ColinChipmunkfan Posted May 22, 2017 Share Posted May 22, 2017 Hi All, Having built two Mk3's in the late 1960s I was really looking forward to the new version. The test shots and the marking looked really good.. I ordered 4 as soon as they were available and bought the xtradecal set as well. I am really pleased with the kit but the decals are another thing. Great schemes but mine do not adhere to any curved surfaces, it looks like cardboard stuck onto the model. I have used the Microscale system but that is struggling to cope. Is there anyone out there with some ideas that work? Kind regards Link to comment Share on other sites More sharing options...
raguk Posted May 22, 2017 Share Posted May 22, 2017 Hi, Most modellers have complained about the decals in these kits, and I also found the Xtradecal aftermarket ones not to be any better. I used hot water to apply them with this makes them a little more flexable then Daco Red strong setting soultion on the day glo strips on my build. I still had to resort to a little touch up with Hmbrol 205 in some places. Great kit though. Hope this helps, Rick 4 Link to comment Share on other sites More sharing options...
rs2man Posted May 22, 2017 Share Posted May 22, 2017 I think the dayglo decals are rather uncooperative because they're printed over a white undercoat to prevent showthrough . Fantasy Printshop do dayglo decals which don't have the white beneath making them very translucent and pretty much useless . Hot water , as recommended above , followed by several coats of the strongest decal solvent you can find seems to be the only solution besides painting the dayglo , which is a nightmare in itself . Link to comment Share on other sites More sharing options...
ColinChipmunkfan Posted May 22, 2017 Author Share Posted May 22, 2017 Thanks Raguk and rs2man for your comments, I have not tried the Xtradecal sheet yet- looks like it will be in for the hot water treatment. Raguk, I really like the job you have made of the model, as Airfix adds used to say it looks just like the real thing!! 1 Link to comment Share on other sites More sharing options...
Truro Model Builder Posted May 22, 2017 Share Posted May 22, 2017 Lots and lots and lots of Micro Set. Link to comment Share on other sites More sharing options...
CT Modeller Posted May 22, 2017 Share Posted May 22, 2017 I reckon the dayglo decals in both the kit and Xtradecal sheets are far too orange! When dayglo first appeared it was painted on and was indeed orange. But when dayglo stick-on strips were used the colour was much more of a red dayglo. I have duplicated this on a Vampire T.11 by spraying a white base, then gloss red (Humbrol), then a couple of coats of dayglo orange on top of that. This gives it a more deep red shade which to me looks more like it should. I then masked off the dayglo strips before spraying the overall aluminium airframe colour. Chris Link to comment Share on other sites More sharing options...
ColinChipmunkfan Posted May 22, 2017 Author Share Posted May 22, 2017 Hi CT, I think you are right, even allowing for scale effect. I have some samples of the original stick on dayglo strips and they are more red than orange. Link to comment Share on other sites More sharing options...
Seahawk Posted May 23, 2017 Share Posted May 23, 2017 16 hours ago, CT Modeller said: I reckon the dayglo decals in both the kit and Xtradecal sheets are far too orange! When dayglo first appeared it was painted on and was indeed orange. But when dayglo stick-on strips were used the colour was much more of a red dayglo. That would explain why, long ago, Aeroclub did two sheets of dayglo, one in orange and one in a redder shade. I bought both but was never clear when Ii should have been using which. Link to comment Share on other sites More sharing options...
meindert Posted May 27, 2017 Share Posted May 27, 2017 Check out how I handled the thick dayglow decals at my page here: https://designer.home.xs4all.nl/models/strikemaster/jetprovost-3.htm Meindert 3 Link to comment Share on other sites More sharing options...
ColinChipmunkfan Posted May 27, 2017 Author Share Posted May 27, 2017 Really liked you build link Meindert and the advice about using "tacky" Clear. Great photos of finished model. Link to comment Share on other sites More sharing options...
stever219 Posted May 27, 2017 Share Posted May 27, 2017 One thing not to follow from Meindert's build is to paint the tank tips black: Raguk's version is correct as the tips are the coloured lenses over the navigation lights. Admittedly the lenses do appear quite dark when the nav lights are off, but black's stretching it a bit. Link to comment Share on other sites More sharing options...
Spad Posted May 28, 2017 Share Posted May 28, 2017 Hair drier is amazingly effective with cardboard decals....well established technique learnt from the car modellers. 1 Link to comment Share on other sites More sharing options...
