Radleigh Posted April 21, 2017 Share Posted April 21, 2017 I'm after a tape, like Tamiya but about 3" or 4" thick, 4 would be ideal as I can trim it smaller... Anything out there? I'm not having much luck... Thanks in advance. Link to comment Share on other sites More sharing options...
Fatboydim Posted April 21, 2017 Share Posted April 21, 2017 You could try one of the below. I've used both and both are good. The Artool is very good. https://www.air-craft.net/acatalog/Artool-Ultra-Mask-24cm-x-2M.html#SID=2675 https://www.air-craft.net/acatalog/Tamiya-Masking-Sheet.html#SID=124 1 Link to comment Share on other sites More sharing options...
Merlin Posted May 13, 2017 Share Posted May 13, 2017 Not 3inch but only 1.5inch wide , same as Tamiya, well almost, is Frog Tape delicate surfaces from B&Q and other sources. 1. far better than the 1.5inch wide one seen at shows which is a paler slightly greeny yellow, not same colour as Tamiya, which is nothing like tamiya, 2. also avoid the one called STUK, same strength yellow as tamiya but, unless I got a duffer of a roll, hell on earth to remove as it kept tearing anywhere ! Merlin Link to comment Share on other sites More sharing options...
