Arniec
Airfix 1/48 Gloster Javelin FAW 9/9R update 15-9-2017
Arniec    3,166
Hi guys,
I will be building the 1/48 Airfix Javelin.  It is already started, but just. So it will be under the 25%.
I have just started the cockpit and some parts are of the sprues, but noting more.
It will be build out of the box. I might get me some seatbelts or some resin seats.
I have also got a sheet from Xtradecals Javelin part 1 (X48-125).
I think I will make the 5 Squadron Javelin.
Pictures will follow later.
Edited by Arniec
Grandboof    353
Will be watching Looking forward to your start
Martin H
Col.    5,016
The big delta wing of a Javelin gives a good surface for those RAF roundels to show on :D
Arniec    3,166
Hi guys,
Here are the pictures of what is in the box.
The box top.
IMG_3979
The content
IMG_3980
And here are the part that were already done. As you can see it is not much.
IMG_3981
And the decals I am going to use from Xtradecal
IMG_3982
This is the scheme I am going to use.
IMG_3983
I hope to start this after finishing my Mosquito in another GB and a Churchill AVRE that I want to take with me to a show in two weeks.
That is it for now.
Edited by Arniec
FortyEighter    295
Nice choice!
I did consider this one myself but think it will stay in the cupboard a bit longer as I intend to build a couple of airliners for the GB.
Hockeyboy76    2,319
I am tempted by one of these, so will be following your build with interest.
Arniec    3,166
I have made some progress today as I was modelling at a friend home. I have put the seats together, intakes and exhaust pipes. As I was doing the intakes and exhausts I noticed some sinkmarks in there. So I have now decided to close them up with the plates provided with the kit. I also need to think about some seatbelts.
I dry fitted the fuselage as well and it looks very good at this point.
I have no foto's jet, hope to do some this weekend.
Arniec    3,166
OK guys here are some pictures.
The cockpit nearly ready for some paint. I still need to do some seatbelts.
IMG_4005
And here you can see the testfit of the intakes and exhausts. As there are some pinch marks inside the inlets and exhaust pipes I have decided to take the easy way out and use the blank off plates that are in the kit. I also had a misalignment with one of the exhaust plates. I removed the tap to get a better fit.
IMG_4006
And here is a picture of the test fit with the top fuselage and also with the front fuselage. It seems to be a very good fit. I like these new Airfix kits a lot!!!
IMG_4007
That is it for now.
Edited by Arniec
Shermaniac    1,226
I'm not particularly good a Aircraft but I do rather like the Cold War Jets
Arniec    3,166
Me to Shermaniac.
In the past I was just interested in WW II projects, but now I like the early jets as well.
But here is again a update. I have started painting some parts.
Here is the cockpit done. I painted it first black and then gave it a coat of German grey from Tamiya.
IMG_4012IMG_4013
And the exhaust were also painted black. This will later get a coat of metallic paint.
IMG_4016
The cockpit still needs to get a wash and some detail painting before I can put it into the front fuselage.
This is realy a nice kit. Airfix has done well.
Edited by Arniec
Arniec    3,166
OK guys, the pictures are reloaded.
Arniec    3,166
It has taken some time to get this one going. It wasn't the kit (witch is great!!!!!), but me. I got distracted with some other models.
Here are some pictures of what has been done sins Monday.
I dry-brushed the cockpit with some medium grey colours and also gave it a wash.
Here is the result.
IMG_4106IMG_4107IMG_4109IMG_4111IMG_4112IMG_4113IMG_4114
And this was done today. I closed the cockpit and placed it inside the fuselage. It is realy a great kit to build. It is so well engineered.
IMG_4115IMG_4116
The clamping was just done to keep the inlets in the right place as the glue dried.
And the last one with the fuselage closed. I needed two cocktail sticks to get the inlet inline with the under fuselage.
Again nothing to serious.
IMG_4117
That is it for now.
Arniec    3,166
Here is a update what has been done till today. The most time I had was on Sunday and there I worked on all the seams, before I could put it further together.
After this it was mainly putting on small details.
here are some pictures to illustrate the progress.
The model on sunday evening.
IMG_4118IMG_4119
And this is where she is now. I forgot to take a picture from the topside:doh: But there aren't much changes there.
IMG_4121
I have also made up the missiles. I also dipped the canopies in the new Klear, but don't know what happened. It looks like it didn't gave it a even look. Now I will need to remove it without marring the parts.:boom: Does somebody know how to do that?! I have never had this before.
There is still a few things to do before I get to the painting stage. Hope to do that next week.
Arniec    3,166
Luckely I have found a method (online, so not my own thinking) for removing Klear from clear parts. phew:clap2:
If you use some windex with some Ammonia in it. Dip the part in for a short time you will see that it becomes milky again and then you can whipe it of. If there still is some klear left, just do it for a second time.
I have redone my clear parts just a few minutes ago.:yahoo:
Edited by Arniec
Arniec    3,166
She is now ready for some paint.
IMG_4137
Biggles87    3,146
I've only just found this. I like what you've done with the cockpit, 1950s and 60s black cockpits are always difficult.
I started one of these some time ago and then stopped to finish something else. I still havn't finished the other kit ( Spitfire ) but when I do I might get back to mine.
John
Arniec    3,166
So, painting done in the last couple of days.
Here are some pictures starting with some pre-shading and ending with the underside painted in alluminium that should represent high speed silver.
IMG_4138
some dark sea gray.
IMG_4139
masking
IMG_4140
green on
IMG_4141
the result.
IMG_4142
and alluminium on
IMG_4143
This now needs to dry.
All the paint is from Gunze.
Hope to put some Klear on tonight or tomorrow morning. So that I can put the decals on on Sunday.
Arniec    3,166
I am not going to make it. Sorry guys.
I started to do the decals, but I didn't have time to finish it.
nimrod54    4,383
That's a shame Arnold, it's really well painted. I hope to see it in the future, once you get around to completing it.
