Hardtarget Posted May 7, 2017 Share Posted May 7, 2017 (edited) I shall be starting with this. Im on a role with big jets at the moment. A big box DSC_0015 by stuart wellard, on Flickr With a lot of goddies inside, most of which are weapons so il try to use some on this A/C. DSC_0016 by stuart wellard, on Flickr Edited September 3, 2017 by Hardtarget 7 Link to comment Share on other sites More sharing options...
Hewy Posted May 7, 2017 Share Posted May 7, 2017 This looks to be a really nice kit stuart, I'll look forward to watching this coming together Glynn Link to comment Share on other sites More sharing options...
AngstROM Posted May 7, 2017 Share Posted May 7, 2017 This looks like one of Trumpeter's better efforts; I have the kit myself and have been noodling around detailing the gear bays (anything rather than actually finishing something!) -I'll grab an observation berth here if I may! 1 Link to comment Share on other sites More sharing options...
Jabba Posted May 7, 2017 Share Posted May 7, 2017 A good choice and it is a good kit to build. Link to comment Share on other sites More sharing options...
Basilisk Posted May 8, 2017 Share Posted May 8, 2017 Welcome to this GB comrade. Great to see a type being built which is not yet represented. Cheers, Peter Link to comment Share on other sites More sharing options...
Sobby_23 Posted May 8, 2017 Share Posted May 8, 2017 Looking forward to this. I built this kit at the tail end of last year, fun little kit! Link to comment Share on other sites More sharing options...
SoftScience Posted May 8, 2017 Share Posted May 8, 2017 There is a great step by step video of this model being built. 3 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 8, 2017 Author Share Posted May 8, 2017 Ah yes Plasimo or is that scale moddeling, yes am aware of them both and actually was partial inspiration for this build. Link to comment Share on other sites More sharing options...
AngstROM Posted May 8, 2017 Share Posted May 8, 2017 If you feel the need for reference walkarounds, have a look on Cybermodeler Online. Most are links to an admirable Russian site, and one (Su-24MR) runs to SIXTY-FOUR PAGES of up close & personal! So no excuses... 1 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 8, 2017 Author Share Posted May 8, 2017 Thanks will have a look. I have Yefim Gordons Su-24 book to hand. 1 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 13, 2017 Author Share Posted May 13, 2017 This week has seen quite a bit of progress so here update as follows. I started off with the main wheel wells which are made from 4 for the front and 6 for the rear. no real fit problems but notorious with trumpeter kits is the spru gates on the return of the edeges so you need to b ecareful throughout this build to shave and sand them off. DSC_0015 (1) by stuart wellard, on Flickr Next it was the turn for cockpit assembly. Againt no real issues except the positioning of the IP with the picture suggesting that the pins from the IP insert into the recessed of the main tub. they dont!, they are completely different sizesand you have to rest this IP onto o fthe control columns. There is also not much space between the control sticks and the IP. DSC_0017 by stuart wellard, on Flickr Main fuselage top and bottoms were up next with plenty of holes to be drilled and slots cut out. ( i never find an easy ways to cut slots) DSC_0016 (1) by stuart wellard, on Flickr Nose halves hold the cockpit tub in place. I had a bit of a fit issue here but nothing thats not difficult to rectify with some filler. Tape was needed to hold it altogether. DSC_0018 by stuart wellard, on Flickr Main fuselage and nose section cemented together. The main join between the two can be tricky and may requrie filler depending on how well you fit the two. DSC_0019 by stuart wellard, on Flickr I found a poor fit of the exhaust shroud at the rear of the fuselage and needed a bit of fettling to fit. DSC_0021 by stuart wellard, on Flickr Wings were next consiting of three parts. ive gone for flaps extended but you can have them retracted. Once they were cemented Trupeter have a an intereesting way of fittin gthem to the fuselage with a clamping system. Inserts on the underside of the fuselage are used to clamp the wings. DSC_0022 by stuart wellard, on Flickr Now this little part on top of the fuselage apparently fits inthat recess however it does not unless you remove that little bit of plastic that holds the tub in place. So duly removed the window actuator now fits. DSC_0023 by stuart wellard, on Flickr 2 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 13, 2017 Author Share Posted May 13, 2017 The tub was then airbrushed using MRP Sukhoi cockpit blue-grey 195. Decals were added once dry which this laqur based paint does extreamly quickly. DSC_0025 by stuart wellard, on Flickr Lumps and bumps were next and there are a few of these as well. DSC_0026 by stuart wellard, on Flickr DSC_0027 by stuart wellard, on Flickr Returning to the cockpit, seats were airbrushed tamiya XF-85. DSC_0031 by stuart wellard, on Flickr 3 Link to comment Share on other sites More sharing options...
