  • Announcements
    • Mike
      Ongoing DDoS Attack causing Forum Slowness   26/04/17
      In case you have missed the announcement, the reason that the forum has been slow at times since the minor version update the other day is due to a Denial of Service attack, brute force attack on our email, and judging by the lag with our FTP response, that too.  If you're feeling like you're experiencing a glitch in the Matrix, you're not wrong.  This is the same MO as the attack in September 2016 that occurred when we transitioned to the new version 4 of the software.  We're currently working with US and UK cyber-crime departments, who specialise in this sort of thing, and we're hopeful that we'll be able to track them down this time by using the accumulated evidence already held.    We are pretty certain that it's a continuation of the same attack last year, only at a reduced intensity to deter people from using the site "because it's terribly slow", rather than taking it down completely, and we're also sure of the motivations of those responsible.  Spite.   Please bear with us in the interim, and wish us luck in dealing with these.... "people".
Bitzer
Airfix 1/72 B5N2 Kate CarDiv5 Shokaku WIP
19 posts in this topic
I'm starting the Airfix 1/72 B5N2 Kate and decorating it in the Shokaku Carrier Division 5 clan. I will be fitting it out in the stored, but armed configuration as it would have been in the hanger deck prior to an attack.
The kit has a fairly large parts count considering it's a 1/72 scale kit.
There is a picture of EI-311 landing on the Shokaku in April 1942 but can't seem to locate it right now.
The Kate was arguably the best carrier borne level and torpedo bomber at the beginning of the war but soon was easily bested against the Allies due to its lack of speed and armor. It was to be replaced by the B6N Tenzan or "Jill" which was late due to teething issues in development. The Kate would solder on through 1945 without shamefully, a single one surviving to the end. The Kate is one of my favorite planes and because of that I'm astonished I have never built one before.
Beginning on the kit, the steps have me starting with the wings. Cutting the wings along the intended line was very easy. The kit is made from the soft but very workable Airfix plastic. The sight window is also installed and holes are drilled for whichever armament will be used if any. The wing ribs at the folds are way too thick for this scale but make installation easy. I don't believe the thickness will be noticed once the kit is complete.
The cockpit is molded in the lower wing. The seats, controls and such are added to the wing section.
More to come soon.
6 people like this
Ooh, an early-ish Kate, I'm in, Bitzer :popcorn:
Stew
More to come soon.
1 person likes this
"There is a picture of EI-311 landing on the Shokaku in April 1942 but can't seem to locate it right now."
My boo boo, the pictures I was thinking of were of the Kate AI-301 in April 42 on the Akagi....which is my next build. The 1/72 Hase Kit. Looking through that kit, there is a world of difference. I prefer the Airfix kit far more.
1 person likes this
A little more on the Kate today. The pit is installed and painted as well as the interior fuse. Next will be mating the fuse and wings then adding the stabilizers and rudder. The kit is fitting very will and the interior detail is quite nice.
10 people like this
Looks like an interesting build, mind if I follow along?
Sure Antb, There's room.
Continuing on with the Kate. I attached the fuselage to the wings and vert stabilizers to the fuse. The only complaint I have with the kit, which is easily remedied with a little trimming and sanding, is the attachment point of the wings and stabilizers to the parts tree. The attachment points are big and invade on the surfaces. But like I said these are easily remedied.
If you decide to build this kit, be aware of the gauge at the bombardier's position. The panel it is attached to came loose while installing the fuselage because the gauge slips into a slot on the fuse. This was easily fixed bit reinstalling the panel after the fuse was on.
The gaps at the wings and stabilizers are very small and the fit is tremendous IMO
I really like this kit. Good on ya Airfix!
1 person likes this
I worked on the seams tonight, painted some grey to check for smoothness and sanded a little more. I then went over the panel lines to remove the Mr Thinned Putty and I think that should do it.
Tomorrow night I'm spraying silver for a base for some chipping. Japanese aircraft weren't as worn out and chipped as they were at the end of the war but there was some. I also sanded and smoothed the torpedo. I'm not going with the Type 91 modification 2 Torpedo which was used at Pearl (adding the wooden fins) because I'm building this as a May 1942 time frame. The kit is awesome enough to include the wood fins for the Mod 2 torp, but doesn't seem to include instructions to add the modification to the kits torpedo.
3 people like this
Hi Bitzer,
That's coming together really nicely now, good work B)
Stew
I sprayed the silver on the kit and will start with the base coat tomorrow.
1 person likes this
Looks smooth B)
At the risk of appearing to be trying to teach you how to suck eggs; you won't be chipping the fabric covered surfaces?
Stew
LOL, no Stew, I won't be.
I sprayed the black nose then the overall grey base coat. The upper surfaces have green squiggles and blotched which I hope to get to tonight.
1 person likes this
Now it's time for a wash then a dull coat. The open canopy is molded together so is somewhat interesting to paint. I'll install the wings after the canopy is attached.
6 people like this
She looks excellent mate, really nice paint work!
i like the idea of building a few Japanese aircraft, maybe the Kate should be one
Rob
Thanks Rob,
Airfix really did a nice job on this one. The decals are a little thick but nothing that a setting solution can't handle.
While I have 3 or 4 Hasegawa Zeros I want the Airfix kit abd I hoping they will be making a Val.
1 person likes this
29 minutes ago, Bitzer said:
Thanks Rob,
I have a new tamiya zero in the collection but it would be rude for it not to have any mates to hang out with!
Looking forward to the rest of your work
Rob
Coming along nicely!
Mike.B)
Thanks Rob and Mike!
I moved the completed build to Ready for Inspection.
I forgot to hit Submit Reply a few days ago...sorry. :unamused:
Edited by Bitzer
6 people like this
