stevej60    15,414
Hi folk's I'm enjoying a spate of easy kit build's at the moment so a good excuse to build a couple more comes by way of this GB.
Love em or hate em they are fun and do build into nice little kits with a little effort,so I'm ordering a couple or maybe two each of
these two for my entry sadly my go to retailer does not have the Mig 3 but with the Northern show on the horizon I might come
across one to add,should have them in time for the start.
Edited by stevej60
Basilisk    1,786
Good to see more WWII types in the GB. Looks like two relaxing builds coming up Steve.
I would use the Normandie-Niemen decals as the decals for Rogovoy's aircraft aren't correct - the yellow markings (line - actually two lines - and number) should be white. The Russians rarely used yellow on their aircraft as it was the theater marking of the Germans.
If you like to make Rogovoy's aircraft, Begemot makes a 1/72 decal sheet (actually 2 sheets) with choices for 68 different Yak-3 markings :o
Cheers, Peter
stevej60    15,414
Thank's for that info Peter,I'll avoid that scheme I was just ordering the two kits and had forgotten their LA-7 so we now
have a trio!
Edited by stevej60
stevej60    15,414
Morning folk's the kit's arrived yesterday so here's a peek,First up the Il-2 which came in a much smaller box than the usual easy kit
range and without the plastic tray but the sprue's were wrapped in foam and polythene even the tail had a foam cap protecting the
aerial connection.surface detailing is very well done too and beautiful canopy.
Next the La-7 which is an older release than the Il-2 but still very nicely done.
And finally the tiny Yak which was one of the early releases in the range but again still holds up well.
So ready to go when the GB starts all three should build well their respective canopies are all decent and the decal's look good
but I will need help with colours especially interiors etc when we start.As I said hopefully I will come across the Mig 3 on my
travels  to make it a quartet.
Basilisk    1,786
They don't look bad at all ! This link should answer most (if not all) of your question in regards to VVS colours.
Cheers, Peter
stevej60    15,414
Cheers, Peter
Superb link Peter many thank's all I need is there!
stevej60    15,414
Hi folk's someone once said a week is a long time in politics,well an hour is a long time in Hobbyboss modelling!
first job was to clean up the mold seams along the fuselage and wings.
There are two cowling option's and front fuselage insert's  with no instructions which ones relate to which version
thankfully Peter's link has the aircraft scheme I'm doing so sorted.The one piece wing and tail planes were added
as well as the U/C doors I love the way Hobbyboss have done these with very positive connecting point's
And within the hour she's up on her feet,no filler used and ready for the cockpit painted.
I also like the way a metal shaft is supplied for the propeller just popped it on for the photo it needs some detail painting.
Valkyrie    624
Looking great already!!!
PlaStix    12,386
Nice start Steve. :popcorn:
Kind regards,
Stix
Basilisk    1,786
These kits are maybe the ticket for me to get a build finished in the time frame of a GB. :unsure:
Cheers, Peter
stevej60    15,414
Morning folk's as the Yak shares a couple of colours with the La-7 I thought I would get both aircraft to he same point before slapping
paint on so another hour this morning and progress made to that end,strange I'm sure the Yak was an earlier offering but it has a better
cockpit(or at least it has a control stick),
And were ready for primer.
Stew Dapple    10,706
Nice start Steve, at this rate you'll be done by next weekend :D
Stew
stevej60    15,414
7 hours ago, Basilisk said:
Don't you paint the cockpits Steve?
Cheers, Peter
I will do Peter and putting belts and decals in but I thought I would leave them till last for a change as there are no internals other
than seats and stick's,when I start the Il-2 I will go the traditional route as it has a full cockpit layout.
stevej60    15,414
Stew
Ha thank's Stew you could be right,I was considering a few more Russian subject's thankfully I re-checked the rules as I was going
to add a couple of lend-lease P-39's from the same range not realising it was Russian/Soviet original's only,might go the Mig 15
trainer for one more though.:lol:
Grandboof    353
Both are looking good
Martin H
stevej60    15,414
Morning folk's,over the weekend I primed both aircraft in the blue underside colour then matching the profiles in Peter's link(as best as
I could) sprayed the lighter gray and brushed the darker camo this morning also started a base coat on the cockpit's. Hobbyboss tell
you to paint the Yak's top surface light blue and Pear green? References seem to show Normandie-Neimen aircraft in a similar scheme
to the LA-7.
stevej60    15,414
Hi folk's,the Yak's under gloss but the La-7 has a more detailed paint scheme so on the basic three tone paintwork the red cowl,
white section of the tail and natural metal plate now need's painting here's the start of the process.
stevej60    15,414
Morning all,the enjoyable side of the hobby,putting decal's on now they are starting to look Russian!
Basilisk    1,786
Looks like we have the first Gallery entry on the weekend - One week after commencing the GB :D
Cheers, Peter
PlaStix    12,386
Both looking very cool! Quick, beautiful modelling as always Steve. :thumbsup:
Kind regards,
Stix
wimbledon99    2,216
Blimey, I blinked and missed this ;)
On the case now though :popcorn:
