Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
Sign in to follow this
Followers 0
jtabbey
Wallace and Gromit motorbike and sidecar/plane what glue to use
Hello,
i have a Wallace and Gromit motorbike and Sidecar I'm about to start building. I've read that the plastic is hard to glue. Does anyone have any suggestions/advice/recommendations of a suitable glue to use. Also any suggestions for vallejo, gunze or tamiya shade of red to use?
Thanks in advance
I built the aeroplane a while ago and the plastic is, er, hard to handle! Under advice I used 5-minute epoxy to glue the parts, mixing up small batches and applying with a cocktail stick. My kit came with Humbrol 19 acrylic (although I didn't use it).
Julian ( @Gremlin56 ) built the motorbike and used Mr. Hobby Mr. Cement S glue with Tamiya rattle can red (not sure what colour, sorry, but I guess their 'red'?)
The plastic is quite 'oily' and doesn't sand well, but it does trim with careful use of a scalpel.
If you're painting with acrylics I'd suggest a wipe over with some IPA after assembly and use a Stynylrez primer - great stuff.
HTH.
I just used regular Revell Contacta glue in the blue pot with a needle.
But; I also drilled out the arm etcetera locations and inserted sprue pegs to help strengthen the joints
Followers 0
