F-111E, 68-020 "My Lucky Blonde"
vesthepes
Hello chaps
Nice to be around this one, the wait is over... I am pretty sure this is going to be a pleasant and entertaining group build, as it is usual here on BM...
I'm in with a colorful F-111E carrying a nice noseart. Not sure about its role in Libya, all I know it was the commander of the sqd. flagship and that the noseart brought luck to the pliot back from the days of Vietnam. Hopefully someone can add some info o the subject, I'd be very happy to hear.
Initially I was thinking of a downed F-111F 70-2389 callsigned Karma 52, but since I don't have the decals for it, I'll stick with the E version. Plus I've heard the IP in the Verlinden set is to match the E and not the F version... I cannot confirm it yet, I will have to take a look at both of the panels and then compare it to the resin one...
Anyway, here's obligatory stuff:
classic Libyan raiders markings...
eduard etch
old Verlindern set, still very useful
a must
too bad both afterburners are open, but still better than the kit offering
this last item is very nice, but I sincerly doubt I will use, as my place on the shelf is limited and this beastie's wingspan is not a joke...
that's about it for now...
cheers,
Vasko
Edited by vesthepes
  • Like 9
Welcome aboard Vasko and yes the wait is finally over after what seems forever. It's nice to see a colourful F-111, plus a huge mound of AM bits!!
You're not wrong about her being a big beast in 1/48th!! I'm not quite sure where I'm going to put mine when she's done!
Good luck with the build, glad you've been looking forward to it, hopefully all that AM stuff won't give you too much grief!
Craig and Rich, thank you for your welcoming words.
My main concern is finishing in time so I will try to kick off ASAP, also the etched part are known for prolonging builds by years...
I probably won't use the Eduard interior as the Verlinden set is all good. Same goes with the flaps and slats. I want a model with wings swept back or preferably with movable wings...
Anyway, here's a few shots of the interior parts...
three layers of PE
a size comparison, just to see what we're dealing with...
that's it for now,
cheers
Edited by vesthepes
nice start, and thank you, I've now found a mistake I've made (well poor instructions!!) with a couple of small PE bits in my cockpit, when compared to yours!
You'e not wrong about the size of her, I'm going wings open!!!
19 hours ago, Hewy said:
Hi vasko,my lucky blonde changed its name to "The chief"in 1988,if i find out more I'll let you know
Glynn
That's interesting. 'The Chief' is now at Duxford in the American Air Museum. I notice she's on the kit decal sheet, complete with tail flash and nose art.
Hi smudge, apparently whats known as" the other chief"67120  in the imperial war museum, the original "lucky blonde"  68020 which changed its name in 1988 to
" the chief" returned back to the usa in december 1993, changed its name back to "lucky blonde" and is now on display at Hill AFB i belive in utah, by the way I'm not a know it all  anorak its all out of a book I'm reading (swotting up) ready for when i enter the fray this week with a f-111a:P,,sorry to vasko didn't mean to hijack your thread
Edited by Hewy
Spelling
I'm  now intrigued  concerning  two -111E's called "the chief" one was "my lucky blonde"
 Renamed " The chief"in 1988 and returned to the us in 1993 this  was the wing flag ship at this time , the  other "the chief" 67120 which  now resides at duxford, it  may have been  another wing flag ship at some time but when, and what was its previous art work, if any  ,any one know more,?i know there was early and late "the chief" artwork the one on your sheet looks to be the late type on 67120 now in duxford , the early type,originally "my lucky blonde" had no writing just a chiefs head,
Sorry for rambling, hope i make sense,
Glynn
Thanks for the interest guys ...
Glynn no need to apologyze, your input is welcome here and so is everybody elses! Thanks for sharing, I knew something about the same serials as the ones on The chief. And then like you said I also saw the photos of My lucky blonde in Hill AFB and The chief at Duxford...
Anyway, I'd like to find out more about its days in '86, to be specific on the night being in Libya. Main reason would probably be the armament during the raid. Was it GBU-10s or mk.82s? probably latter, right?
cheers
Ok I'm sorry if this seems to be going on, but it is very intriguing, I'll use the quoted text (from the Crowood book);
"A1-189 68-020, named "My Lucky Blonde" 1987-88, the second of two E's which were named "The Chief" when assigned to subsequence 20 TFW/FW Wing Commanders. Ret. 07/12/93, preserved at Hill AFB Museum, Utah."
