CedB Posted May 2, 2017 Author Share Posted May 2, 2017 Lots of shots of Rapides here. Obviously there are four and they do appear to be actuators, joined between the top and bottom wing with a wire through the strut (luckily). The PE has three pairs of two parts so I guess the funny symbol in between 20 and 21 in the diagram means 'different numbers other side' and there's a spare set? When I have some more mojo I think I'll fit them as single bits - I was going to fold them! Silly me. Rats - over the page. This diagram: Untitled by Ced Bufton, on Flickr 2 Link to comment Share on other sites More sharing options...
Spookytooth Posted May 2, 2017 Share Posted May 2, 2017 15 minutes ago, CedB said: (Reminds me of an old friend who used to test PA systems by saying "Testes, testes, one, two, THREE??!!") That`s where I have been going wrong Ced, and I thought the 1,2 1,2 bit was the count of the audience. Looking near priming then mate. Simon. 1 Link to comment Share on other sites More sharing options...
CedB Posted May 2, 2017 Author Share Posted May 2, 2017 Thanks Simon - closer... The kit actuators were cut off carefully with a chisel blade: and some slots made with the RB Productions angle scribers. First time I've used them and crikey, they're sharp: Thanks to Fritag for the recommendation. PE then glued on: with a spot of CA in the slot and then prodded around the edges. The nibs on the top have been filled off now; only saw them in that photo. Held carefully with tweezers and filed, only one fell off. Nacelles prepared: All I need to do now is cut the struts off the sprue, clean them up and not mix them up when spraying: I'll number up some cocktail sticks. 15 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 2, 2017 Share Posted May 2, 2017 Looking rather spiffing Ced. Excited for paint! Johnny 1 Link to comment Share on other sites More sharing options...
giemme Posted May 2, 2017 Share Posted May 2, 2017 6 minutes ago, The Spadgent said: Looking rather spiffing Ced. Excited for paint! Johnny Same here Ciao 1 Link to comment Share on other sites More sharing options...
Stew Dapple Posted May 2, 2017 Share Posted May 2, 2017 +3 Cheers, Stew 1 Link to comment Share on other sites More sharing options...
CedB Posted May 2, 2017 Author Share Posted May 2, 2017 Thanks Gents. Struts on sticks: Untitled by Ced Bufton, on Flickr Primer tomorrow, at last! 8 Link to comment Share on other sites More sharing options...
TheBaron Posted May 2, 2017 Share Posted May 2, 2017 I've been listening to old episodes of I'm Sorry I Haven't a Clue whilst catching up with this Ced and now hear Willie Rushton's voice reading out your posts. This modelling lark gets very confusing sometimes doesn't it? Glad to see you're wrestling those shapes into submission and approaching painting imminently. 1 Link to comment Share on other sites More sharing options...
CedB Posted May 2, 2017 Author Share Posted May 2, 2017 Ah, Willie, sadly missed (stop it you lot!) My first 15 minutes of fame came when I appeared on 'Celebrity Squares' some years ago; 1978. Willie was one of the celebrities. For those that remember the game, the last round was 'name nine xxxx' for a £1000 prize. My subject? Classical composers. We had been briefed by the wonderful Bob Monkhouse (a truly lovely man) to work though the alphabet when trying to think of our answers. At 28 seconds I said 'Schubert', my ninth answer. Bob said "Did you say 'Shubert'?" "Yes" says I and off went all the lights. Willie said "He said 'Tuborg' - that's a lager" but I still won. I was presented with the question card and, in the bar afterwards, had it signed by 'the stars' that had stayed behind. 13 Link to comment Share on other sites More sharing options...
CedB Posted May 3, 2017 Author Share Posted May 3, 2017 I've just started priming and the cheap airbrush I use for priming has clogged. Deep clean. Spatters. Grrrr. You get what you pay for I guess. In the bin. Another cheap one ordered from Amazon, delivering tomorrow. Some people never learn. 7 Link to comment Share on other sites More sharing options...
CedB Posted May 3, 2017 Author Share Posted May 3, 2017 While I was waiting for the airbrush... Fitted the PE rudder actuators: Started on the prop for the pressurisation unit: I think that's going to need some tiny blade extensions. Gulp. Cut off some clear sprue for the red nav light thingies: and painted them up: 15 Link to comment Share on other sites More sharing options...
giemme Posted May 3, 2017 Share Posted May 3, 2017 Very nice details there, Ced Ciao 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted May 3, 2017 Share Posted May 3, 2017 + 1 Simon. 1 Link to comment Share on other sites More sharing options...
keefr22 Posted May 3, 2017 Share Posted May 3, 2017 +3 !! K 1 Link to comment Share on other sites More sharing options...
TheBaron Posted May 3, 2017 Share Posted May 3, 2017 (Plus four) 4 Link to comment Share on other sites More sharing options...
Cookenbacher Posted May 3, 2017 Share Posted May 3, 2017 Now we must find a way to post that episode of Celebrity Squares on Youtube - extend that 15 minutes a bit for your Britmodelling friends. The Rapide is looking elegant Ced. 5 Link to comment Share on other sites More sharing options...
