  • Announcements
    • Mike
      Ongoing DDoS Attack causing Forum Slowness   26/04/17
      In case you have missed the announcement, the reason that the forum has been slow at times since the minor version update the other day is due to a Denial of Service attack, brute force attack on our email, and judging by the lag with our FTP response, that too.  If you're feeling like you're experiencing a glitch in the Matrix, you're not wrong.  This is the same MO as the attack in September 2016 that occurred when we transitioned to the new version 4 of the software.  We're currently working with US and UK cyber-crime departments, who specialise in this sort of thing, and we're hopeful that we'll be able to track them down this time by using the accumulated evidence already held.    We are pretty certain that it's a continuation of the same attack last year, only at a reduced intensity to deter people from using the site "because it's terribly slow", rather than taking it down completely, and we're also sure of the motivations of those responsible.  Spite.   Please bear with us in the interim, and wish us luck in dealing with these.... "people".
Ingo Degenhardt
Question Harrier Gr.1/3
12 posts in this topic
Hi all,
I am about to start the Airfix 1/72 Harriers GR.1 and Gr.3. Both have this strenghening plate on the fuselage sides which I can't find on any pictures in my reference books - but then again, this area is almost always in dark shadows.
Does anyone know if all Gr.1/3 Harriers had those or only certain aircraft. I am in doubt wether do leave them or to sand them off.
picture see below.
It might be a case of the old modeller's adage of checking your references as the strengthening plate is visible on all of the pictures of that area of the fuselage shown in the walkaround  section: Harrier Walk Around however as these are all pictures of retired rather than in-service aircraft if may be a case that the plate was added during the aircraft's life.
Hope this helps !
Edited by Richard E
This photo can be found in the walkarounds department
Full thread here.
Yes.....carefully going through my Harrier-books and paperbacks, finding nothing.....and forgetting about the walkaround-section.:banghead:
Thanks to both of you.
Remains the question wether this was a production feature or an add-on.
1 person likes this
I'll offer the suggestion that it was an add on as I don't remember seeing the panel on any of the Italeri/Esci Harriers that I've built; Esci probably took their measurements from an in service aircraft whereas Airfix presumably used a preserved example.
I'm not sure whether it helps but it looks like the panel isn't fitted to the Harrier that's on display at Duxford:
1 person likes this
IIRC That panel was a known weak spot for cracks and was an area that because of this was checked on turn rounds and A/F's. The distinctive shaped patch was mandated in  the official repair scheme. The last production batch  GR3's I believe had a stronger structure in this area so the patch may not have been seen on that batch.
Selwyn
4 people like this
Selwyn
Thanks Selwyn - Duxford's Harrier is XZ133 which was one of the last GR Mk.3s produced so this would make sense.
1 person likes this
So I think I will remove them from both kits - GR.1: too early (Airfix kit decals, Wittering 1970) and GR.3 (Airfix kit decals as XZ133, Falklands)
It may already be in your "to do" list: XZ133 was one of the aircraft fitted with a "Blue Eric" ECM pod in place of its starboard gunpod and all the GR Mk.3s deployed during Operation Corporate were fitted with an I Band transponder aerial and "bulge" under the LRMTS note and ALE-40 chaff and flare dispensers behind the air brake.
1 person likes this
Yes, I have the Freightdog Blue Eric pod and their corrected fin (height).The bulged nose/aerial and chaff/flare dispensers are kit-provided.
1 person likes this
I have to agree with Selwyn, it was an area that was prone to stress....I expect if I thought about long enough and asked a couple of grubbers we could probably work out why....but lifes to short. Not all aircraft had them but certainly a number of Sea Harriers had them.
I f you take a look at the SHAR walkround there is quite a good picture of Aircraft s/n 003 (801 NAS) has one. Granted it  not a stinky dirty Gr .
1 person likes this
