  • Announcements
    • Mike
      Ongoing DDoS Attack causing Forum Slowness   26/04/17
      In case you have missed the announcement, the reason that the forum has been slow at times since the minor version update the other day is due to a Denial of Service attack, brute force attack on our email, and judging by the lag with our FTP response, that too.  If you're feeling like you're experiencing a glitch in the Matrix, you're not wrong.  This is the same MO as the attack in September 2016 that occurred when we transitioned to the new version 4 of the software.  We're currently working with US and UK cyber-crime departments, who specialise in this sort of thing, and we're hopeful that we'll be able to track them down this time by using the accumulated evidence already held.    We are pretty certain that it's a continuation of the same attack last year, only at a reduced intensity to deter people from using the site "because it's terribly slow", rather than taking it down completely, and we're also sure of the motivations of those responsible.  Spite.   Please bear with us in the interim, and wish us luck in dealing with these.... "people".
44 posts in this topic
On ‎16‎.‎05‎.‎2017 at 1:01 PM, NAVY870 said:
What it is though is a nice little A-4K with the hump and square fin tip.
It should also be suitable for an H pre tailpipe Extension, though I'm not sure whether it contains the DEFA "gondolas".
BTW, congrats grandpa !
On ‎16‎.‎05‎.‎2017 at 3:12 PM, Uncle Uncool said:
Is it the same kit? Unc2
Not sure about the Ertl timeline, but Ertl took over US Distribution of Esci from ScaleCraft some time around 1982 or so. I rather think this is a boxing from after Ertl bought Esci, so would be around 1988 or so. The mould was something like ten years old then. Ertl did some re-releases of the Basic mould afterwards (red boxes), but I ***think*** the mould went rather dormant after ca. 1995 or so, though I admit I haven't kept track of Italeri's reboxing cycle. Note that many earlier Esci kits suffered from distorted Frames and sometimes parts as the Esci boxes tended to be somwhat small for the Frames, though I think this is a kit-to-kit issue.
Thanks mate, another one to spoil :)
On 2017-5-17 at 3:00 AM, NAVY870 said:
If your going to backdate the Esci kit to a P or Q you'll need a short nose, new intakes change a lot of panel work on the forward fuselage and add the various antennaes that the Argies glued on.
I may have a short nose from a Hobbycraft kit in the junk box, you can have it if I can find it.
Hey, Steve! :worthy:
Well, yeh, certainly, I could use that short nose, provided you can find it. Thanks a lot! Everything else for the Argie Scooters I can scratchbuild, even the kit intakes. Tell me if you need me to help with postage, please.
Unc2
Edit: Thank you too, tempestfan, for the info regarding the Esci/Ertl boxing! I hadn't see it.
Edited by Uncle Uncool
Because I'm going blind?
On 16/5/2017 at 2:01 PM, NAVY870 said:
The A-4M/N kit you mentioned isnt either of those marks, missing the larger canopy big bore intakes
internal starter exhaust and a few other bits.
IIRC it doesn't come with the brake chute housing under the tailpipe that the real A-4K had so it's not good for that variant OOB.
Edited by Panoz
It does have the DEFA gun parts.
But the A-4H also had the brake parachute fairing so it's not good OOB for that variant either...:whistle:
Edited by Panoz
It has a fairing, I'm not sure what its supposed to be but
it can be beaten into shape for the brake chute.
Those of us who used our Scooters properly didnt need brake chutes, we used deck hooks
as God intended!
Edited by NAVY870
3 people like this
That was from memory, if it has a fairing shape then it's all OK...
Here are sprue pics, there are four flashy parts on the C sprue sub-Frames (Looks like duplicated parts numbering) that I ****think**** are meant to represent the Container, as Steve pointed out.
1 person likes this
Yes you are both right.  It does come with the para brake housing.
BTW never realised that the Italeri rebox also had the hump sprue from the "M/N" kit...:hmmm:
Edited by Panoz
Well, now I'm puzzled, 'cause if that's the Italeri rebox of the ESCI M/N kit, mine has got the squared tail fin on it, not like that on the Italeri rebox sprue.
Thats them
Just for the record the kit isnt a G and cant be built as one from the box.
The kit is an early E model sans NWS spoilers and a few other bits and pieces.
the 88 series A-4G's were new built as G's the 87 series were rebirthed ex USN F's
I'm not sure what the creatures are on the roundels but they dont appear to the the usual red rats
Unc2
No go on the B nose but I have a complete Hobbycraft A-4C fuselage your welcome too.
You could combine it with your kit
Edit: also found the big oval antennae fairing fitted to the spine of the Argie birds, yours as well.
Edited by NAVY870
G'day, Steve!
Oh, bummer about the B nose, but that's such a generous offer anyway; thank you very much!
The ADF antenna on the spine could be of use to me, but I guess the shipping cost from beautiful Aussieland just for that part would be nonsense. I think I can source a conversion set from our local Aconcagua Resin Models store for that price.
Hey, will gladly get you any set you want from them if so you like.
Thanks, Steve! :cheers:
Unc2
That's the VLF Omega antennae.
1 person likes this
No, not the bulging fairing over the spine, which is the ADF, as I stated above. The Omega is another antenna which was not installed on every aircraft.
Like Steve said previously, the Argentinean Scooters had quite a lot of antennae "glued" :lol: on them; here on the A-4Q:
Hope it helps, Antoine.
Unc2
Both are part of the system, the one you show being the simpler GNS-500 E-Field antenna, while the more complex flat-shaped Antenna Coupler Unit is under the dorsal oval fairing.
Are you sure about that, bud? Every Scooter in Argie service has got the dorsal oval fairing on the spine, but this is not the case with the Omega equipment.
During the war for the Falkland there was a flight of Scooters whose leader got shot down, leaving his wingman without the possibility to rendezvous with the tanker while RTB owing to his aircraft not being fitted with the Omega equipment.
I'm not 100% sure about this, 'cause I don't know the exact fit of COAN & FAA Skyhawks, and I've never seen anything definitive about this since I started to gather informations on the subject, a loooong time ago.
But I'm sure the oval shape is too big for a simple ADF antenna.
Basically, there are two kind of Omega system for aircraft.
One quite simple, usually fitted to small civilian aircraft, with the saber antenna shown on your pics.
The other much capable, just a bit short of today's GPS, need the flat-shaped antenna coupler unit and different black boxes in the fuselage and cockpit.
This said, I've never seen the saber antenna in any pics showing a COAN/FAA Skyhawk during the war.
And beside, the antenna dorsal fairing presence doesn't mean that the antenna and the whole system is there, it just shows that the aircraft is wired.
Anyway, I'll be happy to be proved wrong, or right, but with hard fact.
Perhaps it's difficult to find piccies of it because there were only 2 A-4Qs with the VLF Omega installed during the war, and as I said, the antenna is the saber one installed on the spine - behind the canopy - on the COAN birds; while it was below the radome - close to the emblem of the Grupo 5 de Caza on the few FAA A-4P birds which had it installed during the war, if there was any (I surmise there was just one).
As for the FAA A-4Cs, they had the VLF Omega Litton LTN-211, of which I couldn't real tell how many had it operative during the conflict.
Unc2
