Shar2 Posted March 21, 2017 Share Posted March 21, 2017 USN 40mm Bofors Quad mounts 1:350 Master Models As we saw in the Twin Mounts sets reviewed HERE, MASTER models are upping their game with the maritime releases. Once again we see a selection of resin, PE and turned brass. The resin and etch have also been produced by North Star and incorporated into the sets. The new boxes the same style too, with the resin parts in their own compartments in the foam for added protection. [SM-350-093] As with the twin sets, this set contains six version 1 mounts, each mount is made up from no less than twenty two parts, so, once again you will need your optivisors and best tweezers, along with an extra bottle of patience, as you will need them. The resin gun mount is fitted with a two resin front pieces and two PE seats complete with footrests. The gun slides are then rolled to shape and fitted to the mount, along with two hand wheels. Two pairs of twin guns are built using a resin breech, two brass barrels, PE sights and sight covers and a PE elevation arc. The gun assemblies are then attached to the mounting, which is then finished off with the rear mounted railings which have ammunition storage racks built in. The set also include a Mk51 director sighting pedestal, made from a resin pedestal, shoulder guides and deck mounting ring. [SM-350-094] – This set is for version 2 of the twin 40mm Bofors mounts and is the same build as the version above, but, unlike the twin mounts, I cannot see any appreciable differences, unless it’s the fact that version 1 is a manual mounting and version2 is power operated as there is some slight equipment differences on the mounting, but only if viewed through a magnifying glass.. [SM-350-095] – This set is for version 3 of the twin 40mm Bofors mounts and is the same build as the version 2 above, with a different rear mounted railing, and a full splinter shield to the front. Conclusion Since these mountings were fitted to almost every US warship from the frigate and larger, these sets can be used on almost any model released. Just check you references to check which mounting was used. Review sample courtesy of Piotr at 2 Link to comment Share on other sites More sharing options...
Julien Posted March 21, 2017 Share Posted March 21, 2017 The optivisor is needed for these I think! Link to comment Share on other sites More sharing options...