Paul J Posted May 3, 2017 Share Posted May 3, 2017 Looking fine Ced. But did you check the position of the aileron actuators??? Because the raised ribs of the kit depicting these are not all in the right place!! If you view from the front, you will see that they are a rib or so out. Ref my build in this GB. The outer 'I' struts actually contain the cables for the aileron actuators on the real aeroplane as you know.. If you are brave enough and if its not too late, you could still move the new etch parts to the correct locations and render the surface before painting. Also the tail plane elevator hinge lines are swept back!!! I found this out almost too late when building mine. I rectified this by sanding of the rib detail to the fixed portion of the tail planes and fixed them best I could to get it right which helped a bit but one does need to watch for this. 1 Link to comment Share on other sites More sharing options...
CedB Posted May 4, 2017 Author Share Posted May 4, 2017 Thanks Gents - very kind Cookie I'm afraid there's no video record of the programme. No one I knew had a video recorder at the time - too new and expensive! I do have a tape recording that my sister did from the TV; awful quality but now digitised and in my iTunes. Thanks Paul. I've checked the actuator position and it looks as though it's been corrected in my version of the kit: Untitled by Ced Bufton, on Flickr Phew! Come on Amazon, get that airbrush here! (He said, having been conditioned to expect things to be delivered from anywhere in minutes. Roll on transporter beams!) Star Wars day today - May the Fourth be with you! 10 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 4, 2017 Share Posted May 4, 2017 On 03/05/2017 at 0:28 AM, CedB said: That's Amazing. Bob was ace! Willie's comment on the card too. Ha! come on did you say "Tuborg" your secrets safe with us. . Oh an what's going on with cheep airbrushes at the moment? Mines borked too? Grumble, grumble. Wonderful progress Ced. Johhny. 2 Link to comment Share on other sites More sharing options...
06/24 Posted May 4, 2017 Share Posted May 4, 2017 In honour of Willie, Ced and May the Fourth... I give you: 2 Link to comment Share on other sites More sharing options...
Paul J Posted May 4, 2017 Share Posted May 4, 2017 23 minutes ago, CedB said: Thanks Gents - very kind Cookie I'm afraid there's no video record of the programme. No one I knew had a video recorder at the time - too new and expensive! I do have a tape recording that my sister did from the TV; awful quality but now digitised and in my iTunes. Thanks Paul. I've checked the actuator position and it looks as though it's been corrected in my version of the kit: Untitled by Ced Bufton, on Flickr Phew! Come on Amazon, get that airbrush here! (He said, having been conditioned to expect things to be delivered from anywhere in minutes. Roll on transporter beams!) Star Wars day today - May the Fourth be with you! Ah! Then that supports my theory that the one s Airfix boxed could have been rejects by Heller... 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted May 4, 2017 Share Posted May 4, 2017 Have you got an ultrasonic cleaner for your airbrush(es)? If not I would suggest you invest in one, I bought mine from Amazon. They work really well and SWMBO also uses it for jewellery and things like that. John I also miss Willy Rushton 2 Link to comment Share on other sites More sharing options...
CedB Posted May 4, 2017 Author Share Posted May 4, 2017 3 hours ago, The Spadgent said: That's Amazing. Bob was ace! Willie's comment on the card too. Ha! come on did you say "Tuborg" your secrets safe with us. . Oh an what's going on with cheep airbrushes at the moment? Mines borked too? Grumble, grumble. Wonderful progress Ced. Johhny. Thanks Johnny - Bob was great, as were the others who signed the card in the bar; very nice people and not at all 'precious'. Cheap airbrushes? Well, you get what you pay for I guess. The one that's been binned, and its colleague, came with the cheap compressor as a set. All have gone to landfill now. The last brush had a side feed cup, almost impossible to clean. Especially when used for primer which, as its name suggests, sticks like anything. Stynylrez does come out quite easily with the Badger cleaner but only if you're quick. I'm sort of regretting spending the money on another cheap one... should have put the money towards something that'll last. My H&S Evolution is great but, now I'm using Cookie's close up / build up spray method for variation, I keep the 0.2 nozzle in it. Even with the 0.4 nozzle I got fed up having to strip it after primer. Off to the Gloucester show a week on Sunday so I think I'll talk to Paul from Modelling Tools - he's always great for advice and his prices seem to be competitive. 2 hours ago, 06/24 said: In honour of Willie, Ced and May the Fourth... I give you: Thanks Jon Although everyone knows Darth is from Bristle, inni my luvver! 2 hours ago, Paul J said: Ah! Then that supports my theory that the one s Airfix boxed could have been rejects by Heller... Thanks Paul - certainly strange eh? 2 hours ago, Biggles87 said: Have you got an ultrasonic cleaner for your airbrush(es)? If not I would suggest you invest in one, I bought mine from Amazon. They work really well and SWMBO also uses it for jewellery and things like that. John I also miss Willy Rushton Thanks John I do have an ultrasonic cleaner and it's great for deep cleans - nice and easy. Come on, come on... had my 'out for delivery' email so not long now... 4 Link to comment Share on other sites More sharing options...
Leonl Posted May 4, 2017 Share Posted May 4, 2017 All caught up now.... Nice progress Ced.... 1 Link to comment Share on other sites More sharing options...
CedB Posted May 4, 2017 Author Share Posted May 4, 2017 Thanks Keith The airbrush has arrived. Sprayed the white Stynylrez with it: Untitled by Ced Bufton, on Flickr The Amazon description says it comes with multiple nozzles and I was going to use the 0.5mm one. Guess what - it only comes with a 0.2. Of course it clogged. I have learned my lesson - you gets what you pays for! 8 Link to comment Share on other sites More sharing options...
