Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
Antb
1/48 Eduard BF110C- Who doesn't like a shark mouth?
105 posts in this topic
That pit looks the business! Really great paint work. Bravo. :yahoo:
Edited by The Spadgent
1 person likes this
Cheers John,
good to to see you back in model land :D
Magnificient looking cockpit!
Eduard Etch is just lovely, especially when you don't need to bend or fold it!
1 person likes this
Thanks Christer.
Yes it's nice that hardly any of the PE needs folding. Other than the belts there hasn't been anything.
I have to admit I've left a couple of small bits off that you can't really see such as the handles on the cannon ammunition drums. Painted black they don't stand out and they're tiny so left them off.
The PE does add a lot to the model. Think the profipack kits are worth every penny.
3 people like this
Evening
Bit more progress to report and some fit issues which I don't know if it's the kit or me.
Following on from the completion of the tub the next step was to add the cover to the observers position. It wasn't a great fit
A little better the other side but there was quite a step at the top. Time to crack out the filler. Now unfortunately there was some really nice tiny rivet detail along the panel lines and there was no option but to obliterate it. I tried the best I could and you can see the result below in a pic or two further on
This was the initial fit from the other side
On with the filler
Out with the sanding stick and we had this
I slapped some paint on to check what it looked like and to be honest I was surprised that it looked ok. Wouldn't have thought it from the state but it was.
After that came the nose guns and the nose itself. Quite why eduard have moulded the nose seperate rather that it being an actual part of the fuselage I will never know. It just doesn't fit. Or is it me again?
The fun bit first. We have this
Which was fiddly but went together ok. This then turned into this
While the wash was drying And before the gun assembly went into the bottom of the nose I tried a dry fit.
AAAAAAARRRRRRRGGGGGHHHHHH!!!!
I was hoping that because the gun tray hadn't been put in yet it hasn't stretched to the right shape. Wrong....
And I'm now in a position of filling the gaps and trying to fill the step, sanding, and repeating. I will get there.
I don't think part of the nose assembly should be showing through the cannon ports but it wouldn't fit in any other way....
It looks a lot rougher than it is and I've been using a fine sanding stick! Looks like I've been at it with a cheese grater.
Anyway, that's where we are at as of this evening no work now for a few days as am working away and it's my son's birthday on father's day so we have a busy weekend ahead.
If you've read this far thanks for your patience I hope you're enjoying the uodates.
I'm enjoying the build it's good fun and it's coming together really nicely. Have to admit though, I wasn't expecting these issues on the kit as everything had gone together really well so far.
Wings next. Should be fun. Bet they don't fit!
Edited by Antb
3 people like this
Looking good Antb.
I've heard there are a few dodgy areas on these kits, I think you've just found them... thank god for filler and sanding sticks I say!
The other area of concern, so I'm told, are the engine nacelles, but don't let that worry you. :worry:
gazza l
1 person likes this
Ouch!
Lots of fit issues there.
I would have added plastic shims to the under side for the observers cover, so that I could sand it to fit, without destroying all those lovely details.
Somewhere on the interweb there was a tips & trix for the Eduard 110E, I'll see if i can dig it up later on tonigth.
Good luck with the nose! Lets hope the big sharkmouth covers the worst...
1 person likes this
Hi Christer
Thanks for the reply and the information.
're the shims in still pretty new to modelling really so learning as I go so it certainly is something to think about in the future rather than using filler.
I did a quick test of the wings and there's some serious gappage so I will probably have to fill with some plastic card.
Thanks again really appreciate your input
1 person likes this
On 6/14/2017 at 23:38, gazza l said:
Looking good Antb.
gazza l
Hi gazza
Sadly I've heard that too but let's see what happens that's the next stage as I left the wings setting when I went away.
Hey guys.
Engine nacelles. Nothing more I can say other than what the jeepers eduard were thinking.
Here's the pics.
This is an initial dry fit. Not bad
Terrible
And a test fit with the other side on.
Ridiculous
I decided not to glue the nacelle Yves together before fitting and I'm glad I didnt. They would never have fit.
Out with the sanding stick removing part of the leading edge to get a better fit.
