Mike Posted May 3, 2017 Share Posted May 3, 2017 Mig-25RBT Updates (for ICM) 1:48 Eduard ICM's new Foxbat kit is gorgeous, and goes together really well, but as always with injection moulding you can do some aspects better with Photo-Etch. Along comes Eduard with a small collection of PE sets and a set of kabuki tape masks to make your life easier, and the detail better. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Interior (49815) Consisting of two frets of PE, one of which is nickel-plated and pre-painted, the other bare brass, this set adds extra detail to the cockpit that would be difficult, if not impossible to add via scratch-building. After scraping the detail from the sidewall, consoles and instrument panel, new panels are installed with detail picked out in relief and colour, plus a set of new sidewall skins with panelling details added. The main panel is split into several parts, laminated together to create a more realistic whole, replete with instrument dials behind the bezels. The seat is upgraded with a seat cover, more accurate pull handle, leg straps, and a new detail insert for the top of the headbox, whilst behind it the rear bulkhead is given a skin of riveted metal instead of the raised detail that was provided in the kit. After replacing the rudder pedals with more detailed parts, the rest of the set is used to improve the detail on the canopy, including sill details, internal structure, canopy and windscreen hoops with rear-view mirrors, and the seals around the moving section. Speaking personally, detailing the canopy give a big boost to cockpit detail, and the addition of the parts can make a great deal of difference. Zoom! Set (FE815) This set contains a reduced subset of the interior, namely the pre-painted parts that are used to improve on the main aspects of the cockpit, as seen above. Whatever your motivations for wanting this set, it provides a welcome boost to detail, without being concerned with the structural elements. Seatbelts STEEL (49816) Eduard's new STEEL seatbelt range combines the simplicity of pre-painted Photo-Etch (PE) belts with the thin, flexible steel that they now use, resulting in seatbelts that look more in-scale, and are easier to bend to drape more naturally over the ejection seat or crew seat as the case may be. The paint used also seems more flexible, and better able to cope with the rigors of fitting the belts into position without cracking and peeling off, which was sometimes a danger with the previous nickel-plated brass types. As well as coming pre-painted, they are also shaded to imply further depth to the buckles and overlaps, with the clasps, slides and attachment points showing bright in conjunction with the painted portions. Exterior (48918) This set is supplied on one larger brass fret, and contains plenty of parts to improve the detail further. The nose gear bay is skinned almost completely with a number of highly detailed parts, layered to give a better indication of depth, while the bay doors are given hinges and interior skins to complement. The main bays are skinned along the less detailed edges at the bottom of the bay, which is also the area most seen, with the bay doors also receiving some attention in the shape of panels, hinge-lines and brackets. The main legs are improved by the replacement of one of the arms by a detailed assembly that better represents the original, plus a set of hoses, and a hub detail part for the wheels. The intakes have new skin sections to better replicate the detail of the perforated area in the roof, and a skin for the dropped intake "scoops" at the bottom of the intake that sucks in more air at low speeds. Detail panels are added to the guide vanes that hold the intakes away from the fuselage, although little will be seen of these at the end of construction. Careful test-fitting will be needed here also, just in case it affects fit of the parts. At the front of the engine a fan enhancement is added, with the afterburner ring being more delicately depicted by fine PE parts, which are fitted with a centre section so that they are drop-in replacements for the kit parts. A side profile shows the correct shape for the rings after installation, which is conical. Between the exhausts, small parts are added to the wedge-shaped fairing, the separator between the closely spaced exhausts, as well as a small ring under the para-brake pen-nib fairing between the tails. Masks (EX545) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape. In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort. Conclusion As I'm half-way through building this kit, which was initially going to be out of the box, I'm hoping to restart operations shortly using as much of these sets as is practicable. The extra detail it adds will be worth the effort, although sadly it's too late for most of the cockpit set due to the fact that it is all glued in place now. Highly recommended. Review sample courtesy of 3 Link to comment Share on other sites More sharing options...
IGKent Posted May 15, 2017 Share Posted May 15, 2017 Amazing! Link to comment Share on other sites More sharing options...