"A1-165 67-120, Det. 3 57 FWW 1972 (Test & Eval. Sqn.). Remained at Nellis until 1978, when reassigned to 20 TFW. One of two E's named "The Chief" from 1987 when assigned to 20 TFW Commanders. Desert Storm veteran (19 scores). To Duxford Museum 10/19/93."
Again it's quite unusual for two aircraft to carry the same name!
Ok your question on load outs, I found this.....all reference to the aircraft used in the Libyan strike for some reason are listed as F models in just about everything i've read. There must have been a mix of aircraft and nobody really checked.
"The F-111Fs carried payloads of 4 x 2000lb laser guided GBU-10 Paveways or 12 x 500lb Mk20 Cluster Bombs (CBUs), the latter used both in the airport and naval base strikes. Approaching the targets the Pave Tack laser provided precise ranging, after bomb release it illuminated the targets to guide the Paveways to impact."
Ok if the picture of your aircraft above is correct..... :whistle: then she would have been a non-Pave Tack aircraft which attacked the airport and naval base, so would have been carrying the Mk 20's. To find out when she was converted to Pave Tack would be quite hard, so I think you'd be safe loading her up with the Mk.20's.
Hopefully this is of some help, if I find out anything more I'll post it.
Ok I just found this, all F models had Pave Tack and from what I've read the E's never have it fitted (well not at this stage), plus the 20mm M-61 was not fitted either (only on state side A's & D's)
Please, do not be, I enjoy this quite a lot.
Quote
Are you sure about the usage of mk.20 clusters? I am almost positive about 500 lbs mk.82 airs along GBU-10s were used in raids on Lybia on F-111F.
Something like this:
wikipedia source
Quote
I thought exactly the same, having in mind the mk.82s...
And oh yes, the E version seems to be completely forgotten, and it's almost like only the F version operated that night... and maybe it did, and E's were only a back up? Nevertheless they still had to be armed...
Quote
Thanks for your research Rich, I appreciate it.
and some work on the interior... one coat primer, one coat black, one coat light grey... painted the panels black, still have to go into details..
cheers
Edited by vesthepes
man that cockpit looks great!!
:wall: sorry I meant Mk.82's!! The E's would have been fine at night on the port and airfields, you'd be surprised just how accurate they would have been, but the F's were for the really precision stuff. There's is bound to be some more detailed account online somewhere.
cheers
As  rich rightly states the" E " couldnt drop gbu's on its own although i believe some  did carry them and then  had the target lit up by F4's,in much the same way our buccaneer did but maybe not on the libya raid
Glynn
Edited by Hewy
Unfinished
A good start with the build. Remember the Libyan raid well, as I think that our Sqn in the RAF was almost put on standby to fly during the time the raid was going on.
It seems to be the same with the Gulf as well. I can find lots of pictures of Fs with their weapon load, but none of the Es and that is also looking on dstorm.eu which has many a photo of a Gulf period aircraft.
The F-111E didn't fly on Operation Eldorado Canyon, only the F-111F and EF-111A. The 20th TFW did fly a practice mission to the USA in December 1985 to simulate a mission to Libya
http://www.arcforums.com/forums/air/index.php?/topic/286536-f-111f-el-dorado-canyon/#comment-2734254
The F-111F carried either 4 x GBU-10 or 12 x Mk82 (AIR) .
cool, thanks for that, that clears it all up, plus now of course i find a more detailed article as will (very interesting read). Plus it does make sense they'd use the F model as that was the best of the series and most capable.
Normal service can resume Vasko now that's all be sorted out......:D
Thanks for all the info chaps!
 I found out that the mission was called "Operation Ghost Rider"
http://www.shaw.af.mil/News/Features/Display/tabid/6145/Article/719405/remembering-operation-ghost-rider-and-el-dorado-canyon.aspx
More details in the office:
Some itsy bitsy pieces still have to be added and some fell off in the process of painting...
cheers
cheers
Edited by vesthepes
A little update...
Added some detials on the IP "cover", to be more precise "nuclear blast shield"... No instructions by Verlinden for the HUD, but the part wan't hard to find...
The capsule went together quite OK. I was surprised by the instructions to insert a 60g weight into the nose... 60g!! way too much IMO, so I ended up inserting 15g which should be enough
Removed the resin parts from the stubbs and cleaned up...
The movable wings mechanism make this kit quite a clanker.... is that a correct term?
Too much Lego for me... it does work, but not quite like it should...
thanks for looking in...
cheers
Edited by vesthepes
