For a change (yes I am frequently quite/very stupid and forget the walk rounds) I did look but couldn't find the upper part of the nosewheel bay
But I'm stupid and can easily miss stuff
I need the roof and the mainleg hinge point
I don't intend making a fully working bay but I need to be able to assess the relative heights against the cockpit floors, then I can get bashing the consoles and work out whether any of the side ledges Matchbox fitted can be utilised
BrigadierGeneral Milord Melchett is going to do a 'delve' into his own copious and extensive library of wonders for me later
Or possibly he'll send Baldrick down into Melchett Matravers Castle's crypts looking for that old cardboard box the mem' chucked down there three years since with a few Box Brownie shots in it...
In yonder interim I'll pop back to see if I did miss anything
Cheers James
If you are going to all this trouble, you might as well go the whole hog and fold those wings. Go on, you know you want to. :devil:
Martian
Do you mean nose leg hinge point Bill, don't think the mainlegs are anywhere near the cockpit floors?
Can't help personally I'm afraid.
Looking forward to this one as much as Wospie!
Keith
Don't get your hopes up Keith, dropped the port intake section
On hard laminate floor
Guess?
Yup three pieces, two of which I still own  :thumbsup2:
One owned by the gods of nether darknesses
It is a small section of intake rim which dropped two little segments as it split
The main body and the remaining little bit are back together bemoaning the missing bit, as  are I (torture a language? Moi? ...)
I plan to mould a new rim section from the good starboard one tomorrow morning, sun up and possibly gives me time to stumble into the missing bit in a slipper or a stout outdoor walking boot at just the maximum pain threshold
Which I deserve for clumsy see
The intakes are beautifully moulded but they do not give the pair of small rectangular intakes between the lips and the fuselage so I get time to work on that soon too
Now back to the fut.. last post
Keith I do mean the main leg, the main nose leg as opposed to the retract link
but yes of course me wrong again  :(
Martian, did you miss POST ONE?
The wings will not be folded
This model is going to have extended brake petals because often seen parked that way (and I have this Airwaves thing I have a need to try out. One has to be good surely?)
I have yet another Bucc to build navally, it will be an S2 and as it will be built into next year's 'twelve month plan' folded noses, wings and tail petals are highly possible
This year's all folded special is done, I need a fun quick build now
This might be it
Might
but there is no way the cockpit that Matchbox gives me is up to the job, nor their bang-whizz seats neither
The nose wheel sat on a flat bit level with the base of the fuselage and there is no cockpit floor
of which more...
As I mentioned the nosewheel (and leg) are stuck to the base of the fuselage which isn't good enough
I've extended the leg with a length of Evergreen rod and begun restructuring it
And stuck the tail cone together
And cut off the fuselage section of the cone ready to cast new bits to play with
The nose wheel leg is wider than the wheel well, funny huh
Well I'm moulding some new bits to get playing with and the rear fuselage will be getting lots of attention so I'm replicating that too
This is Wilko Blox which is inferior Legolike
It does not click solidly together so I like to seal the box before I cast moulds from it
Plasticene floor to seal the base edges  And then a coat of Johnson's Clear to seal the brick joints
do you see it?
Green brick with yellow to the left, blue below and white and red above
Nice little slot there? Hmm not sure, we'll watch that
get scales and begin measuring latex into a 2gm cup
and add ten percent by weight of catalyst
roughly does it for me, I always have more catalyst left when the latex is done but the scales deviated here, I read 86 before I added the red goo so I set up to add up to 94, slight oops will not cause a problem in setting time
One problem I have in not having a beautiful assistant shows itself at picture time
I was loading the latex using the time honoured 'bombs away- drop from a great height' method but when it was picture time the cup just got lower and lower anyway, here's latex pouring into the mould
I was almost out of latex so I need to order some more from Scarva
In order to get the fill height up enough to cover the pieces I'm moulding from I often fill the spaces with bits of old, not to be reused latex
I then tap the mould body vigorously with a hard implement to encourage as many bubbles as possible to rise out of the mix
Tomorrow I will (should) be able to cast from these, I'll make the 'fix' bit for my intake nose too
More busy times in the casting facility huh
Did you notice?
Yellow brick...
Didn't leak  :)
It's this red and pink junction
Out with the plasticene again  :)
There are some handy pics in there.
Probably the best thread is thread, scroll about half way down for some fore to aft nose bay shots.
You can make out the leg hinge point, but it is behind the retraction jack, think it's hard to get pics of due to being so close to the front of the bay.
There is this schematic from the Buccaneer.co.uk site, but probably not quite what you're after,
http://www.blackburn-buccaneer.co.uk/Pages1_files/Airframe_Detail_Index.html
A friend of mine had a Bucc cockpit, I seem to remember that the floor level was higher than the u/c bay roof, with the rear floor stepped up from the first.
Nice bit of casting there!
Edited by 71chally
Nice link there James, you always seem to find them, ta
I was looking at the filled mould this evening after dinner and the surface seemed hard to the touch and a cocktail stick lifted the once loose pools of resin easily so I did what my mom always said I shouldn't
I started picking at it/the walls
Et violet
hmm that looks promising
The resin is a trifle old so if anything I'd expect it to take a little longer to 'go off'
so further delving...
Dry all the way down too
I had to really didnt I?
