Modelraynz Posted May 22, 2017 Author Share Posted May 22, 2017 21 hours ago, TheRazgriz118 said: I'm still very new to scale modelling but my best suggestion would be to maybe experiment with plastic sheet to extend the wing chord to match the edge of the fuselage and hopefully that would work with maybe some scribing here and there as needed. I saw someone do this with the italeri 1/72 su-27k to correctly shape the area where the canards meet the fuselage. Just my two cents. Hope it helps Hiya! Cheers ! Yea I've used some plastic card to close the gap and align Link to comment Share on other sites More sharing options...
Guest Posted May 25, 2017 Share Posted May 25, 2017 (edited) Go with the trailing edge alignment and trim down the leading edge at the root. The Airfix 19 is known to have too wide a chord on the wing and my gut feeling is that it's at the leading edge, which makes the cowling look too short when in fact it's the same length as all the other two stage Griffon Spits out there. Edited May 25, 2017 by The Wooksta! 2 Link to comment Share on other sites More sharing options...
Troy Smith Posted May 25, 2017 Share Posted May 25, 2017 2 hours ago, The Wooksta! said: Go with the trailing edge alignment and trim down the leading edge at the root. The Airfix 19 is known to have too wide a chord on the wing and my gut feeling is that it's at the leading edge, which makes the cowling look too short when in fact it's the same length as all the other two stage Griffon Spits out there. 3 Link to comment Share on other sites More sharing options...
Modelraynz Posted June 2, 2017 Author Share Posted June 2, 2017 Cheers guys! Yea i went with the trailing edge, was very very noticeably short if aligned to the leading edge! Two sword xvis turned up today! Looking forward to planning how to convert to Xvìi! :-) Link to comment Share on other sites More sharing options...
Guest Posted June 3, 2017 Share Posted June 3, 2017 Sword did a Seafire XII kit! There should still be plenty about - I haven't bought THAT many! And given you're in the right neck of the woods, the Ventura kit has be reissued by Jays Models. http://www.jaysmodelkits.com/jaysmk/ It'll need some cleanup and a fair few bits from the spares box (Eduard's mk IX can be your best friend there!), but it can and does build into a cracking little model. 1 Link to comment Share on other sites More sharing options...
stevehnz Posted June 3, 2017 Share Posted June 3, 2017 (edited) 1 hour ago, The Wooksta! said: Sword did a Seafire XII kit! There should still be plenty about - I haven't bought THAT many! And given you're in the right neck of the woods, the Ventura kit has be reissued by Jays Models. http://www.jaysmodelkits.com/jaysmk/ It'll need some cleanup and a fair few bits from the spares box (Eduard's mk IX can be your best friend there!), but it can and does build into a cracking little model. Yup. I used one of these, to build this. It had its moments but still a good basis for a Spitfire XII. Steve. Edited June 3, 2017 by stevehnz 1 Link to comment Share on other sites More sharing options...
Guest Posted June 3, 2017 Share Posted June 3, 2017 Sorry! I meant Seafire XVII! http://www.jaysmodelkits.com/jaysmk/index.php?main_page=product_info&cPath=65_71&products_id=182 1 Link to comment Share on other sites More sharing options...
Modelraynz Posted June 8, 2017 Author Share Posted June 8, 2017 Hiya, yea im thinking te ventura/jays kit will be the way to go; quite a bit of reshaping from a lowback spit xvi to a seafire!! Got the fuselauge together on the 45, though gotta use some dullcoat on the wing beneath the cockpit as 8s shining through! Link to comment Share on other sites More sharing options...
