that area.
Getting the slats to fit was also a challenge as these don't really fit that well onto the recess in the wing.. Just proving what a stupid idea that step in the upper wing is.
I also moved the anti col light fairing to the correct (for an A-4K) side.
The crappy insert in the back of the aircraft also doesn't fit at all well meaning you're in for some putty work to fill the steps
Wing to fuselage joint also has quite a large gap. Again water based fillers are the best tool for here . I used magi sculpt to fill the worst of it and finished off with Vallejo filler.
Edited by Calum
1/48 isn't really my scale but I am very tempted to buy the Eduard Scooter boxing 'just for the stash'.....
Your build is looking good and a great idea ref the intakes.
Paints on. Went for home made masks for the camo scheme for 2 reasons, firstly I'm lazy , secondly the SEA RNZAF A-4's has a reasonably hard edge to the camo scheme in a lot of the images I've looked at, although I'll acknowledge they were most likely free hand painted.
Paints were Mr Color Lacquers except for the black which is Tamiya NATO Black and the red which is also Tamiya . To save masking the intakes I painted these separately and once I'd finished the camo I glued the intakes on. Fit is good.
The base isn't the final one, it's just a scrap bit of timber. the rod has been bent but heating it with a hot air gun and bending it on a slight angle. I haven't finalised the exact angle as yet but it'll be something like this
Next step is a wash, then a gloss coat.
Edited by Calum
Looks great !!
cannot wait to see in done up fully
rgds
