Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
Sign in to follow this
Followers 0
Shar2
MASTER
USN 40mm Bofors Twin mounts. 1:350
1:350 Master Models
We’ve had quite a few new sets in from Master Models, mostly turned brass or aluminium, yet with these sets they have added another dimension with the inclusion of resin and photo etched parts. The resin and etch seem to have been produced by North Star and incorporated into the sets.  The new boxes are great too, with the resin parts in their own compartments in the foam for added protection.
[SM-350-091] This set contains six version 1 mounts, each mount is made up from no less than seventeen parts, so get your optivisors and finest tweezers out, as you’re going to need them. Once finished though they will look amazing when complete. The resin gun mount is fitted with a resin front piece and two PE seats complete with footrests. The gun slide is then rolled to shape and fitted to the mount, along with two hand wheels. The twin guns are built using a resin breech, two brass barrels, PE sights and sight covers and a PE elevation arc. The gun assembly is then attached to the mounting, which is then finished off with the rear mounted railings. The set also include a director sighting pedestal, made from a resin pedestal, shoulder guides and deck mounting ring.
[SM-350-092] – This set is for version 2 of the twin 40mm Bofors mounts and is the same build as the version above, with a different rear mounted railing, which is complete with ammunition storage racks.
Conclusion
I have to say, I really like these sets, the level of detail is amazing, if rather fiddly and eye watering. They will certainly add that extra something to a model.
3 people like this
Hello,
I totally agree, seem very nice.
I Wonder about my large fingers:huh:
Even at 1/48 I use pincer and magnifier :mellow:
Thank for the nice review.
Corsaircorp
Followers 0
