Hawker Typhoon 1:24
Have been working on four parts for a diorama which will include a Hawker Typhoon, Matador 0854 with Cole Crane Mk V11, a Willys Jeep and a Accumulator, this will be shown with the Typhoon engine hanging from the crane hook, being just replaced with a new one, I hope I can catch the moment.
Have bought all the aftermarket stuff I think everyone knows what is out there.
First picture is what I want to capture, photo is for reference only.
Cleaned up a lot of the seams, filled a few holes etc etc  and then painted aluminum
Machined the shaft out of brass
Started to add some detail to the controls
Until next time,
Regards
Richard
  • Like 22
On 3/27/2017 at 5:49 PM, Jaffajake said:
Very nice start so far. I like the brass shaft. That's a very neat addition.
Shaft did turn out better than the plastic one should have taken a couple more pictures, thanks for looking in
On 3/27/2017 at 6:25 PM, propforward said:
Brilliant - looking forward to this. I have a 1:24 car door Typhoon, so I'll be looking for tips and ideas. Looks great so far!
Will buy one car door, because I do have three of these, maybe I will see if someone wants to swop one.
On 3/27/2017 at 9:09 PM, Christer A said:
That's the Mk1 detailing kit isn't it?
Excellent work on the Throttle!
Did buy the Mk 1 detail but did not use, I don't like the colour on the brass, it looks more blue than black?? so I made all items on the throttle, except for the wood gear
On 3/27/2017 at 10:31 PM, Grey Beema said:
Great start - I think I'll leave mine in the box a bit longer and carry on with my knitting...
Naa get it out and have fun building it Grey it is a nice kit.
On 3/28/2017 at 12:10 AM, Biggles87 said:
From the look of your start, this is going to be something special.
Looking forward to more.
John
Hi John, thanks for looking in I hope it turns out how I want it to be.
Painted the engine, and started the control panel
Put some spark plugs in
Added the seat belts
Until next time
Regards
Richard
  • Like 14
On 3/29/2017 at 11:40 PM, Christer A said:
Show-off!:smirk:
Those sparkplugs were just the thing!
Very nice instrument panel too!
Hi Christer put the spark plugs in because the engine will be seen.
Added more to the cockpit
Until next time
Regards
Richard
  • Like 17
On 3/30/2017 at 9:54 PM, Christer A said:
The details in the cockpit are amazing!
It's fortunate that I'm not doing a 1/24 Tiffy at the same time, I'd give up!
The cockpit did turn out not to bad Christer, on the right side added the windscreen de-icing pump and needle valve, levers for drop tank jettison, engine starter reloading control, drop tank cock control. For all the gauges I punched out clear plastic to fit each one of them
On 3/30/2017 at 11:57 PM, Gremlin56 said:
Nice to see you working your magic on the Typhoon Richard, excellent job underway :yes:
Hi Julian, thanks for joining in :like: on another model I hope to finish, not going to do too much scratch building will leave that for the Matador, but I will add my 2 cents worth
On 4/3/2017 at 11:57 PM, longshanks said:
Good to get my morning fix........
Usual crisp modelling for us to enjoy
Kev
Hi Kev has Mo & Jo come back :nod:, hope so do look forward to you scratch building, well this Typhoon is a very nice model and will compliment the other items
On 4/4/2017 at 12:17 AM, FZ6 said:
Inspirational build so far. After watching your Hurricane progress this is going to be a thoroughly enjoyable thread to watch.
Regards,
Mark
Hi Mark, yes yes the Hurricane do have to get back working on her again :wonder: soon I hope, this one will not be anywhere near the detail
On 4/4/2017 at 7:21 AM, PlaStix said:
Great start and beautiful modelling.......as usual! :worthy:
Kind regards,
Stix
Glad you could join the fun Stix hope this will be the third piece I will finish no pressure :nod:
Will be adding a few wires here and there, bought the Typhoon maintenance manual from Mach One Manuals and in the manual it had so great detail of the Pneumatic system so I started by adding the air hose, filter to the air container behind the seat, will be cutting the panel which goes to the radio's so you can see this
Then started on the engine by using some flex hose to replace the plastic part
Until next time
Regards
Richard
  • Like 14
On 4/4/2017 at 9:02 PM, Christer A said:
That hose is a great addition!
I guess you will spice up the Coffman starter as well?
Hose does make a difference Christer it was quite the bugger to get it to look like the pictures
On 4/5/2017 at 12:12 AM, PlaStix said:
You certainly have an eye for detail. The additional hoses really add to the appearance. :thumbsup:
Kind regards,
Stix
Thanks very much Stix I think you have seen I do love adding my 2 cent worth of detail.
Because I am going to have the engine hanging from the crane I needed to cut the back end of the engine mount so that I could glue the carburetor to the engine and be able to get it in and out
Then filled the cross which they had in the fire wall
Then added the ducting from Radiator used a bit of aluminum off a wine bottle to hide the splice
Until next time
Regards
Richard
  • Like 13
Beautiful work Richard, the hoses look lots better than the plastic ones supplied by Airfix. Good job you are leaving the panels off, had a devil of a job to get them to fit around the engine when I did this build (although knowing your skills you would probably have made new panels of sheet metal ;)).
On 4/7/2017 at 11:46 PM, Christer A said:
Those small small details like the aluminium foil are great!
Keep it up!
Thanks alot Christer it does hide the joint really well.
Did look at a lot of engine pictures to see what the hoses would look like, as you say it does look way better than the plastic, got to go and find your build now, did you do a WIP.
Now making panels :o  that would have been something to do but not for this project, but I do have two more Typhoons in the stash ;) I do have all these parts to use up
I bought the Eduard BIG box for the Typhoon so here are the guns
One thing you will have to do is cut more out of the bottom slot so that it will fit right
Also I bought the 20 mm Master barrels which are the same ones which go in the Mossi so I decided to match up to the Eduard set, had to make a shape out of brass to fit into the eduard part
This is how it turned out
Pic with the Airfix gun by the side
Until next time, and thanks to everyone who is looking in
Regards
Richard
  • Like 10
Now got the bottom of the wings glued on and did a little more detail to the engine
Made up the ammo cases and at the same time did the flaps
Changed the back gun mounts to more what they should look like
Started to get the guns in
Until next time
Regards
Richard
  • Like 13
IMG_6703_zpszciku8f9.jpg[/URL]
I am following this build with interest!
Where did you get the small diameter flex hose?
Jens