Well worth the effort in the end I think
They're as good as they're going to be and only a small amount of filler should sort the gaps
I've left them to dry for now so next up more filling and sanding.
2 people like this
You're finding all the horrible issues with this kit! I thought it enormously disappointing when it was first produced because I was expecting a "state of the art" Bf110 to replace the ancient Revell/Monogram kit, but given a choice (and I'm talking G4s here) I'd still go for the latter.
Max
1 person likes this
Evening guys
Another small ish update this evening. With the wife away with work and the kids tucked up in bed I had every intention of doing a serious amount of modelling.
However the combination of the heat and more fit issues have meant I've given up and will fight another day.
I did get some work Done, however.
First up the engine nacelles got completed and the wheel wells got their details added.
Here's the nacelles before the wheel wells got detailed. Just realised I haven't photographed the wells something I will do when I've painted and shaded.
I will wait and see what work is needed once the primer has gone on as it's difficult to tell at present.
The tail 'fin' got added. Absolute nightmare. The attachment point doesn't lock into the pieces they just sit together and they just keep dropping hence the amount of tape holding them in place.
And we have wings
Given how low the wings are it's easier to sit them on the desk and wait for the glue to set rather than try and support the wings with the fuselage.
Once again the fit isn't great. Haven't looked at the underside yet due to the weight of the wings and the fit but if it's like the top there will be gaps to fill.
I'm thinking of a plastic shim as @Christer A suggested. Assume that this is just a piece of plastic inserted into the gaps and sanded to fit so as not to affect the detail of the surface?
And there she will stay until tomorrow Evening when I can hopefully get more done and ready for priming.
Thank you if you are taking an interest in the build. Despite the issues it's enjoyable and I hope im doing a decent job of it.
3 people like this
Max
Thanks Max
I'm not sure how much of the issues are my modelling but yes there's a few for sure.
It is disappointing but who needs an easy build? Ha
Well despite the fit issues your having it seems to be coming on nicely.
Just out of interest I done a dry run of my G-4,s nacelles this evening and they don't seem too bad, just a large gap
at the rear where they meet the flaps.
gazza l
1 person likes this
I'm certainly following along. I offloaded one of these kits (can't remember which mark, now) when I discovered the nature of the issues, but I've clung resolutely on to a C-6, so I have all this to come, and your work will be an invaluable guide (thanks!)
1 person likes this
Yes, thin strips of plastic. Like these:
That can be inserted into the nasty wing rots and will form a basis for a smoother join.
You still need some filler though, but it helps bridging the gap.
Keep at it! You'll bet this kit in the end!
1 person likes this
gazza l
You're a lucky chap Gazza if that's the case! To be fair it wasn't a massive job to sort the issues out it's just annoying as the kits great, it's just some things really let it down.
Thanks mate. Appreciate your comments
 Christer that's fab thank you.
I know it might seem obvious but I've never used shims with builds before and always just gone filler. It's probably the easiest and simplest thing in the world but I'm learning as I go with this build and i am really enjoying it.
I'm enjoying the challenge so much that I'm even considering going into scratch building bits when I start the 1/24 Spitfire I got last weekend. There's a challenge.
I'd build another eduard 110 kit just maybe go for a different version.
Thanks again chaps
Keep at it! You'll beat this kit in the end!
Edited by Christer A
I've got this kit half built in the loft. I got to the engine nacelle point and gave up, you're doing a great job with yours- keep at it!
1 person likes this
Thank you @Ade
Hope you pick it up again and we get to see the finished article
You are overcoming the fit issues well but I am rather surprised that they are there at all given that this is a relatively recent Eduard kit.
Martian
1 person likes this
Martian
Thanks martian. It does make me wonder whether it's more me than the kit.
To be fair I don't think it is but it does make me wonder somewhat.
1 person likes this
I don't think it can be you. I have gone back and had a good look at the build again and it is clear that some of the parts don't even come close to matching up.
Martian
1 person likes this
To assure you that it's the kit and not you, I've dug out some images from my model of the G4 which, incidentally I was reviewing for Scale Modelling Now.  As can be imagined, my review wasn't totally complimentary about Eduard's 1/48th Bf110!!
Max
1 person likes this