I mean, you would wouldn't you
controlled brutality won
In winter's chill I'd expect that to take 'til tomorrrow morning
Summer bonus
Edited by perdu
Ouch! I have no doubt it'll be as good as new soonish though Bill!
I'll be interested to see how the Airwaves air brake stuff 'fits' - that's another set I bought before intrepid BM pathfinders showed the foolishness of so doing!
And as to bits deflected on parked Buccs, I am straining my brain trying to remember something a friend told me about why the inboard flaps are 'always' down on parked Bricks. But I can't, maybe something to do with some interconnection with the wing fold mechanism? Which if it is of course, you need not think about it. I did do some google 'research' a while ago when thinking about starting my CMR kit  to see if the flaps were indeed 'always' down but it's surprisingly difficult to see in many pics..
I really like that idea of bunging in the used silicon rubber to bulk up the mould - must remember that. Probably won't though!
Keith
Nope.  Never work.  Not a chance.
go barefoot - you'll find it in a few mins.
Stunning start Bill.
I'm sure you'll sort the intake and no one will be any the wiser!
   Roger
Love playing with RTV and resin moulding.  Fun all the way at the mo Bill :)
Left slipper, I kid you not
But.
Only half of it, how in the name of pierce brosnan it broke even smaller I just don't know
Anyway there is only a very small bit of MIA to deal with after breakfast ( note to Giorgio, I'm trying not to add rubbish to your already impeccable vocabulary of anglo-saxon ) so its to be a half hour of castingery
If you want pictures I'll try to handle fifteen things at once and the camera
Much appreciated, Bill :D:D
MIA = Missing In Action?
Ciao
Not sure exactly which bit of the nose oleo you are after, but hope these help:
Delicate, fragile little things, aren't they?
[XN964, Newark's S1]
Also, see PM
Crisp
Edited by Ex-FAAWAFU
PM replied
I'm trying to get "up in the 'ole" thanks Crisp
MIA ? Indeed Giorgio 'missing in action'
Some functionals for you, I could never understand how that ruddy great main gear got through such a small hole, but this helps,
Edited by 71chally
spolling
Nice video!  There is something incredibly evocative about watching an aircraft spread / fold its wings.  Since in my era the Stovies were flying jets without wing fold, I'm not sure why it stirs my WAFU soul so much, but it does.
Incidentally, Bill, are you aware that one of the main visible differences between RN & RAF Bricks is that only the Air Force had a light on the nose wheel - I assume because destroying the FDO's night vision while marshalling was close to being a capital offence.  FAA: no nose light
Watching with interest.  :yes:
I'll say this again, James is the master of finding wonders in archives
Any bugger's archives
That is a brilliant video James thank you
This build I'm happy to be being in heavy concentration on the tail feathers folding, but next time round, as I mentioned to the resident alien Martian, I'm up for all folded and canopy slid well back
Begins around November time at present rates, an S2 of the F.A.A
Unit yet to be decided
It won't be a R.A.F version though, I've already had my fill of Red Flag stupefiers
I made that Desert camo. with a green and grey tail one that was a stunner back in the day
This is my Naval Aviation period, all we artists have a blue period I understand
Edited by perdu
This is a good little set as well, but bear in mind it's a partially restored aircraft, https://hiveminer.com/Tags/buccaneer,walkaround
I actually like the idea of the wings spread, all too easy to go for the folded option every time with a carrier based aircraft.
Edited by 71chally
BTW, have you seen the 'Buccaneer' film? it was a R.Navy instructional following a crew of Bucc S.1s on Eagle c.1964, superb clear footage including Vixens, Scimitars (inc AAR with the Buccs), and Wessex.
'Hands to Flying Stations' of about 10 years later and on board the Ark is very good as well,
Some would say that I have too much time on my hands, though it seems to be diminishing to me!
Edited by 71chally
I think I can sit back awhile whilst you entertain us all James ta mate
but I wont
I did go casting this morning
first assemble the vital gear (Blunt needles via friends on here, you know who you are ;)  )
 Syringes picked up in the autojumble at Race Retro
Stick, Mr Wetherspoon
Engine bits ready for running repairs later
The moulds to work with
the needles on the left got ruined because I couldnt work out a way to remove thickening resin from uberthin or uberbent passages  :(
Next
The resin, shake well
then shake it well again a few times to distribute evenly amongst the goo
I use the syringe tube to mix the mix in, 'tain't really a good idea but when you get 'at it' the time you have is limited, so I try to keep working time to the premium
First half mixed and now the second half
Shaken AND stirred
And plunger inserted ready to pump into the moulds
then some residual resin scraped out and used to repair the intake hole damage
the best mixed resin gets hardest soonest but the drawback to mixing in the tube is that some takes a while longer
The clearerererer resin hasn't gone off yet, although it will
Just noticed I didn't do a very good shot of the repaired intake, that's it behind the mould there on the left
The little blob is hardening nicely
Cleaning out the syringe is key to long time re-use, I often use the spare resin to redo old projects, here is the syringe getting gooey gummy resin scraped out
Using the wooden sticks it is possible to reuse the syringe lots of times
when dry...
One worked
the rest didnt but the one I want did
ciao
The third door on my Midget James
The handy boot rack enables a relatively flat working surface to go with
Flat is quite important when you use scales to weigh ingredients  :)