Jabba Posted May 13, 2017 Share Posted May 13, 2017 Nice start especially in the cockpit. When I made mine I looked at having the flaps extended, but when I found out that the slats are also extended at the same time I left them into the wings. 1 Link to comment Share on other sites More sharing options...
Hardtarget Posted May 13, 2017 Author Share Posted May 13, 2017 4 minutes ago, Jabba said: Nice start especially in the cockpit. When I made mine I looked at having the flaps extended, but when I found out that the slats are also extended at the same time I left them into the wings. Yes it is a shame why they do one and not the other. Bit of a contrast to my F-111 build which has both. Link to comment Share on other sites More sharing options...
Jabba Posted May 13, 2017 Share Posted May 13, 2017 30 minutes ago, Hardtarget said: Yes it is a shame why they do one and not the other. Bit of a contrast to my F-111 build which has both. And they are not the only ones as Fujimi do it with their Intruders. Link to comment Share on other sites More sharing options...
AngstROM Posted May 13, 2017 Share Posted May 13, 2017 4 hours ago, Jabba said: When I made mine I looked at having the flaps extended, but when I found out that the slats are also extended at the same time I left them into the wings. Just had a look in my Fencer Folder -there seems to be a lot of parked (unoccupied) aircraft, including one at a MAKS show, with everything tucked away. I think that's how mine will end up! Link to comment Share on other sites More sharing options...
Basilisk Posted May 14, 2017 Share Posted May 14, 2017 Great progress. Looks like a nicely detailed kit. Cheers, Peter Link to comment Share on other sites More sharing options...
Hardtarget Posted June 26, 2017 Author Share Posted June 26, 2017 Has it really been over a month since the last posting! Right better give you an update then..... She's on her legs and primed rady for the grey DSC_0003 by stuart wellard, on Flickr MRP SU-27 grey sprayed on beautifully. Love this laqur paint, so smooth. DSC_0004 by stuart wellard, on Flickr Masked up and sprayed using Vallejo MA white mixed with a bot of brown to give it a off white hue. DSC_0005 by stuart wellard, on Flickr Masking removed DSC_0029 by stuart wellard, on Flickr Ready for clear coat and decals. DSC_0030 by stuart wellard, on Flickr 8 Link to comment Share on other sites More sharing options...
Valkyrie Posted June 26, 2017 Share Posted June 26, 2017 Yikes this is looking great. Not seen one of these built, looking good. Big beast this one! Link to comment Share on other sites More sharing options...
Basilisk Posted June 28, 2017 Share Posted June 28, 2017 Very nice paint job! Yes, MRP lacquer is indeed very nice to airbrush. Cheers, Peter Link to comment Share on other sites More sharing options...
Jabba Posted June 28, 2017 Share Posted June 28, 2017 Nice work with the paint job. Link to comment Share on other sites More sharing options...
Hewy Posted June 29, 2017 Share Posted June 29, 2017 I agree the su is looking gorgeous,she'll sit next to the 111 very well, a match if ever there was one , i have a 1/48 su24 to build later in the year to sit along side my 111 very nice stuart, Glynn Link to comment Share on other sites More sharing options...
Hardtarget Posted June 30, 2017 Author Share Posted June 30, 2017 Thanks guys, much appreciated. There is somethign about swing wing aircraft. I must finish my Tu-160 at some point. She in the current static park needing final sanding before priming and painting. Link to comment Share on other sites More sharing options...
Hardtarget Posted September 3, 2017 Author Share Posted September 3, 2017 Ok, its been far too long since i did anything on this project but focusing on this in the last week has enabled it to get finished. I assembled and affixed the selected ordinace and weatehred using a oil washes, a mixutre of grey and sienna. Here are the finished photos DSC_0102 by stuart wellard, on Flickr DSC_0103 by stuart wellard, on Flickr DSC_0104 by stuart wellard, on Flickr DSC_0105 by stuart wellard, on Flickr DSC_0106 by stuart wellard, on Flickr DSC_0107 by stuart wellard, on Flickr DSC_0108 by stuart wellard, on Flickr DSC_0109 by stuart wellard, on Flickr DSC_0110 by stuart wellard, on Flickr DSC_0112 by stuart wellard, on Flickr DSC_0113 by stuart wellard, on Flickr DSC_0114 by stuart wellard, on Flickr 7 Link to comment Share on other sites More sharing options...
Valkyrie Posted September 3, 2017 Share Posted September 3, 2017 Oh wow, that is super all finished. The weathering on the white is perfect, what a build, very nice Link to comment Share on other sites More sharing options...
